This compact printer delivers affordable, high quality printing. With USB connectivity it's a perfect personal desktop printer.
Affordable home printer
An easy-to-use and affordable home printer ideal for printing everyday documents and occasional photos. Simple USB connectivity and compact design make it ideally suited for a personal desk printer. -
Quality prints
Print high-quality documents and images with impressive levels of detail. -
Save energy
Auto Power Off automatically switches the printer off if not used for a set time - saving you energy. Auto Power On conveniently turns the printer back on when you start printing.
- Canon PIXMA G1501 - printer - colour - ink-jet
- Printer Type
- Photo printer - ink-jet - colour
- 4.8 kg
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering)
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, pigment black
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 8.8 ipm - B/W - A4 (210 x 297 mm) , Up to 5 ipm - colour - A4 (210 x 297 mm) , Up to 1 min/page - photo - 100 x 150 mm
- Max Resolution (Colour)
- 4800 x 1200 dpi
- Interface
- USB 2.0
- Media Type
- Envelopes, plain paper, photo paper, glossy paper, matte paper, semi-gloss paper
- Total Media Capacity
- 100 sheets
- Printer Features
- Borderless printing, Auto Power On, integrated ink tanks
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista SP2, Microsoft Windows 7 SP1, Windows 8, Microsoft Windows XP (32-bit) SP3, Windows 8.1, Windows 10, Apple MacOS X 10.7.5 - 10.11
- 44.5 cm x 33 cm x 13.5 cm
- 2-year Limited Warranty
- Printer Type
Printer
- Inkjet Technology
- Ink Cartridge Configuration
- 1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB 2.0
- 4800 x 1200 dpi
- Printer Features
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 130 mm
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- Media Weight
- 64 g/m² - 275 g/m²
- 100 sheets
- Media Feeders
- Input tray: 1 - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 275 g/m²
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Included Accessories
- 5 high yield ink bottles
- Power Device
- Power supply - internal
- Voltage Required
- AC 120/230 V
- Frequency Required
- 50/60 Hz
- 11 Watt
- Power Consumption Stand by
- 0.6 Watt
- Software Included
- Drivers & Utilities, Canon Easy-WebPrint EX, Canon My Image Garden with Full HD Movie Print
- OS Required
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
- Sound Emission (Operating)
- 54.5 dBA
- 44.5 cm
- 33 cm
- 13.5 cm
- 4.8 kg
