This professional A3+ printer boasts an 8-ink dye based system for gallery-quality prints you'll be proud to display or sell, plus Wi-Fi and full cloud connectivity for easy integration with existing workflows.
- Canon PIXMA PRO-100S - printer - colour - ink-jet
- Printer Type
- Photo printer - ink-jet - colour
- 19.7 kg
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering)
- Ink Palette Supported (Colours)
- 8-ink - cyan, magenta, yellow, photo cyan, photo magenta, light grey, black, grey
- Max Media Size
- A3 plus (329 x 423 mm), 360 x 430 mm
- Max Media Size (Custom)
- 360 mm x 430 mm
- Print Speed
- Up to 0.57 min/page - photo - 101.6 x 152.4 mm , Up to 1.5 min/page - photo - A3 plus (329 x 423 mm)
- Max Resolution (Colour)
- 4800 x 2400 dpi
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Media Type
- Envelopes, plain paper, photo paper, photo stickers, glossy photo paper, fine art paper, matt photo paper, canvas paper, luster photo paper, DVD discs, CD discs, BD discs, semi-gloss photo paper
- Total Media Capacity
- 150 sheets
- Media Handling
- 150-sheet input tray, CD/DVD tray, 1-sheet manual tray
- Networking
- Print server
- Printer Features
- Borderless printing, fit-to-page, Direct Disc Printing
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Android, Microsoft Windows 7 SP1, Windows 8, Apple iOS, Apple MacOS X 10.7.5 or later, Microsoft Windows XP (32-bit) SP3, Windows 8.1
- Microsoft Certification
- Compatible with Windows 7
- 68.9 cm x 38.5 cm x 21.5 cm
- 2 Years
- Printer Type
Printer
- Inkjet Technology
- Minimum Ink Droplet Size
- 3 pl
- Ink Cartridge Configuration
- 8 individual ink tanks
- Ink Type
- Canon ChromaLife100+
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 4800 x 2400 dpi
- Direct Printing Specifications
- PictBridge, Canon Direct Print
- Printer Features
- Media Handling
Media Handling
- Media Type
- Max Media Size
- 360 mm x 430 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), 100 x 150 mm, A3 plus (329 x 423 mm), 130 x 180 mm, CD (120 mm), 200 x 250 mm, 250 x 300 mm, 360 x 430 mm
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), 100 x 150 mm, A3 plus (329 x 423 mm), 130 x 180 mm, 200 x 250 mm, 250 x 300 mm, 360 x 430 mm
- Media Weight
- 64 g/m² - 350 g/m²
- 150 sheets
- Media Feeders
- 1 x automatic - 150 sheets - A3 plus (329 x 423 mm) weight: 64 g/m² - 300 g/m² , 1 x automatic - 1 sheet - 360 x 430 mm 350 g/m² , 1 x automatic - CD (120 mm)
- Networking
- Print server
- WEP, WPA-PSK, WPA2-PSK
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x printhead , 1 x ink tank (black) , 1 x ink tank (grey) , 1 x ink tank (light grey) , 1 x ink tank (cyan) , 1 x ink tank (magenta) , 1 x ink tank (yellow) , 1 x ink tank (photo cyan) , 1 x ink tank (photo magenta)
- PIXMA Cloud Link
- Power Device
- Power supply
- Voltage Required
- AC 120/230 V
- Frequency Required
- 50/60 Hz
- 19 Watt
- Power Consumption Stand by
- 2.6 Watt
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX, Full HD Movie Print, Canon Color Management Tool Pro, Canon PrintStudioPro, Canon My Image Garden
- OS Required
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
- Sound Emission (Operating)
- 38.5 dBA
- 68.9 cm
- 38.5 cm
- 21.5 cm
- 19.7 kg
Service and Support
- 2 Years
Ink (8)
Canon CLI-42 Multipack (8 Colour) Ink Tank | In Stock | £79.11 |
Canon CLI-42 Photo Black Ink Cartridge | In Stock | £11.44 |
Canon CLI-42 Grey Ink Cartridge | In Stock | £11.47 |
Canon CLI-42 Yellow Ink Cartridge | In Stock | £10.88 |
Canon CLI-42 Photo Magenta Ink Cartridge | In Stock | £10.87 |
Canon CLI-42 Photo Cyan Ink Cartridge | In Stock | £10.87 |
Canon CLI-42 Cyan Ink Cartridge | In Stock | £10.88 |
Canon CLI-42 Magenta Ink Cartridge | In Stock | £11.90 |
Other bundles (1)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.04 |
