Canon PIXMA iP3600 - printer - colour - ink-jet
Quicklinx: 58ZRWS00 Mfr#: 2868B008AA
The PIXMA iP3600 is a compact, affordable home photo printer with class-leading specification that delivers superior photo lab quality prints.
The PIXMA iP3600 features crisp text printing thanks to a dedicated black pigment ink cartridge, making it appropriate for all kinds of web and document printing.
All 5 Single Inks can be replaced individually, minimizing unnecessary ink wastage. A smart LED indicates when a cartridge is running low or needs replacing.
Two paper trays enhance media flexibility, allowing both photo paper and plain paper to be loaded at the same time without having to swap them manually. Digital camera users will also benefit from the ability to print directly from their camera without a PC using PictBridge. If you prefer to hook the printer up to your PC, a Hi-Speed USB interface enables the fast transfer of information.
Printer Type
Photo printer - ink-jet - colour
5.6 kg
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering)
Ink Palette Supported (Colours)
5-ink
Media Size Class
A4/Legal
Max Media Size
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 26 ppm - B/W , Up to 17 ppm - colour
Max Resolution (Colour)
9600 x 2400 dpi
USB, USB host
Media Type
Envelopes, plain paper, photo paper, matt photo paper, high resolution paper, semi-gloss photo paper
Total Media Capacity
300 sheets
Media Handling
150-sheet input tray, 150-sheet paper cassette
Printer Features
Borderless printing
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Vista, Apple MacOS X 10.3.9 - 10.5
Microsoft Certification
Compatible with Windows 7
43.1 cm x 29.6 cm x 15.3 cm
Printer Type
Printer
Inkjet Technology
5-ink
Minimum Ink Droplet Size
1 pl
Ink Cartridge Configuration
5 individual ink tanks
Print Speed
Wired
USB, USB host
9600 x 2400 dpi
Direct Printing Specifications
PictBridge, Canon Direct Print
Printer Features
Borderless printing
Media Handling
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 330 x 457 mm, 25.4 x 38.1 mm, 50.8 x 63.5 mm
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Card / Label Sizes
54 x 86 mm
Media Weight
64 g/m² - 300 g/m²
300 sheets
1 x USB 2.0 - 4 pin USB Type B , 1 x direct print port - 4 pin USB Type A
Consumables Included
1 x ink tank (black) , 1 x ink tank (cyan) , 1 x ink tank (magenta) , 1 x ink tank (yellow)
Power supply - internal
Frequency Required
50/60 Hz
16 Watt
Power Consumption Stand by / Sleep
1.3 Watt
Software Included
Drivers & Utilities, Canon Easy-PhotoPrint
Additional Requirements
CD-ROM, SVGA monitor
Environmental Standards
ENERGY STAR
5 °C
35 °C
10 - 90%
Sound Emission (Operating)
41 dBA
43.1 cm
29.6 cm
15.3 cm
5.6 kg
58ZR Canon CLI-521 Photo Black Ink Tank In Stock £9.54
58ZR Canon CLI-521 Yellow Ink Tank In Stock £9.57
58ZR Canon CLI-521 Magenta Ink Tank In Stock £9.57
58ZR Canon CLI-521 Cyan Ink Tank In Stock £9.57
58ZR Canon PGI 520BK - Ink tank - 1 x pigmented black In Stock £10.81
58ZR Canon PGI-520 BLACK INK IP3600 IP4600 MP540 MP620 In Stock £10.81
