Canon PIXMA iP100 Colour Inkjet Printer with Battery
Quicklinx: 54VVWS00 Mfr#: 1446B028BA
With its rechargeable battery and enhanced connectivity, the PIXMA iP100 delivers the ultimate in portable photo and document printing. Get speedy photo lab quality prints and documents wherever you are.
  • Exceptional portable quality
    The ultra-portable PIXMA iP100 with battery utilizes Canon's FINE print head technology for incredible quality photo and document printing wherever you are. Micro-Nozzles ejecting tiny 1pl ink droplets enable a high 9600 x 2400dpi resolution, producing prints with class-leading quality.
  • Dedicated Ink Technology
    The 5 ink system produces high quality photograph and document prints. The Photo Black ink ensures rich color contrast and deep blacks in photographs, while a separate Pigment Black ink is used to produce crisp, sharp text for business-class documents.
  • Quick print speeds
    The PIXMA iP100 with battery prints 4" x 6" (10 x 15 cm) borderless photo lab quality prints in just 50 seconds. Documents can be printed at speeds of 20 ppm in mono and 14 ppm in color.
  • Beautiful, long-lasting prints
    Canon's ChromaLife100 system delivers beautiful photographs with enhanced durability of up to 100 years. By using the FINE Cartridge, genuine Canon inks and genuine Canon photo papers, the system provides you with long-lasting, beautiful photos.
  • Printing freedom
    The PIXMA iP100 with battery offers IrDA IR connectivity as standard and an optional Bluetooth adapter (BU-30) for convenient, cable-free printing. The ability to print wirelessly from compatible camera phones, PCs and PDAs adds to the printer's versatile operability.
  • Rechargeable Battery for lasting power
    With Canon's Rechargeable Battery (LK-62) included as standard, the PIXMA iP100 can be used wherever you need high quality prints fast. With its compact size and lightweight build, this ultra-compact PIXMA is the ideal tool for printing on the road – and used with optional car charger (PU-200U) gives you total flexibility.
Canon PIXMA iP100 with battery - printer - colour - ink-jet
Printer Type
Photo printer - ink-jet - colour
2 kg
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering)
Ink Palette Supported (Colours)
5-ink
Max Media Size
100 x 150 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 20 ppm - black fast , Up to 14 ppm - colour fast , Up to 15.6 ppm - B/W , Up to 11.2 ppm - colour
Max Resolution (Colour)
9600 x 2400 dpi
USB, IrDA
Media Type
Envelopes, plain paper, photo paper, photo stickers, glossy photo paper, matt photo paper, high resolution paper
Total Media Capacity
50 sheets
Printer Features
Borderless printing
AC 120/230 V
Lithium Ion Included Qty 1
Microsoft Windows 2000 Professional, Microsoft Windows XP, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista
Microsoft Certification
Certified for Windows Vista
32.2 cm x 18.5 cm x 6.2 cm
2 Years
Printer Type
Printer
Inkjet Technology
5-ink
Minimum Ink Droplet Size
1 pl
Print Speed
Wireless
USB, IrDA
9600 x 2400 dpi
Direct Printing Specifications
PictBridge, Canon Direct Print
Printer Features
Borderless printing
Media Handling
Media Type
Max Media Size
100 x 150 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 100 x 180 mm, 54 x 86 mm, 200 x 250 mm
Borderless Photo Sizes
A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 54 x 86 mm
Envelope Sizes
International DL (110 x 220 mm)
Card / Label Sizes
54 x 86 mm
Media Weight
64 g/m² - 273 g/m²
50 sheets
Media Feeders
1 x automatic - 50 sheets weight: 64 g/m² - 273 g/m²
1 x USB 2.0 - 4 pin USB Type B , 1 x IrDA - IrDA
Consumables Included
1 x ink tank (black) , 1 x ink tank (colour)
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Power supply
AC 120/230 V
Frequency Required
50/60 Hz
9 Watt
Power Consumption Stand by / Sleep
1.5 Watt
Lithium Ion
Included
1
Software Included
Drivers & Utilities, Canon Easy-PhotoPrint
Additional Requirements
CD-ROM, XGA monitor
System Requirements Details
Windows 2000/XP/Vista - Pentium II - 300 MHz - RAM 128 MB - HD 800 MB , MacOS X - PowerPC G3 RAM 128 MB - HD 650 MB
Environmental Standards
ENERGY STAR
5 °C
35 °C
10 - 90%
Sound Emission (Operating)
38.5 dBA
32.2 cm
18.5 cm
6.2 cm
2 kg
Service and Support
2 Years
54VV Canon CLI-36 Colour Ink Tank (Black/Cyan/Magenta/Yellow) In Stock £11.00
