The Canon PIXMA TS5350i is a versatile all-in-one printer that combines high-quality printing, scanning, and copying functionalities into one compact device. Designed to meet the needs of both home and office environments, it offers a range of connectivity options including Wi-Fi, AirPrint, and Google Cloud Print, allowing for easy printing from smartphones, tablets, and computers. With support for various media types and sizes, this printer is ideal for creating everything from detailed documents to stunning borderless photos. The inclusion of automatic duplexing further enhances its efficiency, providing an environmentally friendly solution to double-sided printing. Whether you're printing high-resolution images or scanning and copying documents, the Canon PIXMA TS5350i delivers performance and convenience in one sleek package.
Style credentials
An ultra-cool 2-tone color scheme and a chic minimalist design with LED status bar give this printer some solid style points. -
There's an app for that
Print, scan, copy and connect to Facebook, Instagram and other cloud accounts from your smartphone using the Canon PRINT app, or print with AirPrint (iOS) and Mopria (Android). -
Make it your own
Transform your next project with Easy-PhotoPrint Editor, Creative Park and Message In Print and try out restickable, double-sided matte and iron-on transfer media. -
Shareworthy snaps
Get picture-perfect photos with up to 100 years of album life thanks to the ChromaLife100 ink system.
- Canon PIXMA TS5350i - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
- Max Printing Speed
- Up to 13 ipm (mono) / up to 6.8 ipm (colour)
- Max Printing Resolution
- 4800 x 1200 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Display
- 1.44"
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Media Size
- 55 x 89 mm (min) - 215.9 x 676 mm (max)
- Media Type
- Plain paper, high resolution paper, photo paper pro platinum, glossy paper, luster paper, semi-gloss paper, matte paper, envelopes, restickable photo paper, magnetic photo paper, iron-on transfers
- Standard Media Capacity
- 200 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- PIXMA Cloud Link, access point mode
- Power
- AC 120/230 V (50/60Hz)
- 40.3 cm x 31.5 cm x 14.8 cm
- 6.3 kg
- Enclosure Colour
- Black
- 2-year warranty
- Ink-jet - colour
- Display Diagonal Size
- 1.44"
- Display Features
- OLED display
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Enclosure Colour
- Black
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, fit to page, two-sided copy, photo copy
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Ink Type
- Canon ChromaLife100
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 8-bit
- Colour Depth (Internal)
- 16-bit
Document & Media Handling
- Max Original Size
- Supported Original Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm)
- Original Type
- Sheets
- Min Media Size
- 55 x 89 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 200 x 250 mm, 130 x 180 mm, 100 x 150 mm, 130 x 130 mm, 89 x 89 mm, 55 x 89 mm, 215.9 x 676 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 200 x 250 mm, 130 x 180 mm, 100 x 150 mm, 130 x 130 mm, 89 x 89 mm
- 200 sheets
- Input tray - 100 sheets size: 55 x 89 mm - 215.9 x 676 mm weight: 64 g/m² - 300 g/m² , Paper cassette - 100 sheets size: 148 x 210 mm - 215.9 x 297 mm weight: 64 g/m² - 105 g/m²
- Speed Details
- Printing: up to 13 ipm - B/W , Printing: up to 6.8 ipm - colour , Printing: 43 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 4 ipm
- 1 x USB 2.0 - 4 pin USB Type B
- WPA-PSK, WPA2-PSK, WEP
- Operating System Support
- Windows 11, Windows 10, Windows 8.1, MS Windows 7 SP1, macOS 10.12.6 - macOS 13, iOS, Android, Windows 10 Mobile
- Software Included
- Drivers & Utilities, Canon Easy-PhotoPrint Editor, Canon Print Service Plug-in for Android
- Voltage Required
- 19 Watt
- Power Consumption Standby
- 1.7 Watt
- Direct Printing Specifications
- PictBridge
- First Copy Out Time Colour
- 20 sec
- Consumables Included
- 1 x ink cartridge (black) - Canon PG-560 , 1 x ink cartridge (colour) - Canon CL-561
- Limited warranty - 2 years
- 40.3 cm
- 31.5 cm
- 14.8 cm
- 6.3 kg
- Sound Emission
- 43.5 dBA (idle)
- 15 °C
- 30 °C
- 10 - 80% RH (non-condensing)
Canon PG- 560/CL-561 Black & Colour Standard Ink Cartridge | In Stock | £30.78 |
