Take your business on the road. Light and portable with versatile wireless connectivity and smartphone control, get effortless and professional results wherever your work takes you.
Print on the go, wherever you are
Portable and tough for printing on the move. Take control with wireless printing from a PC, laptop or smart device and print text or borderless photos up to A4. -
Travel light with a portable printer
Sleek, light and robust, it's ideal for a business on the move. Tight on space? All cables and connections are fixed to one side for space-saving efficiency. -
Look sharp with superb quality
Get crisp prints with superb quality in darker areas. Hybrid ink with a dedicated pigment ink creates sharp text while dye-based colors give vivid prints.
- Canon PIXMA TR150 - printer - colour - ink-jet
- Printer Type
- Photo printer - ink-jet - colour
- Form Factor
- Portable
- 2.3 kg
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering)
- Ink Palette Supported (Colours)
- 5-ink - cyan, magenta, yellow, black, pigment black
- Media Size Class
- A4/Legal
- Max Media Size
- 215.9 x 676 mm
- Min Media Size (Custom)
- 55 mm x 89 mm
- Max Media Size (Custom)
- 215.9 mm x 676 mm
- Print Speed
- Up to 9 ipm - B/W , Up to 5.5 ipm - colour
- Max Resolution (Colour)
- 4800 x 1200 dpi
- Interface
- USB 2.0, Wi-Fi(n)
- Intelligent Assistant
- Google Assistant, Alexa
- AirPrint Enabled
- Media Type
- Envelopes, plain paper, photo paper, photo stickers, magnetic photo paper, glossy paper, matte paper
- Total Media Capacity
- 50 sheets
- Media Handling
- 50-sheet input tray
- Networking
- Print server
- Printer Features
- Borderless printing
- Power
- AC 120/230 V
- Battery
- Lithium Ion
- System Requirements
- Android, Microsoft Windows 7 SP1, Microsoft Windows Server 2008 R2 SP1, Apple iOS, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016, Windows 10 Mobile, Apple MacOS X 10.11.6, Microsoft Windows Server 2019, Apple macOS 10.12 - 10.15
- 32.2 cm x 21 cm x 6.6 cm
- 2-year Limited Warranty
- Printer Type
Printer
- Inkjet Technology
- Ink Type
- Canon ChromaLife100
- Print Speed
- Built-in Devices
- 1.44 inch (3.6 cm) monochrome OLED display
- Connectivity Technology
- Wireless
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- 4800 x 1200 dpi
- Direct Printing Specifications
- PictBridge
- Printer Features
- Media Handling
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 215.9 x 676 mm
- 55 mm x 89 mm
- 215.9 mm x 676 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 55 x 91 mm, 101.6 x 152.4 mm, 127 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm, 215.9 x 676 mm, 55 x 89 mm, 89 x 89 mm, 177.8 x 254 mm
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 101.6 x 152.4 mm, 88.9 x 88.9 mm, 127 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm, 177.8 x 254 mm
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- Media Weight
- 64 g/m² - 275 g/m²
- 50 sheets
- Media Feeders
- Input tray: 1 - 50 sheets - 215.9 x 676 mm weight: 64 g/m² - 275 g/m²
- Networking
- Print server
- WEP, WPA-PSK, WPA2-PSK
- Connections
- 1 x USB 2.0 - 24 pin USB-C
- Included Accessories
- Battery
- Cables Included
- 1 x USB-C cable
- Consumables Included
- 1 x ink tank (pigmented black) - Canon PGI-35 , 1 x ink tank (yellow/cyan/magenta/black) - Canon CLI-36 , 1 x printhead
- PIXMA Cloud Link
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V
- Frequency Required
- 50/60 Hz
- 8 Watt
- Power Consumption Stand by
- 1.7 Watt
- Lithium Ion
- Capacity
- 2170 mAh
- Run Time (Up To)
- 330 pages
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Compatible Services
- IFTTT
- Software Included
- Drivers & Utilities, Canon Easy-PhotoPrint Editor, Canon IJ Printer Assistant Tool
- OS Required
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
- Sound Emission (Operating)
- 40.5 dBA
- 32.2 cm
- 21 cm
- 6.6 cm
- 2.3 kg
Canon PGI 35 Black - Ink tank - 1 x pigmented black | In Stock | £7.33 |
Canon CLI-36 Colour Ink Tank (Black/Cyan/Magenta/Yellow) | In Stock | £11.34 |
