A sleek, top quality and wireless enabled All-In-One for all your printing needs
The PIXMA MG5250 is an advanced, feature-rich All-In-One with Wi-Fi, Auto Duplex print and Direct Disc print. You'll get to the function you need more quickly with an intuitive interface and 6.0cm TFT display, and enjoy superior photo-lab quality printing as well as professional business documents, efficient scanning and clear copying. And the piano black finish provides a contemporary and sophisticated feel at home in any surroundings.
Fast, photo-lab quality in the home
Thanks to miniscule 1pl ink droplets from Canon's FINE print engine which deliver a maximum print resolution of 9600 x 2400dpi, the PIXMA MG5250 produces smooth, grain free images and the crispest text in next to no time. Document print speeds are a useful 11.0 IPM* in black and white or 9.3 IPM* in colour. A high quality borderless 10x15cm photo-lab quality print is delivered in just 20 seconds so you can instantly and conveniently share those special moments with family and friends. Two-way paper feeding means different types of paper can be loaded at the same time for convenient printing of documents or photos - the printer will know which to choose. You can even print directly onto a CD to help archive data or personalise your music collection for example.
Capture your favourite home movie moments with Full HD Movie Print
Get the best of both worlds, producing high quality individual photos from your favourite HD home movie moments. Printing a photo using Full HD Movie Print couldn't be easier. Simply select a frame from your movie using the intuitive Easy-PhotoPrint software and print. As you do this, frame enhancement technology will automatically analyse the frames either side, combining the best from each to ensure that lighting and resolution are as good as they can be in your final photo.
Efficient 5 Single Ink System and duplex printing reduce waste
Thanks to five separate ink tanks, you only ever need to replace an ink cartridge when it runs out, reducing waste and optimising ink usage. Coupled with Duplex Printing which allows printing on both sides of paper, you can save money, reduce your paper consumption and help the environment in the process - all without compromising on print quality.
Print from anywhere in the home from computer or Wi-Fi enabled device
The PIXMA MG5250 has a fast, 150 Mbps built in wireless connection, so multiple people can print to it, wherever they are in the house, whenever they want - even if it is stored out of sight. You can also print photos and documents directly from your iPhone, iPod touch or iPad simply by downloading the Canon Easy-Photo Print App from the AppStore which links straight to the printer by Wi-Fi. Alternatively, if you have a PlayStation 3, you can even view and print your photos from your widescreen TV. Android devices can also remotely print via the Wi-Fi connection.
Print direct from memory card or via PictBridge connection
There is no need for a computer to print your favourite moments. Simply insert your camera's memory card or print straight from device or USB flash memory for fast and convenient photos.
Have fun with Creative Park Premium
Customers who purchase Canon ink for their PIXMA MG5250 receive access to an exclusive area of the Creative Park website - Creative Park Premium. Here you can access premium artistic content such as professional photography and illustrations which would normally be right protected. This content can be used to create calendars, cards, booklets etc.
Simple and efficient scanning, whatever the document
High quality scanning is quick and easy using the 2400 x 4800dpi scanner with Auto Scan. It automatically recognises what is being scanned - a photo, business card or a document - before saving it using the most suitable settings. All you need to do is push the button.
A world of advantages with Canon technology
Automatic correction to make every print perfect
Based on Canon's market-leading intelligent camera technology, Auto Photo Fix II will automatically analyse and correct your photos at the printer, removing any red-eye and making adjustments to compensate for the photographer, camera or lighting limitations. It will automatically recognise the lighting conditions when the photo was taken and will, for example, brighten faces that are backlit and under-exposed to ensure more accurate skin tones or remove any colour cast to give clear, true colour photos. The result? Perfect prints every time without the need for a computer.
Automatic enhancement for clear and crisp scanned documents
Intelligent auto-correction doesn't stop with your photos. Through Auto Document Fix technology, your printer enhances text, graphics and images in scanned documents making them clearer, more vivid and more impactful.
Printing made easy with FREE in-box software
Exclusive to Canon, Easy-PhotoPrint EX is the fast and easy way to re-touch your digital photos and print them in a choice of size and layouts either directly within the software or from Adobe® Photoshop® with the supplied Easy-PhotoPrint EX plug-in. The Correct and Enhance button adds advanced photo correction and enhancement using the same simple interface. The lab-quality re-touching features available include: red eye correction, smooth facial lines and skin tone, face brightener, face sharpener and blemish remover.
The intuitive on-screen display helps you choose to print your selection in whichever format you require from normal photos to calendars. The software also features a direct link to Flickr where you can search and download publicly available images to supplement your own. Through Easy-PhotoPrint you can access the Full HD Movie print function, enabling you to capture your favourite home movie moments on photo-lab quality stills.
Save paper with Easy-WebPrint software
FREE Easy-WebPrint EX software offers a range of options to help you organise the information you want to print from the internet and avoid wasting paper. These include:
- Auto Clipping: print only the area of a web page you want, not all the advertisements you don't
- Clip from Multiple pages: collect, combine and edit content from multiple web pages before printing
You can collate this information to create easy to print multiple page booklets, or reduce the size of the whole web page to fit it onto a single piece of paper.
Advanced operations at the click of a button with Solutions Menu EX
Solutions Menu EX provides easy access to the advanced features of your printer. The functions in each category are presented in easy to recognize pictorial icons and you can tailor your Desktop in order to quickly access the functions you want, when you want.
