PIXMA MX435 with built-in Wi-Fi and ADF, this stylish All-in-One fits perfectly in the home office with it's quick print speeds. Compact design with FastFront.
The Wi-Fi All-In-One that handles everything with ease
Designed for anywhere
This compact All-In-One, with sleek all-black design and built in Wi-Fi connectivity, is perfectly placed to help you print, copy, scan and fax - from wherever suits you best.
High quality
Canon's FINE ink technology, with minimum 2pl ink droplets and print resolution up to 4800 x 1200 dpi, delivers glorious colours and crisp text - ideal for business documents or photos.
Productivity boosting 30-sheet ADF
Scanning, copying or faxing large documents is quick and easy for more productive working, thanks to a fully-integrated 30-sheet Automatic Document Feeder. The scan and save to a compact pdf feature is ideal for archiving. Additionally, you can scan-to-email for efficient workflow.
Faster performance
Enjoy print speeds of 9.7 ipm mono or 5.5 ipm colour. A 10x15 cm borderless photo is printed in approximately 46 seconds, while an A4 page copies in just 21 seconds. Quick Start means this All-In-One is ready to go seconds after switching on.
Value for money
For further savings you can print more for less, with the high yield Canon XL cartridges, which offer 50% lower cost per page.
Space-saving design and easy-to-use
The compact FastFront design means paper and ink cartridges can be loaded from the front of the printer - making it easier to fit into a busy work space. Quick Start functionality means there is no need to wait for the printer to `warm up'. Operation is almost instantaneous from the moment the power is switched on, ensuring that the user can perform actions virtually straight away.
Fast, cost-effective faxing
Super G3 faxing is fast and reliable. Incoming faxes can be saved as a PDF file to USB memory for viewing and keeping a digital record. You can also reduce costs as you can choose what to print.
Intelligent software
Take control of your web printing, easily combining content from several websites with Easy-WebPrint EX. Automatically optimising the quality and legibility of scanned documents is simple with Auto Document Fix. For additional security, MP Navigator EX adds passwords to PDFs restricting who can edit or print sensitive documents.
Remote printing from iPhone or iPad
Support for Apple AirPrint enables you to print directly to the PIXMA MX435/MX434 from a compatible mobile device.
This compact All-In-One, with sleek all-black design and built in Wi-Fi connectivity, is perfectly placed to help you print, copy, scan and fax - from wherever suits you best. -
High quality
Canon's FINE ink technology, with minimum 2pl ink droplets and print resolution up to 4800 x 1200 dpi, delivers glorious colors and crisp text - ideal for business documents or photos. -
Scanning, copying or faxing large documents is quick and easy for more productive working, thanks to a fully-integrated 30-sheet Automatic Document Feeder. The scan and save to a compact pdf feature is ideal for archiving. Additionally, you can scan-to-email for efficient workflow. -
Faster performance
Enjoy print speeds of 9.7 ipm mono or 5.5 ipm color. A 10x15 cm borderless photo is printed in approximately 46 seconds, while an A4 page copies in just 21 seconds. Quick Start means this All-In-One is ready to go seconds after switching on. -
Value for money
For further savings you can print more for less, with the high yield Canon XL cartridges, which offer 50% lower cost per page. -
The compact FastFront design means paper and ink cartridges can be loaded from the front of the printer - making it easier to fit into a busy work space. Quick Start functionality means there is no need to wait for the printer to 'warm up'. Operation is almost instantaneous from the moment the power is switched on, ensuring that the user can perform actions virtually straight away. -
Super G3 faxing is fast and reliable. Incoming faxes can be saved as a PDF file to USB memory for viewing and keeping a digital record. You can also reduce costs as you can choose what to print. -
Take control of your web printing, easily combining content from several websites with Easy-WebPrint EX. Automatically optimizing the quality and legibility of scanned documents is simple with Auto Document Fix. For additional security, MP Navigator EX adds passwords to PDFs restricting who can edit or print sensitive documents. -
- Canon PIXMA MX435 - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
- Max Copying Speed
- 4.3 ppm (colour)
- Max Printing Speed
- Up to 9.7 ipm (mono) / up to 5.5 ipm (colour)
- Max Printing Resolution
- 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JPEG
- Fax Resolutions
- 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 2400 dpi
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 30 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n), USB host
- Office Machine Features
- Save to USB flash drive
- Power
- AC 110/230 V (50/60Hz)
- 45.8 cm x 38.5 cm x 20 cm
- 8.5 kg
- Copier Type
- Digital
- Fax Type
- Plain paper
- Ink-jet - colour - photo
- Interface
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- 4.3 ppm (colour)
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, BorderFree, 4 on 1, fit to page, Preset Copy Ratios, Frame Erase Copy, collation copy
Printing
- Inkjet Technology
- 4-ink
- Minimum Ink Droplet Size
- 2 pl
- Ink Type
- Canon ChromaLife100
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JPEG
- Fax Resolutions
- Total Memory Capacity
- Up to 50 pages
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 20 station(s)
- Telephone / Fax Switch
- Activity report, automatic redialing, answering machine interface, group dialling, remote reception, Dual Access
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 30 sheets
- Max Media Size
- Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
- 100 sheets
- ADF - 30 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) , Input tray - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Speed Details
- Printing: up to 9.7 ipm - B/W , Printing: up to 5.5 ipm - colour , Copying: up to 4.3 ipm - colour , Printing: 46 sec (10 x 15 cm (4"x6")) - photo
- 1 x USB 2.0 , 1 x USB host
- WEP, WPA-PSK, WPA2-PSK
- Operating System Support
- MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), MS Windows XP SP2, Apple Mac OS X 10.5.8 - 10.7
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX, Fax Speed Dial Utility, Canon Easy-PhotoPrint EX, Canon MP Navigator EX, Canon Solution Menu EX
- Voltage Required
- 14 Watt
- Power Consumption Standby
- 1.6 Watt
- Power Consumption Sleep
- 0.4 Watt
- First Copy Out Time Colour
- 21 sec
- Consumables Included
- 1 x ink cartridge (black) - up to 180 pages - Canon PG-540 , 1 x ink cartridge (colour) - up to 180 pages - Canon CL-541
- 45.8 cm
- 38.5 cm
- 20 cm
- 8.5 kg
- Sound Emission
- 42.5 dB (operating)
- 5 °C
- 35 °C
- 10 - 90%
