Canon PIXMA TS5350i Multifunction Printer
Quicklinx: HYZRWS00 Mfr#: 4462C088
Type: Printer / copier / scanner
Functionality: Copier, Printer, Scanner
Max Paper Size: 215.9 x 676 mm
46 In Stock
£70.48 ex VAT
£84.57 inc VAT
The Canon PIXMA TS5350i is a versatile all-in-one printer that combines high-quality printing, scanning, and copying functionalities into one compact device. Designed to meet the needs of both home and office environments, it offers a range of connectivity options including Wi-Fi, AirPrint, and Google Cloud Print, allowing for easy printing from smartphones, tablets, and computers. With support for various media types and sizes, this printer is ideal for creating everything from detailed documents to stunning borderless photos. The inclusion of automatic duplexing further enhances its efficiency, providing an environmentally friendly solution to double-sided printing. Whether you're printing high-resolution images or scanning and copying documents, the Canon PIXMA TS5350i delivers performance and convenience in one sleek package.
  • Style credentials
    An ultra-cool 2-tone color scheme and a chic minimalist design with LED status bar give this printer some solid style points.
  • There's an app for that
    Print, scan, copy and connect to Facebook, Instagram and other cloud accounts from your smartphone using the Canon PRINT app, or print with AirPrint (iOS) and Mopria (Android).
  • Make it your own
    Transform your next project with Easy-PhotoPrint Editor, Creative Park and Message In Print and try out restickable, double-sided matte and iron-on transfer media.
  • Shareworthy snaps
    Get picture-perfect photos with up to 100 years of album life thanks to the ChromaLife100 ink system.
Canon PIXMA TS5350i - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Max Printing Speed
Up to 13 ipm (mono) / up to 6.8 ipm (colour)
Max Printing Resolution
4800 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Display
1.44"
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Media Size
55 x 89 mm (min) - 215.9 x 676 mm (max)
Media Type
Plain paper, high resolution paper, photo paper pro platinum, glossy paper, luster paper, semi-gloss paper, matte paper, envelopes, restickable photo paper, magnetic photo paper, iron-on transfers
Standard Media Capacity
200 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
PIXMA Cloud Link, access point mode
AC 120/230 V (50/60Hz)
40.3 cm x 31.5 cm x 14.8 cm
6.3 kg
Enclosure Colour
Printing Technology
Ink-jet - colour
Display Diagonal Size
1.44"
Display Features
OLED display
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Enclosure Colour
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, fit to page, two-sided copy, photo copy
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Ink Type
Canon ChromaLife100
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Grayscale Depth
8-bit
Colour Depth
8-bit
Colour Depth (Internal)
16-bit
Document & Media Handling
Max Original Size
Supported Original Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm)
Original Type
Sheets
Min Media Size
55 x 89 mm
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 200 x 250 mm, 130 x 180 mm, 100 x 150 mm, 130 x 130 mm, 89 x 89 mm, 55 x 89 mm, 215.9 x 676 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 200 x 250 mm, 130 x 180 mm, 100 x 150 mm, 130 x 130 mm, 89 x 89 mm
200 sheets
Input tray - 100 sheets size: 55 x 89 mm - 215.9 x 676 mm weight: 64 g/m² - 300 g/m² , Paper cassette - 100 sheets size: 148 x 210 mm - 215.9 x 297 mm weight: 64 g/m² - 105 g/m²
Speed Details
Printing: up to 13 ipm - B/W , Printing: up to 6.8 ipm - colour , Printing: 43 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 4 ipm
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WPA-PSK, WPA2-PSK, WEP
Operating System Support
Windows 11, Windows 10, Windows 8.1, MS Windows 7 SP1, macOS 10.12.6 - macOS 13, iOS, Android, Windows 10 Mobile
Software Included
Drivers & Utilities, Canon Easy-PhotoPrint Editor, Canon Print Service Plug-in for Android
19 Watt
Power Consumption Standby
1.7 Watt
Direct Printing Specifications
PictBridge
First Copy Out Time Colour
20 sec
Consumables Included
1 x ink cartridge (black) - Canon PG-560 , 1 x ink cartridge (colour) - Canon CL-561
40.3 cm
31.5 cm
14.8 cm
6.3 kg
Sound Emission
43.5 dBA (idle)
15 °C
30 °C
10 - 80% RH (non-condensing)
HYZR Canon PG- 560/CL-561 Black & Colour Standard Ink Cartridge In Stock £31.99
Functionality: Printer
Functionality: Scanner
Brand: Canon
