Print, copy and scan with the entry-level multifunction printer for home and office. It's super-simple to set up and use, and allows smartphone printing for extra versatility.
The PIXMA TS3450 is a compact and easy-to-use printer, scanner and copier. It’s simple to set up, with wireless connection at the touch of a button. Control it remotely with the latest technology: you can copy, scan or print from smartphone and tablet using the Canon PRINT app, or print app-free with AirPrint (iOS) and Mopria (Android). Access Point Mode allows you to connect your device directly to the printer without the need for an internet connection or router. Keep your documents crisp and images bright with FINE cartridges, and get creative with the Easy-PhotoPrint Editor app and Canon Creative Park. This all-in-one inkjet printer is an ideal first printer, with essential features at an affordable price.
Smart simplicity
With a compact, modern design and excellent value, you can print, scan and copy effortlessly. It's so easy! -
Compatible with your tech
You can print, copy and scan from your tablet or smartphone, with wireless compatibility and clean, simple interface. -
Super-simple setup
You'll be up and running in less time than ever with one-touch wireless connectivity and an easier setup procedure. -
Seeing is believing
Status updates are shown in plain sight on the crystal-clear 1.5" mono segment LCD screen.
- Canon PIXMA TS3450 - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
- Max Printing Speed
- Up to 7.7 ipm (mono) / up to 4 ipm (colour)
- Max Printing Resolution
- 4800 x 1200 dpi (colour)
- Scanning
- 600 x 1200 dpi
- Display
- 1.5"
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- 89 x 127 mm (min) - 215.9 x 676 mm (max)
- Media Type
- Plain paper, glossy photo paper, magnetic photo paper, restickable photo paper
- Standard Media Capacity
- 60 sheets
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- PIXMA Cloud Link, access point mode
- Power
- AC 120/230 V (50/60Hz)
- 43.5 cm x 32.7 cm x 14.5 cm
- 4 kg
- Enclosure Colour
- Black
- 2 Years
- Ink-jet - colour
- Display Diagonal Size
- 1.5"
- Display Colour Support
- Monochrome
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Enclosure Colour
- Black
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 20
- Copying Features
- Fit to page, Borderless copy
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 8-bit
- Colour Depth (Internal)
- 16-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Supported Original Sizes
- 216 x 297 mm
- Original Type
- Sheets
- Min Media Size
- 89 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 275 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 89 x 127 mm, 130 x 130 mm, 215.9 x 676 mm
- Borderless Photo Sizes
- 100 x 150 mm, 130 x 180 mm, 130 x 130 mm
- 60 sheets
- Input tray - 60 sheets size: 89 x 127 mm - 215.9 x 676 mm weight: 64 g/m² - 275 g/m²
- Speed Details
- Printing: up to 7.7 ipm - B/W , Printing: up to 4 ipm - colour , Printing: 65 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 3 ipm
- 1 x USB 2.0 - 4 pin USB Type B
- WEP, WPA-PSK, WPA2-PSK
- Operating System Support
- MS Windows 7 SP1, Android, iOS, Windows 8.1, Windows 10, Chrome OS, iPadOS, macOS 10.12.6 - macOS 10.15
- Software Included
- Drivers & Utilities, MP Driver including Scanning Utility, Canon Easy-PhotoPrint Editor
- Voltage Required
- 9 Watt
- Power Consumption Standby
- 0.8 Watt
- Direct Printing Specifications
- PictBridge
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (colour)
- 43.5 cm
- 32.7 cm
- 14.5 cm
- 4 kg
- Sound Emission
- 48 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80% (non-condensing)
- 2 Years
Canon CL546XL Colour High Yield Inkjet Cartridge | In Stock | £16.70 |
Canon PG545 Black Ink Cartridge | In Stock | £11.11 |
Canon PG545/CL546 Black & Colour Ink Multipack | In Stock | £23.32 |
Canon PG545XL Black High Yield Inkjet Cartridge | In Stock | £15.52 |
Canon PG545XL/CL546XL Photo Value Pack 2-Pack | In Stock | £30.93 |
Canon PG-545/CL-546 MULTI PACK SEC | In Stock | £22.76 |
