Cloud enabled All-In-One with auto document feeder and Wi-Fi connectivity.
Easily print, copy, scan and fax with this cloud enabled All-In-One. Wi-Fi connection allow functions to be shared between multiple PCs as well as smart devices.
- Canon PIXMA MX535 - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
- Monthly Duty Cycle (max)
- 3000 impressions
- Max Copying Speed
- 4.7 ppm (colour)
- Max Printing Speed
- Up to 9.7 ipm (mono) / up to 5.5 ipm (colour)
- Max Printing Resolution
- 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 2400 dpi
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 30 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- PIXMA Cloud Link
- Power
- AC 120/230 V (50/60Hz)
- 45.8 cm x 38.5 cm x 20 cm
- 8.5 kg
- 2 Years
- Fax Type
- Plain paper
- Ink-jet - colour
- 3000 impressions
- Interface
- AirPrint Enabled
- PIXMA Cloud Link
Copying
- Max Copying Speed
- 4.7 ppm (colour)
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- BorderFree, fit to page
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, pigment black
- 4-ink
- Minimum Ink Droplet Size
- 2 pl
- Ink Type
- Canon ChromaLife100
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 50 pages
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 30 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
- 100 sheets
- ADF - 30 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) , Input tray - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Speed Details
- Printing: up to 9.7 ipm - B/W , Printing: up to 5.5 ipm - colour , Copying: up to 4.7 ipm - colour , Printing: 46 sec (10 x 15 cm (4"x6")) - photo
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB - 4 pin USB Type A
- WEP, WPA-PSK, WPA2-PSK
- Operating System Support
- MS Windows 7, MS Windows Vista SP1, MS Windows XP SP3, MS Windows Vista SP2, Apple Mac OS X 10.6.8 or later, Windows 8, Windows RT, Android, iOS, Windows 8.1
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX, Canon My Image Garden
- Voltage Required
- 18 Watt
- Power Consumption Standby
- 1.1 Watt
- First Copy Out Time Colour
- 24 sec
- Consumables Included
- 1 x ink cartridge (pigmented black) , 1 x ink cartridge (colour)
- 45.8 cm
- 38.5 cm
- 20 cm
- 8.5 kg
- Sound Emission
- 43 dBA (operating)
- 15 °C
- 30 °C
- 5 - 95% (non-condensing)
Service and Support
- 2 Years