Beautiful, long-lasting photos
You can keep your precious photos bright and vibrant with the Canon ChromaLife100+ system. This unique combination of enhanced FINE print head technology and genuine Canon Chromalife 100+ inks with selected Canon photo papers lets you create beautiful photos that will last up to 300 years when stored in an archival-quality photo album.
To achieve exceptional print resolution, Canon Full-photolithography Inkjet Nozzle Engineering (FINE) uses a patented print head with high precision nozzles, ejecting ink droplets as small as 1 picolitre in size (the smaller the ink drop the better quality the image).
Compact and tidy
Both the Power cable and USB port are recessed inside the compact, stylish printer body so you can push the machine right back against the wall - saving space and keeping everything neat and tidy.
Printing speeds explained:
Canon measures its printing speeds in IPM (Images Per Minute). IPM is a new ISO speed testing standard, approved by the International Standards Organisation in March 2009.
PPM (Page Per Minute), used by some manufacturers, is not a standard for inkjet printers. Every printer manufacturer has their own 'test pages' that are used to test speed and give vastly different results. The new ISO standard sets standardised 'test pages' that are to be used by any manufacturer measuring their speed in IPM, allowing comparable results across inkjet brands.
*Only compatible with Canon Digital Still Compact and Digital SLR cameras.
Box Contains
- PIXMA MG5250 All-In-One
- Power cord
- Ink tanks (PGI-525PGBK, CLI-526BK, CLI-526C, CLI-526M, CLI-526Y)
- Multilingual set up guides
- Set up software
- User's manual CD
- Warranty sheet
Full HD movie print
You can print stunning photographs from high definition movies. -
Efficient individual ink tanks
It has individual ink tanks saving you time and money, also notifying you when the ink is running out. -
Sharper previews
It has 2.4" color TFT screen allowing preview and image correction before printing. -
Simple operation
It has easy scroll wheel for simple, clear and intuitive operation of the menu. -
Quality scanning
You can scan high-quality photos and documents at up to 2400 x 4800 optical dpi. -
Flash memory
You can connect a USB flash memory device and access your photos quickly and easily.
- Canon PIXMA MG5250 - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 5-ink
- Max Printing Speed
- Up to 11 ipm (mono) / up to 9.3 ipm (colour)
- Max Printing Resolution
- 9600 x 2400 dpi (colour)
- Scanning
- 2400 x 4800 dpi
- Display
- 2.4"
- Original Size
- A4 (210 x 297 mm), Letter A (216 x 279 mm) (max)
- Original Type
- Sheets
- Media Size
- 216 x 356 mm (max)
- Media Type
- Envelopes, plain paper, photo paper, printable CD/DVD disc
- Standard Media Capacity
- 300 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- Wi-Fi(n), USB host, USB 2.0
- Office Machine Features
- Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive
- Power
- AC 110/230 V (50/60Hz)
- 45.5 cm x 36.8 cm x 16 cm
- 8.1 kg
- Copier Type
- Digital
- Ink-jet - colour - photo
- Display Diagonal Size
- 2.4"
- Interface
- Supported Flash Memory
- Memory Stick, CompactFlash, SD Memory Card, MultiMediaCard, Memory Stick PRO, Memory Stick Duo, USB flash drive, IBM Microdrive, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, BorderFree, 4 on 1, fit to page, Frame Erase Copy
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 5 individual ink tanks
- 5-ink
- Minimum Ink Droplet Size
- 1 pl
- Ink Type
- Canon ChromaLife100+
Scanning
- Scan Element
- CIS
- Optical Resolution
- 2400 x 4800 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, A4 Super (228.6 x 381 mm), 200 x 250 mm
- Borderless Photo Sizes
- 100 x 150 mm, 130 x 180 mm, A4 Super (228.6 x 381 mm), 200 x 250 mm
- 300 sheets
- 2 x input tray - 150 sheets , CD/DVD tray
- Speed Details
- Printing: up to 11 ipm - B/W , Printing: up to 9.3 ipm - colour , Printing: 20 sec (10 x 15 cm (4"x6")) - photo
- 1 x USB 2.0 , 1 x USB host
- Network Protocols
- TCP/IP
- WEP, WPA-PSK, WPA, WPA2
- Operating System Support
- MS Windows XP, MS Windows 7, Apple Mac OS X 10.4.11 - 10.6.x, MS Windows Vista
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX, Canon Easy-PhotoPrint EX, Canon MP Navigator EX, Auto Photo Fix II
- Voltage Required
- 21 Watt
- Power Consumption Standby
- 1.6 Watt
- Power Consumption Sleep
- 0.4 Watt
- Direct Printing Specifications
- PictBridge
- First Copy Out Time Colour
- 15 sec
- Consumables Included
- 1 x ink tank (pigmented black) - up to 341 pages - Canon PGI-525PGBK , 1 x ink tank (black) - up to 3005 pages - Canon CLI-526BK , 1 x ink tank (cyan) - up to 520 pages - Canon CLI-526C , 1 x ink tank (magenta) - up to 500 pages - Canon CLI-526M , 1 x ink tank (yellow) - up to 515 pages - Canon CLI-526Y
- 45.5 cm
- 36.8 cm
- 16 cm
- 8.1 kg
- Sound Emission
- 47.5 dB (operating)
- 5 °C
- 35 °C
- 10 - 90%
Canon PGI 525PGBK Black Ink Tank | In Stock | £11.16 |
Canon CLI-526 Cyan Ink Tank | In Stock | £9.89 |
Canon CLI-526 Magenta Ink Tank | In Stock | £9.89 |
