Top of the range Wireless All-In-One printer with mini-photo lab functionality and Intelligent Touch System
The PIXMA MG8150 is a premium performance Wireless All-In-One printer offering superb photolab-quality greyscale and colour prints with easy to use Intelligent Touch System and 4800 x 4800dpi CCD scanner capable of 35mm film scanning. Whether printing, copying or scanning, you'll get the best possible results every time and it will integrate seamlessly into your home or office.
Intuitive operation with light-guided touch panel and stunning design
The PIXMA MG8150 features a brand new and unique Intelligent Touch System which makes operation as easy as possible. All controls are integrated into the lid of the printer, providing a larger operational panel and leaving your 8.8cm TFT display free to view images.
The controls are operated by touch rather than press, providing a fast response to your inputs. The clever bit, however, is the intuitive light guided operation. For example, if you select the photo print function, only the controls relating to that function will be illuminated, all other buttons remaining virtually invisible in the glossy black lid. At each subsequent step, only the controls which will assist your photo printing will be illuminated, guiding you through the process to print quickly and easily.
Your own darkroom in a sleek multi-functional machine
Such is the quality and power of the built in 4800 x 4800dpi White-LED CCD scanner, you can re-print photos from your 35mm film archives. Simply put your 35mm film negative onto the scanner and in a few moments print supremely high quality photos of your favourite memories. Normal documents and even 3D objects can also be scanned with the highest possible clarity.
Fast, photo-lab quality printing, with the 6 Single Ink System
Thanks to miniscule 1pl ink droplets from Canon's FINE print engine which delivers a maximum print resolution of 9600 x 2400dpi, the PIXMA MG8150 produces smooth, grain free images. Canon's High Performance 6 Single Ink System includes two blacks - one for printing crisp laser sharp text, the other for photos to give strong saturated blacks - and a unique grey, for superior monochrome printing.
Document print speeds are a useful 12.5 IPM* in black and white or 9.3 IPM* in colour. A high quality borderless 10x15cm photo-lab quality print is delivered in just 20 seconds. Two-way paper feeding means different types of paper can be loaded at the same time for convenient printing of documents or photos. You can even print directly onto a CD to help archive data or personalise your music collection for example. Plus, you can print your favourite moments without a computer, using the PictBridge connection to print straight from a device or USB flash memory for fast and convenient photos.
Efficient 6 Single Ink System and duplex printing for reduced waste
Thanks to six separate ink tanks, you only ever need to replace an ink cartridge when it runs out, reducing waste and optimising ink usage. Coupled with Duplex Printing which allows printing on both sides of paper, you can save money, reduce your paper consumption and help the environment in the process - all without compromising on print quality.
Capture your favourite home movie moments with Full HD Movie Print
Get the best of both worlds, producing high quality individual photos from your favourite HD home movie moments. Printing a photo using Full HD Movie Print couldn't be easier. Simply select a frame from your movie** using the intuitive Easy-PhotoPrint software and print. As you do this, frame enhancement technology will automatically analyse the frames either side, combining the best from each to ensure that lighting and resolution are as good as they can be in your final photo.
Print from anywhere in the home or connect to a network
The PIXMA MG8150 has a fast, 150 Mbps built in wireless connection, so multiple people can print to it, wherever they are in the house whenever they want - even if it is stored out of sight. You can also print photos and documents directly from your iPhone, iPod touch or iPad simply by downloading the Canon Easy-Photo Print App from the AppStore which links straight to the printer by Wi-Fi. Alternatively, if you have a PlayStation 3, you can even view and print your photos from your widescreen TV. Android devices can also remotely print via the Wi-Fi connection.
An Ethernet connection means that the MG8150 can be easily connected to a home or office network for everyone to share in the PIXMA quality.
Have fun with Creative Park Premium
Customers who purchase genuine Canon inks for their PIXMA MG8150 receive access to an exclusive area of the Creative Park website - Creative Park Premium. Here you can access premium artistic content such as professional photography and illustrations which would normally be right protected. This content can be used to create calendars, cards, booklets etc.
