Canon PIXMA MP270 - multifunction ( printer / copier / scanner ) ( colour )
Quicklinx: 64RXWS00 Mfr#: 3744B008AA
Affordable and versatile, the PIXMA MP270 combines high quality printing, scanning and copying. Ideal for document, web and photolab-quality printing, it's perfect for first-time users, students and families - particularly those who require the added versatility of camera direct printing.
Canon supports the industry-wide ISO standard for measuring print and copy speeds. This makes it easy to select the right PIXMA for you based on real document print speeds. The PIXMA MP270 offers ISO ESAT speeds of 8.4ipm for mono documents and 4.8ipm for color.
Compact and stylish, the PIXMA MP270 has a convenient self-opening paper tray that automatically opens to collect prints and copies.
  • Print, copy, scan
  • Realistic document print speeds
  • Photolab-quality
    Canon's patented FINE technology with 2pl size ink droplets delivers great print quality, with 4800 x 1200dpi resolution. Photos appear amazingly detailed and free from grain. While Canon's FINE cartridges use dye-based inks for perfect photo printing, an additional pigment ink ensures that text is crisp and sharp. The PIXMA MP270 combines quality with speed.
  • Efficient scanning
    Scan in detail using the 1200dpi scanner. Auto scan mode automatically senses what is being scanned - a photo or a document - before saving it using the most appropriate settings.
  • Print without a computer
    For camera owners, a PictBridge connection allows photos to be printed directly from compatible digital cameras, camera phones or camcorders.
  • Convenient self-opening paper tray
Canon PIXMA MP270 - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Max Printing Speed
Up to 8.4 ppm (mono) / up to 4.8 ppm (colour)
Max Printing Resolution
4800 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Original Size
A4 (210 x 297 mm), Letter A (216 x 279 mm) (max)
Media Size
216 x 356 mm (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
100 sheets
Connection Availability
USB 2.0, USB host
AC 110/230 V (50/60Hz)
45 cm x 33.5 cm x 15.5 cm
5.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Printing Technology
Ink-jet - colour - photo
USB 2.0, USB host
Copying
Maximum Copies
20
Copying Features
BorderFree, fit to page
Printing
Inkjet Technology
Max Printing Speed
4-ink
Minimum Ink Droplet Size
2 pl
Ink Type
Canon ChromaLife100+
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Document & Media Handling
Max Original Size
Max Media Size
Other
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
100 sheets
Input tray - 100 sheets
Speed Details
Printing: up to 8.4 ppm - B/W , Printing: up to 4.8 ppm - colour
1 x USB 2.0 , 1 x USB host
Operating System Support
MS Windows XP, MS Windows Vista, MS Windows 2000 Professional, Apple Mac OS X 10.3.9 - 10.5.x
Software Included
Drivers & Utilities, Canon Photo Optimizer Pro, Canon Easy-WebPrint EX, Canon Easy-PhotoPrint EX, Canon MP Navigator EX, Canon Vivid Photo
10 Watt
Power Consumption Standby
1.2 Watt
Power Consumption Sleep
0.5 Watt
Direct Printing Specifications
PictBridge, Canon Direct Print
Consumables Included
1 x ink tank (black) - up to 220 pages - Canon PG-510 , 1 x ink tank (colour) - up to 244 pages - Canon CL-511
ENERGY STAR Certified
45 cm
33.5 cm
15.5 cm
5.6 kg
Sound Emission
45 dB (operating)
5 °C
35 °C
10 - 90%
64RX Canon CL 511 - Print cartridge - 1 x colour (cyan, magenta, yellow) In Stock £15.24
64RX Canon PG 510 - Print cartridge - 1 x black In Stock £11.80
