Canon PIXMA TR150 Colour Inkjet Printer with Battery
Quicklinx: FRZQWS00 Mfr#: 4167C028
Select:
  • inc battery
Take your business on the road. Light and portable with versatile wireless connectivity and smartphone control, get effortless and professional results wherever your work takes you.
  • Print on the go, wherever you are
    Portable and tough for printing on the move. Take control with wireless printing from a PC, laptop or smart device and print text or borderless photos up to A4.
  • Travel light with a portable printer
    Sleek, light and robust, it's ideal for a business on the move. Tight on space? All cables and connections are fixed to one side for space-saving efficiency.
  • Look sharp with superb quality
    Get crisp prints with superb quality in darker areas. Hybrid ink with a dedicated pigment ink creates sharp text while dye-based colors give vivid prints.
Canon PIXMA TR150 - printer - colour - ink-jet
Printer Type
Photo printer - ink-jet - colour
Portable
2.3 kg
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering)
Ink Palette Supported (Colours)
5-ink - cyan, magenta, yellow, black, pigment black
Media Size Class
A4/Legal
Max Media Size
215.9 x 676 mm
Min Media Size (Custom)
55 mm x 89 mm
Max Media Size (Custom)
215.9 mm x 676 mm
Print Speed
Up to 9 ipm - B/W , Up to 5.5 ipm - colour
Max Resolution (Colour)
4800 x 1200 dpi
USB 2.0, Wi-Fi(n)
Intelligent Assistant
Google Assistant, Alexa
AirPrint Enabled
Media Type
Envelopes, plain paper, photo paper, photo stickers, magnetic photo paper, glossy paper, matte paper
Total Media Capacity
50 sheets
Media Handling
50-sheet input tray
Print server
Printer Features
Borderless printing
AC 120/230 V
Lithium Ion
Android, Microsoft Windows 7 SP1, Microsoft Windows Server 2008 R2 SP1, Apple iOS, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016, Windows 10 Mobile, Apple MacOS X 10.11.6, Microsoft Windows Server 2019, Apple macOS 10.12 - 10.15
32.2 cm x 21 cm x 6.6 cm
2-year Limited Warranty
Printer Type
Printer
Inkjet Technology
Ink Type
Canon ChromaLife100
Print Speed
Built-in Devices
1.44 inch (3.6 cm) monochrome OLED display
Wireless
USB 2.0, Wi-Fi(n)
AirPrint Enabled
4800 x 1200 dpi
Direct Printing Specifications
PictBridge
Printer Features
Borderless printing
Media Handling
50-sheet input tray
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
215.9 x 676 mm
55 mm x 89 mm
215.9 mm x 676 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 55 x 91 mm, 101.6 x 152.4 mm, 127 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm, 215.9 x 676 mm, 55 x 89 mm, 89 x 89 mm, 177.8 x 254 mm
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 101.6 x 152.4 mm, 88.9 x 88.9 mm, 127 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm, 177.8 x 254 mm
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Media Weight
64 g/m² - 275 g/m²
50 sheets
Media Feeders
Input tray: 1 - 50 sheets - 215.9 x 676 mm weight: 64 g/m² - 275 g/m²
Print server
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
1 x USB 2.0 - 24 pin USB-C
1 x USB-C cable
Consumables Included
1 x ink tank (pigmented black) - Canon PGI-35 , 1 x ink tank (yellow/cyan/magenta/black) - Canon CLI-36 , 1 x printhead
PIXMA Cloud Link
Power adapter
AC 120/230 V
Frequency Required
50/60 Hz
8 Watt
Power Consumption Stand by
1.7 Watt
Lithium Ion
2170 mAh
Run Time (Up To)
330 pages
Internet of Things (IoT)
Compatible Services
IFTTT
Software Included
Drivers & Utilities, Canon Easy-PhotoPrint Editor, Canon IJ Printer Assistant Tool
5 °C
35 °C
10 - 90% (non-condensing)
Sound Emission (Operating)
40.5 dBA
32.2 cm
21 cm
6.6 cm
2.3 kg
FRZQ Canon PGI 35 Black - Ink tank - 1 x pigmented black In Stock £7.52
FRZQ Canon CLI-36 Colour Ink Tank (Black/Cyan/Magenta/Yellow) In Stock £11.87