A world of advantages with Canon technology
Automatic correction to make every print perfect
Based on Canon's market-leading intelligent camera technology, Auto Photo Fix II will automatically analyse and correct your photos at the printer, removing any red-eye and making adjustments to compensate for the photographer, camera or lighting limitations. It will automatically recognise the lighting conditions when the photo was taken and will, for example, brighten faces that are backlit and under-exposed to ensure more accurate skin tones or remove any colour cast to give clear, true colour photos. The result? Perfect prints every time without the need for a computer.
Automatic enhancement for clear and crisp scanned documents
Intelligent auto-correction doesn't stop with your photos. Through Auto Document Fix technology, your printer enhances text, graphics and images in scanned documents making them clearer, more vivid and more impactful.
Printing made easy with FREE in-box software
Exclusive to Canon, Easy-PhotoPrint EX is the fast and easy way to re-touch your digital photos and print them in a choice of size and layouts either directly within the software or from Adobe® Photoshop® with the supplied Easy-PhotoPrint EX plug-in. The Correct and Enhance button adds advanced photo correction and enhancement using the same simple interface. The lab-quality re-touching features available include: red eye correction, smooth facial lines and skin tone, face brightener, face sharpener and blemish remover.
The intuitive on-screen display helps you choose to print your selection in whichever format you require from normal photos to calendars. The software also features a direct link to Flickr where you can search and download publicly available images to supplement your own. Through Easy-PhotoPrint you can access the Full HD Movie print function, enabling you to capture your favourite home movie moments on photo-lab quality stills.
Save paper with Easy-WebPrint software
FREE Easy-WebPrint EX software offers a range of options to help you organise the information you want to print from the internet and avoid wasting paper. These include:
- Auto Clipping: print only the area of a web page you want, not all the advertisements you don't
- Clip from Multiple pages: collect, combine and edit content from multiple web pages before printing
You can collate this information to create easy to print multiple page booklets, or reduce the size of the whole web page to fit it onto a single piece of paper.
Advanced operations at the click of a button with Solutions Menu EX
Solutions Menu EX provides easy access to the advanced features of your printer. The functions in each category are presented in easy to recognize pictorial icons and you can tailor your Desktop in order to quickly access the functions you want, when you want.
Beautiful, long-lasting photos
You can keep your precious photos bright and vibrant with the Canon ChromaLife100+ system. This unique combination of enhanced FINE print head technology and genuine Canon Chromalife 100+ inks with selected Canon photo papers lets you create beautiful photos that will last up to 300 years when stored in an archival-quality photo album.
To achieve exceptional print resolution, Canon Full-photolithography Inkjet Nozzle Engineering (FINE) uses a patented print head with high precision nozzles, ejecting ink droplets as small as 1 picolitre in size (the smaller the ink drop the better quality the image).
Compact and tidy
Both the Power cable and USB port are recessed inside the compact, stylish printer body so you can push the machine right back against the wall - saving space and keeping everything neat and tidy.
*Printing speeds explained:
Canon measures its printing speeds in IPM (Images Per Minute). IPM is a new ISO speed testing standard, approved by the International Standards Organisation in March 2009.
PPM (Page Per Minute), used by some manufacturers, is not a standard for inkjet printers. Every printer manufacturer has their own 'test pages' that are used to test speed and give vastly different results. The new ISO standard sets standardised 'test pages' that are to be used by any manufacturer measuring their speed in IPM, allowing comparable results across inkjet brands.
**Only compatible with Canon Digital Still Compact and Digital SLR cameras.
Box Contains
PIXMA MG8150 All-In-One
Power cord
Ink Cartridges (PGI-525PGBK, CLI-526BK, CLI-526C, CLI-526M, CLI-526Y, CLI-526GY);Multilingual set up guides
Set up software
User's manual CD
Warranty sheet
Exceptional print quality with speed
Canon's FINE technology, with 1pl ink droplets, delivers 9600 x 2400dpi print resolution for amazingly detailed color photos and grain-free monochrome images. A stunning 10 x 15cm photo is produced in approximately 20 seconds. -
Quick and easy navigation
For the ultimate user experience, Canon's intelligent touch system provides intuitive and easy to follow light guided touch panel operation integrated into the stylish PIXMA body surface with an 8.8cm TFT display. -
Full HD movie print
Capture memories by turning your Canon digital camera movie moments into beautiful prints with Canon's Full HD movie print. Simply play your movie using Canon's full HD movie print software, and pause to capture a frame or frames to print. -
Advanced media handling
With 2-way paper feeding, different paper types can be loaded at the same time and you can also print directly onto compatible DVDs, Blu-ray discs and CD-ROMs. An auto duplex feature makes it easy to print documents on both sides of the paper.
