Canon PIXMA MG3250 - multifunction ( printer / copier / scanner ) ( colour )
Quicklinx: 87VPWS00 Mfr#: 6223B008AA
Easily print, copy and scan with this Wi-Fi all-in-one for use anywhere in the home. With compact FastFront design and auto duplex, it also supports smartphone printing and Apple AirPrint.
  • Compact, wireless all-in-one
    With Wi-Fi connectivity, this all-in-one offers easy printing around the home from PC and from mobile devices. The stylish and compact FastFront design simplifies paper loading and ink replacement. It is an ideal printer, copier and scanner for those looking for everyday functionality.
  • Smartphone and tablet ready
    Canon's Easy-PhotoPrint app provides the flexibility to print from or even scan to your mobile devices, wherever you are in the home. With Apple AirPrint support, you can also print photos, emails, web pages and other documents direct from your iPhone, iPad and iPod touch. Print more for less. With the extra capacity XL FINE cartridges there are longer periods between ink replacements. They deliver significantly more prints than their standard equivalents. The XL cartridges are also more cost effective and let you save up to 50% per page - ideal if you print regularly.
  • Save paper
    Auto duplex provides automatic double-sided printing, which saves paper while delivering professional looking documents. For smart web printing use the Easy-WebPrint EX plug-in and only print what you need. It makes it simple to clip information from websites and combine them into one page for efficient printing.
  • Print direct from Facebook
    The Print Your Days app lets you print your, and your friends', photos directly from Facebook. Apply various effects or create eye-catching collages of up to five photos on a single page, using one of the many background styles available.
  • Save energy
    Cut your power consumption with auto power off, which switches the printer off if not used for a set time. Auto power on conveniently turns it back on, automatically, when you start printing.
Canon PIXMA MG3250 - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Max Copying Speed
4.3 ppm (colour)
Max Printing Speed
Up to 9.2 ipm (mono) / up to 5 ipm (colour)
Max Printing Resolution
4800 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Original Size
A4 (210 x 297 mm), Letter A (216 x 279 mm) (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
AC 110/230 V (50/60Hz)
44.9 cm x 30.4 cm x 15.2 cm
5.5 kg
Copier Type
Digital
Printing Technology
Ink-jet - colour - photo
USB 2.0, Wi-Fi(n)
Copying
Max Copying Speed
4.3 ppm (colour)
Maximum Copies
20
Copying Features
Fit to page, Multiple Copy, collation copy
Printing
Inkjet Technology
Max Printing Speed
4-ink
Minimum Ink Droplet Size
2 pl
Ink Type
Canon ChromaLife100
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Document & Media Handling
Max Original Size
Original Type
Sheets
Max Media Size
Legal
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
100 sheets
Speed Details
Printing: up to 9.2 ipm - B/W , Printing: up to 5 ipm - colour , Printing: 44 sec (10 x 15 cm (4"x6")) - photo , Scanning: 14 sec (A4) , Copying: up to 4.3 ipm - colour
1 x USB 2.0
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows 7, MS Windows Vista SP1, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), MS Windows Vista SP2, MS Windows Vista SP2 64-bit Edition, Apple Mac OS X 10.5.8 - 10.8
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Canon Full HD Movie Print, Canon Creative Park Premium
20 Watt
Power Consumption Standby
2 Watt
First Copy Out Time Colour
20 sec
Consumables Included
1 x ink tank (black) - up to 180 pages - Canon PG-540 , 1 x ink tank (colour) - up to 180 pages - Canon CL-541
44.9 cm
30.4 cm
15.2 cm
5.5 kg
Sound Emission
42.5 dB (operating)
5 °C
35 °C
10 - 90% (non-condensing)
