Canon PIXMA MX7600 - multifunction ( fax / copier / printer / scanner ) ( colour )
Customer rating: 4.0* (Write a review)
Quicklinx: 4ZJVWS00 Mfr#: 2437B008AA
Revolutionary 'clear-ink' technology delivers professional quality printing on plain paper. This flagship Office All-In-One offers your business fax, duplex print, copy scan functionality.
Canon PIXMA MX7600 - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 6-ink
Max Copying Speed
Up to 28 ppm (mono) / up to 23 ppm (colour)
Max Printing Speed
Max Printing Resolution
4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JPEG
Fax Resolutions
200 x 200 dpi
Scanning
4800 x 9600 dpi
Original Size
216 x 356 mm (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
216 x 356 mm (max)
Media Type
Envelopes, plain paper, cards, labels, photo paper
Standard Media Capacity
170 sheets
Bypass Feeder Capacity
20 sheets
Automatic Duplexing
Yes (copying)
Connection Availability
USB 2.0, LAN
AC 110/230 V (50/60Hz)
50 cm x 53.5 cm x 25.7 cm
16.6 kg
Microsoft Certification
Certified for Windows Vista
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour - photo
USB 2.0, LAN
Supported Flash Memory
Memory Stick, CompactFlash, SD Memory Card, MultiMediaCard, Memory Stick PRO, IBM Microdrive, SDHC Memory Card
Copying
Max Copying Speed
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
2 on 1, BorderFree, 4 on 1
Printing
Inkjet Technology
Max Printing Speed
6-ink
Minimum Ink Droplet Size
2 pl
Scanning
Scan Element
CIS
Optical Resolution
4800 x 9600 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
16-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JPEG
Fax Resolutions
200 x 200 dpi
Total Memory Capacity
Up to 250 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
8 station(s)
Speed Dialing
100 station(s)
Telephone / Fax Switch
Automatic redialing, answering machine interface, colour faxing
Document & Media Handling
Max Original Size
216 x 356 mm
Original Type
Sheets
35 sheets
Max Media Size
Other
Min Media Weight
64 g/m²
Max Media Weight
273 g/m²
Supported Media Type
Borderless Photo Sizes
A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
170 sheets
20 sheets
Bypass tray - 20 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 105 g/m² , ADF - 30 sheets - 216 x 356 mm , Paper cassette - 150 sheets - 216 x 356 mm weight: 64 g/m² - 105 g/m²
Speed Details
Printing: up to 28 ppm - B/W fast , Printing: up to 11 ppm - B/W , Printing: up to 23 ppm - colour fast , Printing: up to 10 ppm - colour , Copying: up to 28 ppm - B/W , Copying: up to 23 ppm - colour , Printing: 43 sec (10 x 15 cm (4"x6")) - photo
1 x USB 2.0 , 1 x LAN
Operating System Support
MS Windows XP, MS Windows 2000, MS Windows Vista, Apple MacOS X 10.3.9 or later
Software Included
Drivers & Utilities, Presto! PageManager, ScanSoft OmniPage SE, Canon Easy-PhotoPrint EX, Canon MP Navigator EX
26 Watt
Power Consumption Standby
6.5 Watt
Power Consumption Sleep
1.6 Watt
Direct Printing Specifications
PictBridge, Canon Direct Print
Phone cable
Consumables Included
1 x ink cartridge (black) - up to 570 pages , 1 x ink cartridge (photo black) - up to 9015 pages , 1 x ink cartridge , 1 x ink cartridge (cyan) - up to 865 pages , 1 x ink cartridge (magenta) - up to 715 pages , 1 x ink cartridge (yellow) - up to 1075 pages
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
ENERGY STAR Certified
50 cm
53.5 cm
25.7 cm
16.6 kg
Sound Emission
33 dBA (operating)
5 °C
35 °C
10 - 90%
4ZJV Canon PGI-9C Cyan Ink Tank In Stock £10.84
4ZJV Canon PGI-9 Yellow Ink Cartridge In Stock £10.84
Customer reviews
Write a review for the Canon PIXMA MX7600 - multifunction ( fax / copier / printer / scanner ) ( colour ) here!
Good quality all in one
Reviewed by Stephen Hayes. Review Posted 01/07/2008
I bought this all-in-one in June 2008 and am really pleased with it. The quality for printing colour photos on glossy photo paper is excellent. It is great to print things double-sided, it saves paper and bulk, thought the MX7600 is a bit slow turning the paper over, thinking for a bit, then printing the second side. I've not used the fax. The scanner is very good. I can scan in some pages from a book, and print them out duplex, and there is hardly any loss of quality from the original book. Used as a photocopier, dead easy and good results. You can print photos on ordinary paper, the MX7600 sprays the paper to stop ink bleed, the result is better than normally printing on normal paper, but nothing like as good quality as on photo paper. With a multi-purpose machine, I was expecting scanner results not as good as a dedicated scanner, printer results ditto, but this was not the case.
  • Overall 4*
  • Ease of use 4*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
