This highly accurate, 10-ink pigment based printer produces gallery-quality prints you’ll be proud to display or sell. Full cloud connectivity offers easy integration with your favorite professional editing and storage apps.
Professional color and mono prints
PIXMA PRO-10S's 10-ink pigment based system produces accurate, stable and long lasting, gallery-quality prints. Three dedicated monochrome inks also ensure your black and white prints are beautifully reproduced. -
Accurate, long-lasting gallery-quality prints
PIXMA PRO-10S uses LUCIA inks which combines the glossiness and vivid colors of dye-based ink with the longevity of pigment ink. Chroma Optimizer ink enhances glossiness, flattens the print surface and expands color range. -
Print from popular cloud services
Print photos directly from your preferred cloud storage services including Facebook, Dropbox, Google Drive and OneDrive using PIXMA Cloud Link. -
Easy integration with professional editing software
Take the hassle out of finding the correct print settings by using Canon's Print Studio Pro plugin, which is compatible with Adobe Photoshop and Lightroom - so you can print straight from your professional editing software. -
Easy CD printing
Print labels directly onto compatible CDs using Direct Disc Print to create a professional look for your media.
- Canon PIXMA PRO-10S - printer - colour - ink-jet
- Printer Type
- Photo printer - ink-jet - colour
- 20 kg
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering)
- Ink Palette Supported (Colours)
- 10-ink - cyan, magenta, yellow, photo black, matte black, grey, photo cyan, photo magenta, red, chroma optimiser
- Max Media Size
- A3 plus (329 x 423 mm), 360 x 430 mm
- Max Media Size (Custom)
- 360 mm x 430 mm
- Print Speed
- Up to 3.58 min/page - photo - A3 plus (329 x 423 mm)
- Max Resolution (Colour)
- 4800 x 2400 dpi
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Media Type
- Plain paper, photo paper, photo stickers, glossy photo paper, fine art paper, matt photo paper, canvas paper, luster photo paper, DVD discs, CD discs, BD discs, semi-gloss photo paper
- Total Media Capacity
- 150 sheets
- Media Handling
- 150-sheet input tray, CD/DVD tray, 1-sheet manual tray
- Networking
- Print server
- Printer Features
- Borderless printing, Chroma Optimizer Technology, fit-to-page, Direct Disc Printing
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Microsoft Windows 7 SP1, Windows 8, Apple MacOS X 10.7.5 or later, Microsoft Windows XP (32-bit) SP3, Windows 8.1
- Microsoft Certification
- Compatible with Windows 7
- 68.9 cm x 38.5 cm x 21.5 cm
- Printer Type
Printer
- Inkjet Technology
- Minimum Ink Droplet Size
- 4 pl
- Ink Cartridge Configuration
- 10 individual ink tanks
- Ink Type
- Canon LUCIA pigment ink
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 4800 x 2400 dpi
- Direct Printing Specifications
- PictBridge, Canon Direct Print
- Printer Features
- Media Handling
Media Handling
- Media Type
- Max Media Size
- 360 mm x 430 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), 100 x 150 mm, A3 plus (329 x 423 mm), 130 x 180 mm, CD (120 mm), 200 x 250 mm, 250 x 300 mm, 360 x 430 mm
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), 100 x 150 mm, A3 plus (329 x 423 mm), 130 x 180 mm, 200 x 250 mm, 250 x 300 mm, 360 x 430 mm
- Media Weight
- 64 g/m² - 350 g/m²
- 150 sheets
- Media Feeders
- 1 x automatic - 150 sheets - A3 plus (329 x 423 mm) weight: 64 g/m² - 300 g/m² , 1 x automatic - 1 sheet - 360 x 430 mm 350 g/m² , 1 x automatic - CD (120 mm)
- Networking
- Print server
- WEP, WPA-PSK, WPA2-PSK
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x printhead , 1 x ink tank (photo black) , 1 x ink tank (matte black) , 1 x ink tank (grey) , 1 x ink tank (cyan) , 1 x ink tank (magenta) , 1 x ink tank (yellow) , 1 x ink tank (photo cyan) , 1 x ink tank (photo magenta) , 1 x ink tank (red) , 1 x ink tank (chroma optimiser)
- PIXMA Cloud Link
- Power Device
- Power supply
- Voltage Required
- AC 120/230 V
- Frequency Required
- 50/60 Hz
- 18 Watt
- Power Consumption Stand by
- 2.7 Watt
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX, Full HD Movie Print, Canon Color Management Tool Pro, Canon PrintStudioPro, Canon My Image Garden
- OS Required
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
- Sound Emission (Operating)
- 33.9 dBA
- 68.9 cm
- 38.5 cm
- 21.5 cm
- 20 kg