- Canon PIXMA MG8150 - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 6-ink
- Max Printing Speed
- Up to 12.5 ipm (mono) / up to 9.3 ipm (colour)
- Max Printing Resolution
- 9600 x 2400 dpi (colour)
- Scanning
- 4800 x 9600 dpi
- Display
- 3.5"
- Original Size
- A4 (210 x 297 mm), Letter A (216 x 279 mm) (max)
- Original Type
- Sheets
- Media Size
- 216 x 356 mm (max)
- Media Type
- Envelopes, plain paper, photo paper, printable CD/DVD disc
- Standard Media Capacity
- 300 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- LAN, Wi-Fi(n), USB host, USB 2.0
- Office Machine Features
- Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive
- Power
- AC 110/230 V (50/60Hz)
- 47 cm x 39.2 cm x 19.9 cm
- 10.7 kg
- Copier Type
- Digital
- Ink-jet - colour - photo
- Display Diagonal Size
- 3.5"
- Interface
- Supported Flash Memory
- Memory Stick, CompactFlash, SD Memory Card, MultiMediaCard, Memory Stick PRO, Memory Stick Duo, USB flash drive, IBM Microdrive, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, BorderFree, 4 on 1, fit to page, Frame Erase Copy
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 6 individual ink tanks
- 6-ink
- Minimum Ink Droplet Size
- 1 pl
- Ink Type
- Canon ChromaLife100+
Scanning
- Scan Element
- CCD
- Optical Resolution
- 4800 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, A4 Super (228.6 x 381 mm), 200 x 250 mm
- Borderless Photo Sizes
- 100 x 150 mm, 130 x 180 mm, A4 Super (228.6 x 381 mm), 200 x 250 mm
- 300 sheets
- 2 x input tray - 150 sheets , CD/DVD tray
- Speed Details
- Printing: up to 12.5 ipm - B/W , Printing: up to 9.3 ipm - colour , Printing: 20 sec (10 x 15 cm (4"x6")) - photo
- 1 x USB 2.0 , 1 x USB host , 1 x LAN
- WEP, WPA-PSK, WPA, WPA2
- Operating System Support
- MS Windows XP, MS Windows 7, Apple Mac OS X 10.4.11 - 10.6.x, MS Windows Vista
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX, Canon Easy-PhotoPrint EX, Canon MP Navigator EX, Auto Photo Fix II
- Voltage Required
- 24 Watt
- Power Consumption Standby
- 2 Watt
- Power Consumption Sleep
- 0.5 Watt
- Direct Printing Specifications
- PictBridge
- First Copy Out Time Colour
- 15 sec
- Consumables Included
- 1 x ink tank (pigmented black) - up to 328 pages - Canon PGI-525PGBK , 1 x ink tank (black) - up to 2185 pages - Canon CLI-526BK , 1 x ink tank (cyan) - up to 462 pages - Canon CLI-526C , 1 x ink tank (magenta) - up to 437 pages - Canon CLI-526M , 1 x ink tank (yellow) - up to 450 pages - Canon CLI-526Y , 1 x ink tank (grey) - up to 1515 pages - Canon CLI-526GY
- 47 cm
- 39.2 cm
- 19.9 cm
- 10.7 kg
- Sound Emission
- 46 dB (operating)
- 5 °C
- 35 °C
- 10 - 90%
Canon PGI 525PGBK Black Ink Tank | In Stock | £11.62 |
Canon Original ChromaLife 100+ Cyan Ink Tank CLI-526C | In Stock | £10.33 |
Canon Original ChromaLife 100+ Magenta Ink Tank CLI-526M | In Stock | £10.33 |
Canon Original ChromaLife 100+ Yellow Ink Tank CLI-526Y | In Stock | £10.33 |
Canon CLI-526 Original ChromaLife 100+ Black Ink Tank | In Stock | £10.31 |
Canon CLI-526 Cyan Ink Tank | In Stock | £10.33 |
Canon CLI-526 Magenta Ink Tank | In Stock | £10.33 |
