An easy, affordable printer with smart connectivity
Enjoy crisp text and vivid, borderless photo printing, straight from your Smart device, Wi-Fi camera, with this affordable PIXMA printer. Scan and copy with ease, using the intuitive 3.8 cm LCD display. -
Smart device printing, scanning and copying
Print from anywhere with convenient wireless printing, using the Canon PRINT app, AirPrint and Mopria. -
Stylish, durable design
With a surface that's fingerprint and scratch resistant, this printer is practical and easy to maintain. -
Cost-effective XL cartridges
Use high-capacity Canon XL ink cartridges and save up to 30% per page, compared to standard equivalents. -
Easy-to-use LCD screen and buttons
Connect to your smart device, check your settings and troubleshoot with the easy-to-use 3.8 cm LCD screen. -
Borderless photo printing
Create vivid borderless photos up to 5x7" thanks to dye-based ink cartridges.
- Canon PIXMA TS3150 - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering)
- Max Copying Speed
- 3 ppm (colour)
- Max Printing Speed
- Up to 7.7 ppm (mono) / up to 4 ppm (colour)
- Max Printing Resolution
- 4800 x 1200 dpi (colour)
- Scanning
- 600 x 1200 dpi
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper, glossy photo paper
- Standard Media Capacity
- 60 sheets
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- PIXMA Cloud Link, access point mode
- Power
- AC 120/230 V (50/60Hz)
- 43.5 cm x 31.6 cm x 14.5 cm
- 3.9 kg
- Ink-jet - colour
- Display Colour Support
- Monochrome
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
Copying
- Max Copying Speed
- 3 ppm (colour)
- Maximum Copies
- 20
- Copying Features
- Borderless copy
Printing
- Inkjet Technology
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 x 1200 dpi
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 275 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 130 x 130 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- 60 sheets
- Input tray - 60 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Speed Details
- Printing: up to 7.7 ppm - B/W , Printing: up to 4 ppm - colour , Printing: 65 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 4 ppm - colour , Scanning: 15 sec
- 1 x USB 2.0 - 4 pin USB Type B
- WEP, WPA-PSK, WPA2-PSK
- Operating System Support
- MS Windows 7 SP1, Windows 8.1, Windows 10, macOS 10.12, Apple Mac OS X 10.10.5 - 10.11
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX, Canon Full HD Movie Print, Canon My Image Garden, Quick Menu, MP Driver including Scanning Utility
- Voltage Required
- 11 Watt
- Power Consumption Standby
- 1.7 Watt
- Direct Printing Specifications
- PictBridge
- 43.5 cm
- 31.6 cm
- 14.5 cm
- 3.9 kg
- Sound Emission
- 46 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80% (non-condensing)
