Ideal for everyday printing, scanning and copying, this speedy all-in-one includes the FINE cartridge system for high quality photos and documents. Its compact and stylish design takes up less space and ensures effortless paper loading and ink replacement.
The auto clip function of the Easy-WebPrint EX plug-in for Internet Explorer makes it simple to print only what you need from the web. You can also clip selected information from multiple web pages to print on one sheet or save as a PDF file.
Compact, stylish all-in-one
Ideal for everyday printing, scanning and copying, this speedy all-in-one includes the FINE cartridge system for high quality photos and documents. Its compact and stylish design takes up less space and ensures effortless paper loading and ink replacement. -
Fast, quality printing
The FINE cartridge system with min. 2pl ink droplets and up to 4800-dpi print resolution delivers great levels of detail. With A4 print speeds of 8.0-ipm mono and 4.0-ipm for color there's almost no waiting for your documents to print. -
Save money on ink
Print more for less. XL FINE cartridges deliver significantly more pages and last longer between ink replacements - ideal if you print frequently - and can deliver up to 30% savings per page compared to their standard equivalents. -
Smart web printing
The auto clip function of the Easy-WebPrint EX plug-in for Internet Explorer makes it simple to print only what you need from the web. You can also clip selected information from multiple web pages to print on one sheet or save as a PDF file. -
Save energy
Auto power off automatically switches the printer off if not used for a set time - saving you energy. Auto power on conveniently turns the printer back on when you start printing. Quiet mode can significantly reduce operating noise for near silent printing at home.
- Canon PIXMA MG2450 - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
- Max Copying Speed
- 1.6 ppm (colour)
- Max Printing Speed
- Up to 8 ipm (mono) / up to 4 ipm (colour)
- Max Printing Resolution
- 4800 x 1200 dpi (colour)
- Scanning
- 600 x 1200 dpi
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 60 sheets
- Connection Availability
- Interface
- USB 2.0
- Power
- AC 120/230 V (50/60Hz)
- 42.6 cm x 30.6 cm x 14.5 cm
- 3.5 kg
- 2 Years
- Ink-jet - colour
- Interface
- USB 2.0
Copying
- Max Copying Speed
- 1.6 ppm (colour)
- Maximum Copies
- 21
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, pigment black
- 4-ink
- Minimum Ink Droplet Size
- 2 pl
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 275 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- 60 sheets
- Input tray - 60 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 275 g/m²
- Speed Details
- Printing: up to 8.4 ipm - B/W , Printing: up to 4 ipm - colour , Copying: up to 1.6 ipm - colour , Scanning: 14 sec (A4)
- 1 x USB 2.0 - 4 pin USB Type B
- Operating System Support
- MS Windows 7, MS Windows XP SP3, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, Windows RT
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX, Canon Full HD Movie Print, Canon My Image Garden
- Voltage Required
- 9 Watt
- Power Consumption Standby
- 1 Watt
- First Copy Out Time Colour
- 31 sec
- Consumables Included
- 1 x ink cartridge (pigmented black) , 1 x ink cartridge (colour)
- 42.6 cm
- 30.6 cm
- 14.5 cm
- 3.5 kg
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
Service and Support
- 2 Years
