Canon PIXMA TS5150 Ink-jet (colour) 4800 x 1200 1 x USB 2.0 4 pin
Quicklinx: G2MNWS00 Mfr#: 2228C008
Type: Printer / copier / scanner
Functionality: Copier, Printer, Scanner
Output Type: Colour
Wireless Capability: Wireless, Wired
Technology: Ink-jet
£62.03 ex VAT
£74.43 inc VAT
Affordable, connected home all-in-one for simple wireless color printing, copying and scanning from mobile devices.
Fun, affordable and user friendly, this compact, stylish family printer takes all the hassle out of creating beautiful images and documents at home - with smart wireless connectivity to your devices, social networks and cloud storage services. Enjoy control from different angles using the manual tilt panel with colour screen and simple to use button navigation.
  • Simple affordable family printing with smart connectivity
    Fun, affordable and easy, this small, stylish family all-in-one takes all the hassle out of printing, scanning and copying beautiful images and sharp documents at home with smart wireless connectivity to your devices and the cloud.
  • Versatile and cost effective
    Print more pages for your money using and save on paper with auto 2-sided printing. Dual paper feeds handle both photo and paper media.
Canon PIXMA TS5150 - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Max Printing Speed
Up to 13 ipm (mono) / up to 6.8 ipm (colour)
Max Printing Resolution
4800 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Display
2.5"
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper, glossy paper, matte paper, high resolution paper, luster paper, semi-gloss paper
Standard Media Capacity
120 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n), Bluetooth LE
AirPrint Enabled
Office Machine Features
PIXMA Cloud Link, access point mode
AC 120/230 V (50/60Hz)
42.5 cm x 31.5 cm x 14.7 cm
6.5 kg
Enclosure Colour
2 Years
Printing Technology
Ink-jet - colour
Display Diagonal Size
2.5"
Display Colour Support
AirPrint Enabled
Enclosure Colour
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, 4 on 1, fit to page, ID Card Copy, Frame Erase Copy, Borderless copy
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Automatic Duplexing
Colour Management Features
Mopria
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Grayscale Depth
8-bit
Colour Depth
8-bit
Colour Depth (Internal)
16-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 130 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 130 mm
120 sheets
Input tray - 20 sheets size: 100 x 150 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 300 g/m² , Paper cassette - 100 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 105 g/m²
Speed Details
Printing: up to 13 ipm - B/W , Printing: up to 6.8 ipm - colour , Printing: 43 sec (10 x 15 cm (4"x6")) - photo , Scanning: 14 sec (A4) - colour
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows 7 SP1, Android, iOS, Windows 8.1, Windows 10, Windows 10 Mobile, macOS 10.12, Apple Mac OS X 10.10.5 - 10.11
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Canon Full HD Movie Print, Canon My Image Garden, Quick Menu, MP Driver including Scanning Utility
14 Watt
Power Consumption Standby
1.5 Watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x ink cartridge (yellow/cyan/magenta) , 1 x ink cartridge (black)
42.5 cm
31.5 cm
14.7 cm
6.5 kg
15 °C
30 °C
10 - 80% (non-condensing)
2 Years
Functionality: Printer
Functionality: Scanner
Output Type: Colour
Wireless Capability: Wired
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: Canon
