Canon PIXMA TS3750i Multifunction Printer
Quicklinx: HYZQWS00 Mfr#: 6671C008
Type: Printer / copier / scanner
Functionality: Printer, Copier, Scanner
Max Paper Size: 215.9 x 676 mm
More than 50 In Stock
£39.16 ex VAT
£46.99 inc VAT
Marketing description is not available.
  • Efficient connectivity
    The Canon PIXMA TS3750i features multiple connectivity options including USB 2.0 and Wi-Fi, enabling easy access to printers from different devices while supporting various mobile printing technologies.
  • Impressive print quality
    With a maximum resolution of 4800 x 1200 DPI, this printer delivers vibrant color and sharp detail in every print, suitable for both text and high-quality photos.
  • User-friendly display
    An easy-to-use 1.5-inch LCD display guides users through operations, making it straightforward to manage print jobs and access settings quickly.
  • Versatile media handling
    Designed to handle various media types, the printer supports plain and photo paper, including borderless printing options, making it ideal for creative projects.
  • Eco-conscious operation
    The Canon PIXMA TS3750i operates with an eco-friendly mindset, consuming just 9 watts during printing while offering efficient capabilities to minimize energy use.
Canon PIXMA TS3750i - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Max Printing Speed
Up to 7.7 ipm (mono) / up to 4 ipm (colour)
Max Printing Resolution
4800 x 1200 dpi (colour)
Scanning
600 x 1200 dpi
Display
1.5"
Original Size
Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Media Size
88.9 x 127 mm (min) - 215.9 x 676 mm (max)
Media Type
Plain paper, glossy photo paper, magnetic photo paper, restickable photo paper, coloured paper
Standard Media Capacity
60 sheets
Connection Availability
Wi-Fi(n), USB 2.0
AirPrint Enabled
Office Machine Features
Auto power on/off, access point mode, borderless printing
AC 100-240 V (50/60Hz)
43.5 cm x 32.7 cm x 14.5 cm
4 kg
Enclosure Colour
Printing Technology
Ink-jet - colour
Display Diagonal Size
1.5"
Display Colour Support
Monochrome
Display Features
LCD display
Wi-Fi(n), USB 2.0
AirPrint Enabled
Enclosure Colour
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
20
Copying Features
Borderless copy, document copy, fit to page
Printing
Inkjet Technology
Nozzle Configuration
1280 nozzles
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Scanning
Scan Element
CIS
Optical Resolution
600 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
8-bit
Colour Depth (Internal)
16-bit
Scanning Resolution Details
600 x 1200 dpi - flatbed
Document & Media Handling
Max Original Size
Supported Original Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm)
Original Type
Sheets
Min Media Size
88.9 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
275 g/m²
Supported Media Type
Supported Media Sizes
101.6 x 152.4 mm, 127 x 127 mm, 127 x 177.8 mm, ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm)
Borderless Photo Sizes
101.6 x 152.4 mm
60 sheets
Input tray - 60 sheets size: 88.9 x 127 mm - 215.9 x 676 mm weight: 64 g/m² - 275 g/m²
Speed Details
Printing: up to 7.7 ipm - B/W , Printing: up to 4 ipm - colour , Printing: 65 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 3 ipm
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WPA-PSK, WPA2-PSK, WPA3-SAE, AES
Operating System Support
Windows 11, Windows 10, Windows 8.1, MS Windows 7 SP1, Apple mac OS 10.15.67 - 14, iOS, iPadOS, Android, Chrome OS
Software Included
Drivers & Utilities, Canon Easy-PhotoPrint Editor
9 Watt
Power Consumption Standby
1.3 Watt
Direct Printing Specifications
PictBridge
First Copy Out Time B/W
27 sec
First Copy Out Time Colour
27 sec
Photo Paper Sample Pack (3 sheets)
Consumables Included
1 x ink cartridge (black) - Canon PG-575 , 1 x ink cartridge (colour) - Canon CL-576
Works With Chromebook (WWCB) certified
43.5 cm
32.7 cm
14.5 cm
4 kg
Shipping Width
49 cm
Shipping Depth
40 cm
Shipping Height
20 cm
Shipping Weight
5.2 kg
Sound Emission
48 dBA (operating)
5 °C
35 °C
10 - 90% RH
Functionality: Copier
Functionality: Scanner
Brand: Canon
