Canon PIXMA MG2550S Colour Inkjet Multifunction Printer
Quicklinx: CDLKWS00 Mfr#: 0727C008
The perfect everyday All-In-One for printing, scanning and copying. From text-heavy documents to family photos, the compact Canon PIXMA MG2550S’s print engine is built for quality and ease-of-use.
Print, scan, copy – home printing made easy:
The ideal home All-In-One, letting you print, scan and copy documents and photos at speed without compromising on quality. Simple to use, the Canon PIXMA MG2550S is a stylish, compact and desk-friendly device with powerful features for every home user.
Affordable device, premium print quality:
The Canon PIXMA MG2550S offers incredible value for money: an affordable home printer that produces superior quality documents and photos. FINE Cartridge technology means deep blacks, vivid colours and a stunning level of detail.
Up to 30% lower cost per page:
Using the optional high-capacity Canon XL ink cartridges, you can save as much as 30% on the cost per page compared to their standard equivalents. Get more pages per cartridge and go longer between cartridge replacements; the Canon PIXMA MG2550S won’t cost the earth to run.
Be creative:
Easily organise and print your photos with the face-recognition features of My Image Garden app, while CREATIVE PARK PREMIUM opens a world of creative possibilities with its selection of designs from professional artists, all available for you to use as postcards, calendars, birthday cards and much more.
Energy saving built-in:
Use less energy with Auto Power On/Off. Hit print on your laptop and watch as the printer immediately emerges from its power-saving mode, ready to print without even switching it on.
This model has replaced the PIXMA MG2450
  • Print, scan, copy - home printing made easy
    The ideal home all-in-one, letting you print, scan and copy documents and photos at speed without compromising on quality. Simple to use, the Canon PIXMA MG2550S is a stylish, compact and desk-friendly device with powerful features for every home user.
  • Affordable device, premium print quality
  • Energy saving built-in
    Use less energy with auto power on/off. Hit print on your laptop and watch as the printer immediately emerges from its power-saving mode, ready to print without even switching it on.
Canon PIXMA MG2550S - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Max Copying Speed
1.6 ppm (colour)
Max Printing Speed
Up to 8 ipm (mono) / up to 4 ipm (colour)
Max Printing Resolution
4800 x 600 dpi (colour)
Scanning
600 x 1200 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper, glossy photo paper
Standard Media Capacity
60 sheets
Connection Availability
USB 2.0
AC 120/230 V (50/60Hz)
42.6 cm x 30.6 cm x 14.5 cm
3.5 kg
2 years
Printing Technology
Ink-jet - colour
USB 2.0
Copying
Max Copying Speed
1.6 ppm (colour)
Maximum Copies
21
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Scanning
Scan Element
CIS
Optical Resolution
600 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
275 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
60 sheets
Input tray - 60 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 275 g/m²
Speed Details
Printing: up to 8 ipm (A4) - B/W , Printing: up to 4 ipm (A4) - colour , Scanning: 14 sec (A4) , Copying: up to 1.6 ipm - colour
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
MS Windows 7, MS Windows XP SP3, MS Windows Vista SP2, MS Windows 7 SP1, Windows 8, Windows 8.1, Windows 10, Apple Mac OS X 10.7.5 - 10.11
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX, Canon Full HD Movie Print, Canon My Image Garden, Quick Menu, MP Driver including Scanning Utility
9 Watt
Power Consumption Standby
1 Watt
First Copy Out Time Colour
31 sec
42.6 cm
30.6 cm
14.5 cm
3.5 kg
5 °C
35 °C
10 - 90% (non-condensing)
Service and Support
2 years
CDLK Canon CL546XL Colour High Yield Inkjet Cartridge In Stock £17.29
CDLK Canon PG545XL Black High Yield Inkjet Cartridge In Stock £18.04
CDLK Canon PG-545XL/CL-546XL Photo Paper Value Pack - 2-pack In Stock £34.72
