Canon PIXMA Pro-10 Colour Inkjet Printer
Quicklinx: 8PFNWS00 Mfr#: 6227B008AA
Produce gallery-quality, saleable prints come with this 10-ink A3+ photo printer. It offers outstanding professional prints in color and monochrome, versatile media support and enhanced connectivity.
The PIXMA PRO-10 has three dedicated monochrome inks, allowing you to create beautiful black and white photos with smooth tonal gradations. The matte black and photo black inks are always available to print, ensuring you don't waste ink by changing photo paper from glossy to matte. PIXMA PRO-10 has a FINE technology print head with 4 pl ink droplets, delivering up to 4800 dpi print resolution for highly detailed, grain-free photos. You can print bordered A3+ gallery-quality color or a black and white print in less than four minutes.
  • Gallery-quality photos
    With the 10-ink system PIXMA PRO-10 can produce outstanding, professional prints in a range of sizes from 10 x 15 cm up to A3+ or even 14" wide. It is the ideal choice for the photographer looking to create exhibition prints or sell gallery-quality photos.
  • Professional color
    The LUCIA pigment-based inks provide powerful and inspirational results with amazing consistency and exceptional image permanence. The 10-ink system can reproduce a wide color gamut, adding to the vibrancy and detail of images.
  • Striking black and white prints
  • Uniform glossiness
    The Chroma Optimizer clear ink is used on the printed areas of glossy and semi-gloss papers enhancing the density of blacks, expanding color gamut and delivering photo prints with the ultimate uniform gloss finish.
  • Quality and speed
  • Efficient workflow
    The Print Studio Pro plug-in makes the workflow of professional printing easy and efficient. This print plug-in for major photo applications brings all print settings into one simple to navigate menu.
  • Connectivity
    With Wi-Fi and Ethernet connectivity you can locate the printer anywhere - perfect for the home-based photographer or small studio. Print photos directly from smartphones and tablets using Canon's Easy-PhotoPrint or Apple AirPrint.
Canon PIXMA PRO-10 - printer - colour - ink-jet
Printer Type
Photo printer - ink-jet - colour
20 kg
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering)
Ink Palette Supported (Colours)
10-ink - cyan, magenta, yellow, photo black, matte black, grey, photo cyan, photo magenta, red
Max Media Size
A3 plus (329 x 423 mm), 360 x 430 mm
Max Media Size (Custom)
360 mm x 430 mm
Print Speed
Up to 3.58 min/page - photo - A3 plus (329 x 423 mm)
Max Resolution (Colour)
4800 x 2400 dpi
USB, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Media Type
Plain paper, photo paper, photo stickers, glossy photo paper, fine art paper, matt photo paper, luster photo paper, semi-gloss photo paper
Total Media Capacity
150 sheets
Media Handling
150-sheet input tray, CD/DVD tray, 1-sheet manual tray
Print server - Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Printer Features
Borderless printing, fit-to-page
Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Microsoft Windows 7 (32/64 bits), Microsoft Windows Vista (64-bit versions) SP2, Microsoft Windows Vista (32-bit versions) SP2, Apple MacOS X 10.5.8 - 10.8
Microsoft Certification
Compatible with Windows 7
68.9 cm x 38.5 cm x 21.5 cm
Printer Type
Printer
Inkjet Technology
Minimum Ink Droplet Size
4 pl
Ink Cartridge Configuration
10 individual ink tanks
Ink Type
Canon LUCIA pigment ink
Print Speed
Wireless
AirPrint Enabled
4800 x 2400 dpi
Direct Printing Specifications
PictBridge, Canon Direct Print
Printer Features
Media Handling
Media Handling
Media Type
Max Media Size
360 mm x 430 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), 100 x 150 mm, A3 plus (329 x 423 mm), 130 x 180 mm, 200 x 250 mm, 250 x 300 mm, 360 x 430 mm
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), 100 x 150 mm, A3 plus (329 x 423 mm), 130 x 180 mm, 200 x 250 mm, 250 x 300 mm, 360 x 430 mm
Media Weight
64 g/m² - 350 g/m²
150 sheets
Media Feeders
1 x automatic - 150 sheets - A3 plus (329 x 423 mm) weight: 64 g/m² - 300 g/m² , 1 x manual - 1 sheet - 360 x 430 mm 350 g/m² , 1 x automatic - CD (120 mm)
Print server
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
1 x USB 2.0 - 4 pin USB Type B , 1 x direct print port - 4 pin USB Type A , 1 x LAN - RJ-45
Power supply - internal
Frequency Required
50/60 Hz
17 Watt
Power Consumption Stand by / Sleep
2.3 Watt
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Full HD Movie Print, Canon Color Management Tool Pro, Canon PrintStudioPro, Canon My Image Garden
System Requirements Details
Windows 7 - 1 GHz - RAM 1 GB , Windows 7 64-bit Edition - 1 GHz - RAM 2 GB , Windows Vista - 1 GHz - RAM 512 MB , Windows XP SP3 - 300 MHz - RAM 128 MB , MacOS X 10.7 - Core 2 Duo RAM 1 GB , MacOS X 10.6 - RAM 1 GB , MacOS X 10.5.8 - RAM 512 MB
5 °C
35 °C
10 - 90% (non-condensing)
Sound Emission (Operating)
33.9 dBA
68.9 cm
38.5 cm
21.5 cm
20 kg
8PFN Canon MP101 Matte Photo Paper 50 Sheets In Stock £11.46
