Canon PIXMA G650 Colour Ink Jet Multifunction Printer
Quicklinx: G96NWS00 Mfr#: 4620C008AA
Type: Printer / copier / scanner
Functionality: Printer, Copier, Scanner
Output Type: Colour
Wireless Capability: Wireless, Wired
Technology: Ink-jet
25 In Stock
£233.33 ex VAT
£279.99 inc VAT
PIXMA G650 blends unrivaled photo-quality printing with the ability to produce high volumes at an extremely low cost.
  • High volume, high standards, low costs
    For printing large quantities of high-quality images at a low cost, the PIXMA G650 offers simplicity, versatility and brilliant print quality.
  • Dye inks - high quality and fastness
    Various inks for enhanced color gamut and high-quality photo printing.
  • Maintenance cartridge
    Users can replace the print head and maintenance cartridge by themselves to reduce downtime.
  • High-volume photo printing
    High-volume ink tanks enable high page yields: one set of bottles can print many photo prints, meaning fewer bottle refills.
  • Enhanced media support
    Improved feed accuracy and capacity across a wide variety of photo papers, auto print head alignment and more accurate droplet placement.
  • Enhanced usability
    Key-type ink bottles with no squeezing required ensure error-free filling.
Canon PIXMA G650 - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 6-ink
Refillable Tank
Max Printing Speed
Up to 3.9 ipm (mono) / up to 3.9 ipm (colour)
Max Printing Resolution
Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
600 x 1200 dpi
Original Size
A4 (210 x 297 mm), Letter A (216 x 279 mm) (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, iron-on transfers, greeting cards, photo paper, card stock, glossy photo paper, matte photo paper, high resolution paper, luster paper, semi-gloss photo paper, fine art paper, magnetic photo paper, restickable photo paper
Standard Media Capacity
100 sheets
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Intelligent Assistant
Google Assistant, Alexa
Office Machine Features
PIXMA Cloud Link, refillable ink tank
AC 120/230 V (50/60Hz)
44.5 cm x 34 cm x 16.7 cm
6.6 kg
2 Years
Printing Technology
Ink-jet - colour
Display
2 lines
Display Colour Support
Monochrome
Display Features
LCD display
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, 4 on 1, fit to page, ID Card Copy, Frame Erase Copy, Borderless copy
Printing
Inkjet Technology
Refillable Tank
Max Printing Speed
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, red, grey
6-ink
Scanning
Scan Element
CIS
Optical Resolution
600 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
8-bit
Colour Depth (Internal)
16-bit
Document & Media Handling
Max Original Size
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm)
Original Type
Sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
105 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 55 x 91 mm, 216 x 1200 mm, 127 x 127 mm, 200 x 250 mm, 180 x 250 mm, 55 x 89 mm, 89 x 89 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 55 x 91 mm, 127 x 127 mm, 180 x 250 mm, 89 x 89 mm
100 sheets
- 100 sheets size: 55 x 89 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 105 g/m²
Speed Details
Printing: up to 3.9 ipm - B/W , Printing: up to 3.9 ipm - colour , Printing: 47 sec (10 x 15 cm (4"x6")) - photo
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WEP, WPA-PSK, 802.1x, WPA2-PSK, Wi-Fi Direct
Operating System Support
MS Windows 7 SP1, MS Windows Server 2008 R2 SP1, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, MS Windows Server 2016, MS Windows Server 2019, Apple Mac OS X 10.12.6 - 10.15, iPadOS
Software Included
Drivers & Utilities, IJ Printer Assistant Tool
16 Watt
Power Consumption Standby
1.2 Watt
Internet of Things (IoT)
First Copy Out Time Colour
25 sec
Consumables Included
1 x ink bottle (cyan) , 1 x ink bottle (magenta) , 1 x ink bottle (yellow) , 1 x ink bottle (black) , 1 x ink bottle (grey) , 1 x ink bottle (red)
44.5 cm
34 cm
16.7 cm
6.6 kg
Sound Emission
50.5 dBA (operating)
5 °C
35 °C
10 - 90% (non-condensing)
2 Years
Functionality: Copier
Functionality: Scanner
Output Type: Colour
Wireless Capability: Wired
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: Canon
