Canon Pixma MG6450 Inkjet Multifunction Printer
Quicklinx: 8YYJWS00 Mfr#: 8333B008
This high-performance all-in-one printer, in stylish glossy finish, boasts an advanced 5-ink system and offers fast, high quality print, copy, scan and cloud access functions. It is designed to be used and shared wirelessly around the home and remotely from mobile devices.
With built-in memory card reader and Wireless LAN PictBridge you can easily print photos directly from memory cards as well as compatible wireless cameras. You can also scan documents and photos to memory card. The large 7.5 cm display makes it easy to view selected functions and preview images.
  • High-performance all-in-one
  • Camera companion
  • Cloud printing
    Print directly from the Internet with enhanced PIXMA cloud link. Produce calendars, download stationery and other templates direct from the PIXMA cloud.
  • Superior prints with single inks
    With the 5 single inks system you only need to change the color that runs out - making printing more efficient. Dedicated document black and photo black inks plus Canon's FINE technology and up to 4800 dpi print resolution deliver sharp text and images with great levels of detail.
  • Fast printing
    Ideal for speedy, quality printing at home, it has a rapid A4 document print speed of 15.0 ipm mono/9.7 ipm color and produces a 10 x 15 cm borderless photo in approximately 44 seconds.
Canon PIXMA MG6450 - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 5-ink
Max Copying Speed
7.7 ppm (colour)
Max Printing Speed
Up to 15 ipm (mono) / up to 9.7 ipm (colour)
Max Printing Resolution
4800 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper, glossy photo paper, matte photo paper
Standard Media Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
PIXMA Cloud Link
AC 120/230 V (50/60Hz)
45.5 cm x 36.9 cm x 14.8 cm
6.4 kg
2 Years
Printing Technology
Ink-jet - colour
USB 2.0, Wi-Fi(n)
AirPrint Enabled
PIXMA Cloud Link
Supported Flash Memory
SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, SDHC Memory Card
Copying
Max Copying Speed
7.7 ppm (colour)
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, BorderFree, 4 on 1, fit to page, Frame Erase Copy
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
5 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, pigment black
5-ink
Minimum Ink Droplet Size
2 pl
Ink Type
Canon ChromaLife100+
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
100 sheets
Input tray - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 300 g/m²
Speed Details
Printing: up to 15 ipm - B/W , Printing: up to 9.7 ipm - colour , Printing: 44 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 7.7 ipm - colour
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows 7, MS Windows XP SP3, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, Windows RT, Android, iOS
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Canon Full HD Movie Print, Canon My Image Garden
13 Watt
Power Consumption Standby
1.3 Watt
Power Consumption Sleep
0.3 Watt
Direct Printing Specifications
PictBridge
First Copy Out Time Colour
18 sec
Consumables Included
1 x ink tank (pigmented black) - Canon PGI-550PGBK , 1 x ink tank (black) - Canon CLI-551BK , 1 x ink tank (cyan) - Canon CLI-551C , 1 x ink tank (magenta) - Canon CLI-551M , 1 x ink tank (yellow) - Canon CLI-551Y
45.5 cm
36.9 cm
14.8 cm
6.4 kg
Sound Emission
42.5 dB (operating)
5 °C
35 °C
10 - 90% (non-condensing)
Service and Support
2 Years
