Canon PIXMA TR4650 Wireless Colour All-in-One Inkjet
Quicklinx: GV46WS00 Mfr#: 5072C008
Smart, compact, easy-to-use: the perfect all-rounder for those working from home.
Compact, versatile, and easy to set up and use, this multifunctional printer can copy, scan and fax multiple page documents with the 20-Sheet ADF1. With high productivity and seamless wireless connectivity, it's a perfect fit for any home working environment.
Smart to connect, simple to use
Wi-Fi connectivity and the Canon PRINT app give you control of your printer functions from your smart devices, allowing you to print, scan and copy with ease.
Easy to set up, smart design
Set up with ease using the smartphone app or on the web. Smart, user-friendly features include easy ink cartridge replacements, improved paper loading and a document removal reminder.
Save paper, save time
Enhance efficiency with automatic 2-sided printing and a 20-sheet ADF2 for copying and scanning multiple page documents.
Quality printing for home and office
Pigment black ink ensures sharp text while dye colour inks produce vivid colours in both documents and photos, for a crisp professional finish and photos you can treasure.
Helping the environment
To reduce impact on the environment there is less plastic packaging producing approximately a 65% reduction in plastic waste.3
  1. Scanning straight to cloud and scanning to email are only available for users of genuine Canon ink.
  2. A4/LTR/LGL sizes only
  3. Compared to previous models.
  4. A4/LTR/LGL sizes only
  • Smart, compact, easy-to-use: the perfect all-rounder for those working from home
    Compact, versatile, and easy to set up and use, this multifunctional printer can copy, scan and fax multiple page documents with the 20-Sheet ADF. With high productivity and seamless wireless connectivity, it's a perfect fit for any home working environment.
  • Smart to connect, simple to use
  • Easy to set up, smart design
  • Save paper, save time
  • Quality printing for home and office
    Pigment black ink ensures sharp text while dye color inks produce vivid colors in both documents and photos, for a crisp professional finish and photos you can treasure.
  • Helping the environment
Canon PIXMA TR4650 - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Monthly Duty Cycle (max)
1200 pages
Max Copying Speed
Up to 6.4 ppm (mono) / up to 2.7 ppm (colour)
Max Printing Speed
Up to 8.8 ipm (mono) / up to 4.4 ipm (colour)
Max Printing Resolution
4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi
Scanning
600 x 1200 dpi
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
20 sheets
Media Size
215.9 x 676 mm (max)
Media Type
Envelopes, plain paper, greeting cards, photo paper, glossy photo paper, matte photo paper, high resolution paper, luster paper, semi-gloss photo paper, magnetic photo paper, restickable photo paper
Standard Media Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Intelligent Assistant
Google Assistant, Alexa
Office Machine Features
PIXMA Cloud Link
AC 120/230 V (50/60Hz)
43.5 cm x 29.5 cm x 18.9 cm
5.8 kg
2 Years
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
1200 pages
Display Colour Support
Monochrome
Display Features
LCD display
USB 2.0, Wi-Fi(n)
AirPrint Enabled
PIXMA Cloud Link
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, 4 on 1, fit to page, ID Card Copy, Frame Erase Copy, collation copy
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Automatic Duplexing
First Print Out Time B/W
11 sec
First Print Out Time Colour
19 sec
Scanning
Scan Element
CIS
Optical Resolution
600 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
8-bit
Colour Depth (Internal)
16-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 50 pages
Fax Machine Features
Speed Dialing
20 station(s)
Document & Media Handling
Max Original Size
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
Original Type
Sheets
20 sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 101.6 x 152.4 mm, 200 x 250 mm, 215.9 x 676 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
100 sheets
Input tray - 100 sheets size: 101.6 x 152.4 mm - 215.9 x 676 mm weight: 64 g/m² - 300 g/m² , ADF - 20 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 8.8 ipm - B/W , Printing: up to 4.4 ipm - colour , Printing: 65 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 2.7 ipm - colour , Copying: up to 6.4 ipm - B/W
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows 7 SP1, Android, iOS, Windows 8.1, Windows 10, Chrome OS, iPadOS, macOS Big Sur, macOS 10.13.6 - macOS 10.15
Software Included
Drivers & Utilities, Canon Creative Park, Canon Easy-PhotoPrint Editor, IJ Printer Assistant Tool
7 Watt
Power Consumption Standby
1.4 Watt
Internet of Things (IoT)
Phone cable
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (colour)
43.5 cm
29.5 cm
18.9 cm
5.8 kg
Sound Emission
56.5 dBA (operating)
5 °C
35 °C
10 - 90% (non-condensing)
2 Years
GV46 Canon CL546XL Colour High Yield Inkjet Cartridge In Stock £17.29
GV46 Canon PG545XL Black High Yield Inkjet Cartridge In Stock £17.82
