Affordable, connected home all-in-one for simple wireless color printing, copying and scanning from mobile devices.
Fun, affordable and user friendly, this compact, stylish family printer takes all the hassle out of creating beautiful images and documents at home - with smart wireless connectivity to your devices, social networks and cloud storage services. Enjoy control from different angles using the manual tilt panel with colour screen and simple to use button navigation.
Simple affordable family printing with smart connectivity
Fun, affordable and easy, this small, stylish family all-in-one takes all the hassle out of printing, scanning and copying beautiful images and sharp documents at home with smart wireless connectivity to your devices and the cloud. -
Versatile and cost effective
Print more pages for your money using and save on paper with auto 2-sided printing. Dual paper feeds handle both photo and paper media.
- Canon PIXMA TS5150 - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
- Max Printing Speed
- Up to 13 ipm (mono) / up to 6.8 ipm (colour)
- Max Printing Resolution
- 4800 x 1200 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Display
- 2.5"
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper, glossy paper, matte paper, high resolution paper, luster paper, semi-gloss paper
- Standard Media Capacity
- 120 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n), Bluetooth LE
- AirPrint Enabled
- Office Machine Features
- PIXMA Cloud Link, access point mode
- Power
- AC 120/230 V (50/60Hz)
- 42.5 cm x 31.5 cm x 14.7 cm
- 6.5 kg
- Enclosure Colour
- Black
- 2 Years
- Ink-jet - colour
- Display Diagonal Size
- 2.5"
- Display Colour Support
- Interface
- AirPrint Enabled
- Enclosure Colour
- Black
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1, fit to page, ID Card Copy, Frame Erase Copy, Borderless copy
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Colour Management Features
- Mopria
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 8-bit
- Colour Depth (Internal)
- 16-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 130 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 130 mm
- 120 sheets
- Input tray - 20 sheets size: 100 x 150 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 300 g/m² , Paper cassette - 100 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 105 g/m²
- Speed Details
- Printing: up to 13 ipm - B/W , Printing: up to 6.8 ipm - colour , Printing: 43 sec (10 x 15 cm (4"x6")) - photo , Scanning: 14 sec (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type B
- WEP, WPA-PSK, WPA2-PSK
- Operating System Support
- MS Windows 7 SP1, Android, iOS, Windows 8.1, Windows 10, Windows 10 Mobile, macOS 10.12, Apple Mac OS X 10.10.5 - 10.11
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX, Canon Full HD Movie Print, Canon My Image Garden, Quick Menu, MP Driver including Scanning Utility
- Voltage Required
- 14 Watt
- Power Consumption Standby
- 1.5 Watt
- Direct Printing Specifications
- PictBridge
- Consumables Included
- 1 x ink cartridge (yellow/cyan/magenta) , 1 x ink cartridge (black)
- 42.5 cm
- 31.5 cm
- 14.7 cm
- 6.5 kg
- 15 °C
- 30 °C
- 10 - 80% (non-condensing)
- 2 Years
Canon PG-540/CL-541 Black and Colour Value Pack | In Stock | £31.38 |
Canon CL541 Cyan Magenta Yellow Standard Capacity Ink Cartridge | In Stock | £16.56 |
Canon PG540L Black Standard Capacity Ink Cartridge 11ml | In Stock | £16.87 |
Canon CL541XL Cyan Magenta Yellow High Capacity Ink Cartridge | In Stock | £19.39 |
