Enjoy stunning quality photos up to A3+ with this premium 6 single ink printer. Print wirelessly around the home including from smartphones, tablets and Wi-Fi cameras. Ideal for photo enthusiasts.
Premium A3+ photo printer:
This premium photo printer, with a sophisticated design, boasts an advanced 6 colour ink system allowing you to print stunning quality photos in sizes from 10x15cm up to A3+ as well as documents - making it the ideal choice for photo enthusiasts.
Exceptional performance:
The 6 colour system includes a grey ink for richer colour photos and stunning mono prints, while FINE print head technology with up to 9600dpi resolution delivers exceptional details for photo-lab quality results, fast.
Wireless connectivity:
Use and share the printer wirelessly around the home. Download Canon PRINT app to print from your smart devices. Apple AirPrint and Google Cloud Print support is also provided. Print photos directly from wireless cameras using Wireless PictBridge.
Save money on ink:
Print more for less. The single ink system with individually replaceable ink tanks means you only have to change the colour that runs out, reducing any wastage. The optional XL inks allow you to print more pages and offer savings of up to 30% per page compared with standard inks.
Get creative:
It's easy to organise and print your photos with the My Image Garden software. It lets you search through your images and create attractive designs for printing, including directly onto printable discs. Enjoy access to a wide range of professional quality creative content with CREATIVE PARK PREMIUM.
Hybrid ink system:
The dye-based inks (C, M, Y, GY and BK) produce stunning quality colour photos while the pigment black ink (PBK) is used to create documents with crisp, sharp text. Genuine Canon inks feature the ChromaLife100+ system, producing photo-lab quality photos that can also last a lifetime.
This premium photo printer, with a sophisticated design, boasts an advanced 6 color ink system allowing you to print stunning quality photos in sizes from 10 x 15 cm up to A3+ as well as documents - making it the ideal choice for photo enthusiasts -
The 6 color system includes a gray ink for richer color photos and stunning mono prints, while FINE print head technology with up to 9600 dpi resolution delivers exceptional details for photo-lab quality results, fast. -
Use and share the printer wirelessly around the home. -
Save money on ink
Print more for less. The single ink system with individually replaceable ink tanks means you only have to change the color that runs out, reducing any wastage. The optional XL inks allow you to print more pages and offer savings of up to 30% per page compared with standard inks. -
Get creative
It's easy to organize and print your photos with the My Image Garden sofware. It lets you search through your images and create attractive designs for printing, including directy onto printable discs. Enjoy access to a wide range of professional quality creative content with CREATIVE PARK PREMIUM. -
Hybrid ink system
The dye-based inks (C ,M, Y, GY and BK) produce stunning quality colour photos while the pigment black ink (PBK) is used to create documents with crisp, sharp text. Genuine Canon inks feature the ChromaLife100+ system, producing photo-lab quality photos that can also last a lifetime.
- Canon PIXMA iP8750 - printer - colour - ink-jet
- Printer Type
- Photo printer - ink-jet - colour
- 8.5 kg
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering)
- Ink Palette Supported (Colours)
- 6-ink - cyan, magenta, yellow, black, pigment black, grey
- Max Media Size
- ANSI B (Ledger) (279 x 432 mm), A3 Plus (329 x 483 mm)
- Max Media Size (Custom)
- 329 mm x 483 mm
- Print Speed
- Up to 14.5 ipm - B/W , Up to 10.4 ipm - colour , Up to 0.6 min/page - photo - 100 x 150 mm , Up to 2 min/page - photo - A3 Plus (329 x 483 mm)
- Max Resolution (Colour)
- 9600 x 2400 dpi
- Print on CD/DVD
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Media Type
- Envelopes, plain paper, photo paper, photo stickers, glossy photo paper, matt photo paper, high resolution paper, luster photo paper, semi-gloss photo paper
- Total Media Capacity
- 150 sheets
- Media Handling
- 150-sheet input tray
- Networking
- Print server
- Printer Features
- Borderless printing
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Android, Apple MacOS X 10.6.8 or later, Windows 8, Apple iOS, Windows 8.1, Windows RT
- 59 cm x 33.1 cm x 15.9 cm
- 2 years
- Printer Type
Printer
- Inkjet Technology
- Minimum Ink Droplet Size
- 1 pl
- Ink Cartridge Configuration
- 6 individual ink tanks
- Ink Type
- Canon ChromaLife100+
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- 9600 x 2400 dpi
- Print on CD/DVD
- Direct Printing Specifications
- PictBridge
- Printer Features
- Media Handling
Media Handling
- Media Type
- Max Media Size
- 329 mm x 483 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 250 x 300 mm, A3 Plus (329 x 483 mm)
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 250 x 300 mm, A3 Plus (329 x 483 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- Media Weight
- 64 g/m² - 300 g/m²
- 150 sheets
- Media Feeders
- 1 x automatic - 150 sheets - A3 Plus (329 x 483 mm) weight: 64 g/m² - 300 g/m²
- Networking
- Print server
- WEP, WPA-PSK, WPA2-PSK
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Included Accessories
- CD/DVD tray
- Consumables Included
- 1 x ink tank (pigmented black) , 1 x ink tank (black) , 1 x ink tank (cyan) , 1 x ink tank (yellow) , 1 x ink tank (magenta) , 1 x ink tank (grey)
- Power Device
- Power supply
- Voltage Required
- AC 120/230 V
- Frequency Required
- 50/60 Hz
- 23 Watt
- Power Consumption Stand by
- 1.9 Watt
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX, Canon Creative Park Premium, Canon My Image Garden
- OS Required
- 15 °C
- 30 °C
- 5 - 95% (non-condensing)
- Sound Emission (Operating)
- 43.5 dBA
- 59 cm
- 33.1 cm
- 15.9 cm
- 8.5 kg
Service and Support
- 2 Years
Canon PGI-550PGBK XL - Pigment Black - Ink Cartridge | In Stock | £13.27 |
Canon CLI-551 XL Black Ink Cartridge | In Stock | £12.52 |
Canon CLI-551 XL Cyan Ink Cartridge | In Stock | £12.91 |
Canon CLI-551 XL Magenta Ink Cartridge | In Stock | £12.91 |
Canon CLI-551 XL Yellow Ink Cartridge | In Stock | £11.91 |
Canon CLI-551 XL Grey High Yield Ink Tank | In Stock | £11.91 |
Canon PGI550 Black Ink Cartridge | In Stock | £10.67 |
Canon CLI-551 Black Ink Tank | In Stock | £8.78 |
Canon CLI-551 Grey Ink Tank | In Stock | £8.77 |
Canon CLI-551 Cyan Ink Tank | In Stock | £9.51 |
Canon CLI-551 Yellow Ink Tank | In Stock | £9.20 |
Canon CLI-551 Magenta Ink Tank | In Stock | £9.20 |
Canon PGI550PGBK/CLI551 Value Pack 6 Inks | In Stock | £52.30 |
