Product
Canon PIXMA TS5050 Colour Inkjet Multifunction Printer
Quicklinx: CDLCWS00 Mfr#: 1367C008
Type: Printer / copier / scanner
Functionality: Copier, Printer, Scanner
Technology: Ink-jet
More than 50 in stock
£75.25 ex VAT
£90.30 inc VAT
High-quality colour printing from the comfort of your own home, with scan and copy functions, Wi-Fi, cloud connectivity and an easy-to-use 7.5 cm (3") LCD display - all contained within a compact, space-saving body.
The photo printer you've been looking for:
Print beautiful photographs and crisp text - over USB cable, Wi-Fi or directly from your SD cards. Canon's FINE inkjet print technology and 5 single inks bring convenience, cost savings and great-looking prints.
Perfectly proportioned:
Experience a lean, space-saving form factor 40% smaller than previous equivalent models. Clever contrasting textures, rounded corners and tapering contours make the printer's already-small frame appear even smaller. A superb printer inside and out - and an elegant addition to any desk or home office.
Print wirelessly:
Built-in Wi-Fi means you can print from your smartphone, tablet or computer via support for Mopria™ for Android, Apple AirPrint™, Google Cloud Print™, Windows 10 Mobile™ and the Canon PRINT app. Print your photos directly from Wi-Fi-enabled cameras, or using the built-in SD card slot.
So easy to use:
Every function is within easy reach with the manually adjustable front panel, 7.5 cm (3") LCD display and simple interface. The clear, simple buttons mean quick access to the printer's primary functions, whether printing, copying or scanning.
Access cloud services:
Using PIXMA Cloud Link, accessed through the Canon PRINT app on your smartphone or tablet, you can print from popular social network and cloud services including Facebook, Instagram, Google Drive, Dropbox, OneDrive and many more. You can even upload scanned documents and photos to Google Drive, OneDrive and Dropbox.
Economical printing:
Running costs won't break the bank, thanks to the optional high-capacity Canon XL ink cartridges, letting you save as much as 30% per page compared to standard equivalents. The 5 single ink cartridges mean you'll only need to replace the colour that has run out.
Unleash your creativity:
Get inspired with CREATIVE PARK and CREATIVE PARK PREMIUM*. Design and print greeting cards, calendars, photo collages and stunning 3D paper craft animals, toys and landmark buildings.
Square paper support:
Add new life to your social network snaps - access Instagram via PIXMA Cloud Link then print your favourite shots using Canon's 13x13 cm (5"x5") Photo Paper Plus Glossy II square media.
This model has replaced the PIXMA MG5750
Canon PIXMA TS5050 - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 5-ink
Max Copying Speed
6 ppm (colour)
Max Printing Speed
Up to 12.6 ipm (mono) / up to 9 ipm (colour)
Max Printing Resolution
4800 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Display
3"
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper, glossy photo paper, matte photo paper, high resolution paper, luster paper, semi-gloss photo paper
Standard Media Capacity
100 sheets
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
PIXMA Cloud Link, access point mode
AC 120/230 V (50/60Hz)
37.2 cm x 31.5 cm x 12.6 cm
5.5 kg
Enclosure Colour
Printing Technology
Ink-jet - colour
Display Diagonal Size
3"
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Enclosure Colour
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
6 ppm (colour)
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, fit to page, Borderless copy
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
5 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, pigment black
5-ink
Ink Type
Canon ChromaLife100
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 130 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 130 mm
100 sheets
Input tray - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 300 g/m²
Speed Details
Printing: up to 12.6 ipm - B/W , Printing: up to 9 ipm - colour , Printing: 39 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 6 ipm - colour , Scanning: 19 sec (A4) - colour
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK, Wi-Fi Direct
Operating System Support
MS Windows 7, MS Windows Vista SP2, MS Windows 7 SP1, Windows 8, Windows RT, Android, iOS, Windows 8.1, Windows 10, Windows 10 Mobile, Apple Mac OS X 10.8.5 - 10.11
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Canon Full HD Movie Print, Canon My Image Garden, Quick Menu, MP Driver including Scanning Utility
12 Watt
Power Consumption Standby
1.6 Watt
Direct Printing Specifications
PictBridge
First Copy Out Time Colour
20 sec
Consumables Included
1 x ink tank (pigmented black) , 1 x ink tank (black) , 1 x ink tank (cyan) , 1 x ink tank (magenta) , 1 x ink tank (yellow)
37.2 cm
31.5 cm
12.6 cm
5.5 kg
Sound Emission
44.5 dBA (operating)
15 °C
30 °C
10 - 80% (non-condensing)
Functionality: Printer
Functionality: Scanner
Technology: Ink-jet
Brand: Canon
Price Range Ex VAT: 50 - 100
