Connect easily with smart devices using this compact Canon PIXMA MG3650 Wi-Fi all-in-one. Enjoy fast, high-quality print, copy and scan with 2-sided printing.
Connect, print, copy and scan the way you want with this Wi-Fi all-in-one that delivers fast high-quality, borderless prints
Effortlessly print stunning borderless photos packed with high levels of detail, plus professional looking documents with sharp text - thanks to Canon's cartridge system and up to 4,800 dpi print resolution. -
Effortlessly print and scan using smart devices- no Internet required with built-in access point mode
You're smartphone ready and so is this printer. You can print and scan using your smartphone or tablet. Built-in access point mode creates an ad hoc wireless network - so you can print and scan directly without having to join a Wi-Fi network or use the Internet.
- Canon PIXMA MG3650 - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
- Max Copying Speed
- 2.7 ppm (colour)
- Max Printing Speed
- Up to 9.9 ipm (mono) / up to 5.7 ipm (colour)
- Max Printing Resolution
- 4800 x 1200 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Original Size
- A4 (210 x 297 mm), Letter A (216 x 279 mm) (max)
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper, glossy photo paper, matte photo paper, high resolution paper, luster paper, semi-gloss photo paper
- Standard Media Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, PIXMA Cloud Link, scan to Cloud, access point mode
- Power
- AC 120/230 V (50/60Hz)
- 44.9 cm x 30.4 cm x 15.2 cm
- 5.4 kg
- Enclosure Colour
- Black
- Ink-jet - colour
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Enclosure Colour
- Black
Copying
- Max Copying Speed
- 2.7 ppm (colour)
- Maximum Copies
- 21
- Copying Features
- Fit to page
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, pigment black
- 4-ink
- Minimum Ink Droplet Size
- 2 pl
- Ink Type
- Canon ChromaLife100
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
- 100 sheets
- Input tray - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 300 g/m²
- Speed Details
- Printing: up to 9.9 ipm - B/W , Printing: up to 5.7 ipm - colour , Printing: 44 sec (10 x 15 cm (4"x6")) - photo
- 1 x USB 2.0 - 4 pin USB Type B
- WEP, WPA-PSK, WPA2-PSK
- Operating System Support
- MS Windows 7, MS Windows XP SP3, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, Android, iOS
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX, Canon My Image Garden, Canon Print Service Plug-in for Android, Quick Menu, MP Driver including Scanning Utility, Canon Easy-PhotoPrint+
- Voltage Required
- 16 Watt
- Power Consumption Standby
- 1.4 Watt
- Direct Printing Specifications
- PictBridge
- First Copy Out Time Colour
- 22 sec
- Consumables Included
- 1 x ink cartridge (pigmented black) ¦ 1 x ink cartridge (colour)
- 44.9 cm
- 30.4 cm
- 15.2 cm
- 5.4 kg
- Sound Emission
- 43.5 dBA (operating)
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
