With snappy connectivity from palm to print, this chic and sleek 3-in-1 multifunctional is the ideal tool for crafts and creations - and the perfect print partner for your smartphoneWith snappy connectivity from palm to print, this chic and sleek 3-in-1 multifunctional is the ideal tool for crafts and creations - and the perfect print partner for your smartphone.
Minimalist with a creative twist
Stickers, magnets and crafts – unleash your creativity with a huge range of medias and apps. With easy connectivity, simplified OLED display, LED status bar and first-class FINE cartridges, this chic printer packs a punch for the smartphone-savvy.
Make it your own with the Canon PIXMA TS5350 Series
Transform your next project with Easy-PhotoPrint Editor, Creative Park and Message In Print and try out restickable, double-sided matte and iron-on transfer media.
Smart and connected
Print, scan, copy and connect to Facebook, Instagram and other cloud** accounts from your smartphone using the Canon PRINT app, or print app-free with AirPrint (iOS) and Mopria (Android).
Unleash your creativity
Use the printer's 45 built-in patterns to design scrapbooks or your own wrapping paper. Get creative using Canon’s Easy-PhotoPrint Editor app for iOS or Android.
Effortless connectivity
With options like AirPrint, Google Cloud Print, and Wi-Fi Direct, this Canon PIXMA TS5352a ensures seamless connection across all your devices, making it easier than ever to print from anywhere. -
Versatile media handling
From glossy photo paper to envelopes and iron-on transfers, the Canon PIXMA TS5352a handles a wide range of media sizes and types, accommodating all your printing needs. -
High-quality printing
Achieve high print quality with a maximum resolution of 4800 x 1200 DPI and Canon ChromaLife100 ink, ensuring your photos and documents look professional with vivid colors and sharp text. -
Convenient scanning and copying
With a high optical resolution of 1200 x 2400 DPI for scanning and features like 2 on 1 copying, this all-in-one printer simplifies document management and allows for easy duplication and digitalization of your documents. -
Eco-friendly design
Automatic duplexing allows for easy two-sided printing, reducing paper usage and helping you contribute to environmental conservation.
- Canon PIXMA TS5352a - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
- Max Printing Speed
- Up to 13 ppm (mono) / up to 6.8 ppm (colour)
- Max Printing Resolution
- 4800 x 1200 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Display
- 1.44"
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- 55 x 89 mm (min) - 215.9 x 676 mm (max)
- Media Type
- Envelopes, plain paper, iron-on transfers, glossy photo paper, matte photo paper, high resolution paper, luster paper, semi-gloss paper, photo stickers, magnetic photo paper
- Standard Media Capacity
- 200 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- PIXMA Cloud Link, access point mode
- Power
- AC 120/230 V (50/60Hz)
- 40.3 cm x 31.5 cm x 14.8 cm
- 6.3 kg
- Enclosure Colour
- Pink
- 2 Years
- Ink-jet - colour
- Display Diagonal Size
- 1.44"
- Display Features
- OLED display
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Enclosure Colour
- Pink
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Ink Type
- Canon ChromaLife100
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 8-bit
- Colour Depth (Internal)
- 16-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Supported Original Sizes
- 216 x 297 mm
- Original Type
- Sheets
- Min Media Size
- 55 x 89 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 130 mm, 215.9 x 676 mm, 55 x 89 mm, 89 x 89 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- 200 sheets
- Input tray - 100 sheets size: 55 x 89 mm - 215.9 x 676 mm weight: 64 g/m² - 300 g/m² , Paper cassette - 100 sheets size: A5 (148 x 210 mm) - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 105 g/m²
- Speed Details
- Printing: up to 16 ppm - B/W , Printing: up to 6.8 ppm - colour , Printing: 43 sec (10 x 15 cm (4"x6")) - photo
- 1 x USB 2.0 - 4 pin USB Type B
- WEP, WPA-PSK, WPA2-PSK, Wi-Fi Direct
- Operating System Support
- MS Windows 7 SP1, Android, iOS, Windows 8.1, Windows 10, Windows 10 Mobile, Apple Mac OS X 10.11.6, macOS 10.12 - macOS 10.14
- Software Included
- Drivers & Utilities, MP Driver including Scanning Utility, Canon Easy-PhotoPrint Editor
- Voltage Required
- 19 Watt
- Power Consumption Standby
- 0.9 Watt
- Direct Printing Specifications
- PictBridge
- Consumables Included
- 1 x toner cartridge (black) - Canon PG-560 , 1 x toner cartridge (colour) - Canon CL-561
- 40.3 cm
- 31.5 cm
- 14.8 cm
- 6.3 kg
- Shipping Width
- 48.15 cm
- Shipping Depth
- 47.7 cm
- Shipping Height
- 22.3 cm
- Shipping Weight
- 7.7 kg
- Sound Emission
- 43.5 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80% (non-condensing)
- 2 Years
