The perfect everyday All-In-One for printing, scanning and copying. From text-heavy documents to family photos, the compact Canon PIXMA MG2550S’s print engine is built for quality and ease-of-use.
Print, scan, copy – home printing made easy:
The ideal home All-In-One, letting you print, scan and copy documents and photos at speed without compromising on quality. Simple to use, the Canon PIXMA MG2550S is a stylish, compact and desk-friendly device with powerful features for every home user.
Affordable device, premium print quality:
The Canon PIXMA MG2550S offers incredible value for money: an affordable home printer that produces superior quality documents and photos. FINE Cartridge technology means deep blacks, vivid colours and a stunning level of detail.
Up to 30% lower cost per page:
Using the optional high-capacity Canon XL ink cartridges, you can save as much as 30% on the cost per page compared to their standard equivalents. Get more pages per cartridge and go longer between cartridge replacements; the Canon PIXMA MG2550S won’t cost the earth to run.
Be creative:
Easily organise and print your photos with the face-recognition features of My Image Garden app, while CREATIVE PARK PREMIUM opens a world of creative possibilities with its selection of designs from professional artists, all available for you to use as postcards, calendars, birthday cards and much more.
Energy saving built-in:
Use less energy with Auto Power On/Off. Hit print on your laptop and watch as the printer immediately emerges from its power-saving mode, ready to print without even switching it on.
This model has replaced the PIXMA MG2450
Print, scan, copy - home printing made easy
The ideal home all-in-one, letting you print, scan and copy documents and photos at speed without compromising on quality. Simple to use, the Canon PIXMA MG2550S is a stylish, compact and desk-friendly device with powerful features for every home user. -
The Canon PIXMA MG2550S offers incredible value for money: an affordable home printer that produces superior quality documents and photos. -
Use less energy with auto power on/off. Hit print on your laptop and watch as the printer immediately emerges from its power-saving mode, ready to print without even switching it on.
- Canon PIXMA MG2550S - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
- Max Copying Speed
- 1.6 ppm (colour)
- Max Printing Speed
- Up to 8 ipm (mono) / up to 4 ipm (colour)
- Max Printing Resolution
- 4800 x 600 dpi (colour)
- Scanning
- 600 x 1200 dpi
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper, glossy photo paper
- Standard Media Capacity
- 60 sheets
- Connection Availability
- Interface
- USB 2.0
- Power
- AC 120/230 V (50/60Hz)
- 42.6 cm x 30.6 cm x 14.5 cm
- 3.5 kg
- 2 years
- Ink-jet - colour
- Interface
- USB 2.0
Copying
- Max Copying Speed
- 1.6 ppm (colour)
- Maximum Copies
- 21
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, pigment black
- 4-ink
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 275 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- 60 sheets
- Input tray - 60 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 275 g/m²
- Speed Details
- Printing: up to 8 ipm (A4) - B/W , Printing: up to 4 ipm (A4) - colour , Scanning: 14 sec (A4) , Copying: up to 1.6 ipm - colour
- 1 x USB 2.0 - 4 pin USB Type B
- Operating System Support
- MS Windows 7, MS Windows XP SP3, MS Windows Vista SP2, MS Windows 7 SP1, Windows 8, Windows 8.1, Windows 10, Apple Mac OS X 10.7.5 - 10.11
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX, Canon Full HD Movie Print, Canon My Image Garden, Quick Menu, MP Driver including Scanning Utility
- Voltage Required
- 9 Watt
- Power Consumption Standby
- 1 Watt
- First Copy Out Time Colour
- 31 sec
- 42.6 cm
- 30.6 cm
- 14.5 cm
- 3.5 kg
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
Service and Support
- 2 years
Canon PG545 Black Ink Cartridge | In Stock | £12.63 |
Canon PG545/CL546 Black & Colour Ink Multipack | In Stock | £26.30 |
Canon PG545XL Black High Yield Inkjet Cartridge | In Stock | £17.62 |
