Canon PIXMA MX895 - multifunction printer - colour
Quicklinx: 800MWS00 Mfr#: 5786B008AA
Quality, speed and functionality in one powerful, Cloud-ready All-In-One
PIXMA MX895 enjoys prints of the highest quality with this all-in-one. With network, Wi-Fi, this device also offers double sided prints, copies, faxes and scan capabilities.
Ideal for the home or office
Everyone can share in the productivity this stylish black, network-ready All-In-One delivers. Wi-Fi and Ethernet connectivity enable printing, scanning, copying and faxing from virtually anywhere in the home or office. Apple AirPrint support allows you to print directly from iPad and iPhone.
High-speed document handling
The fully integrated, 35-sheet Duplex Automatic Document Feeder (DADF) automatically scans, copies or faxes large double-sided documents. Scan and save to `compact PDF' is ideal for storing or emailing.
High quality, fast performance
Canon's FINE technology, with minimum 1pl ink droplets, delivers up to 9600dpi print resolution for amazingly detailed colour photos and images. Enjoy print speeds of 12.5 ipm mono or 9.3 ipm colour. A photolab-quality 10x15 cm borderless photo is printed in approximately 20 seconds, while an A4 page copies in just 14 seconds. Quick Start means this All-In-One is ready to go seconds after switching on.
Easy to work with
A large 7.5cm colour TFT display makes it easy to view selected functions and preview images. The Dual Function Panel features LED-lit dual purpose keys. These keys change appearance according to the mode selected, reducing the number of physical keys on the product.
Economical, single ink tanks
For greater economy, the PIXMA MX895 has 5 single ink tanks. When a colour runs out, only this single tank needs replacing.
Cloud-ready
PIXMA Cloud Link enables you to browse and print your favourite photos directly to the printer from online albums at CANON iMAGE GATEWAY and Google's Picasa. You can also access on demand calendars, stationery and other templates without a PC or print from virtually anywhere using Google Cloud Print.[1]
Go green and save
See how much paper and CO2 you save using the Auto Duplex Print feature that automatically prints both sides of the paper.
PC-free scanning
Using the USB and memory card port on the front, documents can be saved directly without the need to connect to a PC.
[1] Google Cloud Print available from April 2012 onwards
  • Ideal for the home or office
    Everyone can share in the productivity this stylish black, network-ready all-in-one delivers. Wi-Fi and Ethernet connectivity enable printing, scanning, copying and faxing from virtually anywhere in the home or office.
  • High-speed document handling
    The fully integrated, 35-sheet Duplex Automatic Document Feeder (DADF) automatically scans, copies or faxes large double-sided documents. Scan and save to 'compact PDF' is ideal for storing or emailing.
  • High quality, fast performance
    Canon's FINE technology, with minimum 1 pl ink droplets, delivers up to 9600 dpi print resolution for amazingly detailed color photos and images. Quick Start means this all-in-one is ready to go seconds after switching on.
  • Easy to work with
    A large 7.5 cm color TFT display makes it easy to view selected functions and preview images. The dual function panel features LED-lit dual purpose keys. These keys change appearance according to the mode selected, reducing the number of physical keys on the product.
  • Economical, single ink tanks
    For great economy, the PIXMA MX895 has 5 single ink tanks. When a color runs out, only this single tank needs replacing.
  • Go green and save
    See how much paper and CO2 you save using the auto duplex print feature that automatically prints both sides of the paper.
  • PC-free scanning
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 5-ink
Max Copying Speed
7 ppm (colour)
Max Printing Speed
Up to 12.5 ipm (mono) / up to 9.3 ipm (colour)
Max Printing Resolution
Up to 9600 x 2400 dpi (mono) / up to 9600 x 2400 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JPEG
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi
Scanning
2400 x 4800 dpi
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
300 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
Office Machine Features
Print from USB flash drive, save to USB flash drive, Auto Photo Fix II, PIXMA Cloud Link
AC 110/230 V (50/60Hz)
49.1 cm x 44.8 cm x 21.8 cm
11.7 kg
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour - photo
Supported Flash Memory
Memory Stick, CompactFlash, SD Memory Card, MultiMediaCard, Memory Stick PRO, Memory Stick Duo, USB flash drive, IBM Microdrive, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card
Copying
Max Copying Speed
7 ppm (colour)
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
2 on 1, BorderFree, 4 on 1, Frame Erase Copy, collation copy
Printing
Inkjet Technology
Max Printing Speed
5-ink
Minimum Ink Droplet Size
1 pl
Ink Type
Canon ChromaLife100+
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
2400 x 4800 dpi
Grayscale Depth
16-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JPEG
Fax Resolutions
Total Memory Capacity
Up to 250 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
100 station(s)
Telephone / Fax Switch
Broadcast Transmission
Activity report, colour faxing, remote reception, Dual Access
Document & Media Handling
Max Original Size
Original Type
Sheets
35 sheets
Max Media Size
Legal
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
300 sheets
ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 150 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 300 g/m² , Paper cassette - 150 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 105 g/m²
Speed Details
Printing: up to 12.5 ipm - B/W , Printing: up to 9.3 ipm - colour , Copying: up to 7 ipm - colour , Printing: 20 sec (10 x 15 cm (4"x6")) - photo
1 x USB 2.0 , 1 x USB host , 1 x LAN
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), MS Windows XP SP2, MS Windows 7 SP1, Apple Mac OS X 10.5.8 - 10.7
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Fax Speed Dial Utility, Canon Easy-PhotoPrint EX, Canon MP Navigator EX, Auto Photo Fix II, Canon Full HD Movie Print, Canon Solution Menu EX
23 Watt
Power Consumption Standby
2 Watt
Direct Printing Specifications
PictBridge
First Copy Out Time Colour
14 sec
49.1 cm
44.8 cm
21.8 cm
11.7 kg
Sound Emission
45.5 dBA (operating)
5 °C
35 °C
10 - 90% (non-condensing)
800M Canon PGI 525PGBK Black Ink Tank In Stock £12.17
800M Canon Original ChromaLife 100+ Cyan Ink Tank CLI-526C In Stock £10.83
800M Canon Original ChromaLife 100+ Magenta Ink Tank CLI-526M In Stock £10.83
800M Canon Original ChromaLife 100+ Yellow Ink Tank CLI-526Y In Stock £10.33
800M Canon CLI-526 Original ChromaLife 100+ Black Ink Tank In Stock £10.31
