Canon Full-photolithography Inkjet Nozzle Engineering (FINE) features a patented print head that enables printing with microscopic droplets and high resolution up to 4800 x 2400 dpi, this makes the PGI-72 photo magenta ink cartridge produce superior quality photos and images.
After developing the basic mechanisms used in inkjet printers, Canon has continued to foster new ideas and original technologies in the field. FINE is the key technology behind these innovations. FINE's ink ejection mechanism and print head manufacturing technology have enabled Canon to achieve dramatic improvements in image quality, gradation expression, and image stability. Microscopic ink droplets and precise ejection are essential to high image quality. With conventional ejection systems, the finer the ink droplets, the more vulnerable they are to airflow disturbances from print head movement and changes in ink viscosity due to temperature fluctuations, resulting in inconsistent ejection volumes and ink dot placement. Canon's FINE print head ensures that all the ink under the heater is pushed out in a single ejection to ensure efficient performance. Ink droplet speed has been increased to more than 1.5 times that of conventional systems, reducing their susceptibility to airflow disturbances to enable increased placement accuracy.
- Canon PGI-72PM - photo magenta - original - ink tank
- Product Type
- Ink tank
- Printing Technology
- Ink-jet
- Printing Colour
- Photo magenta (pigmented)
- Capacity
- 14 ml
- Cartridge Features
- Canon LUCIA
- Yield
- Up to 303 pages ISO/IEC 24711/29102
- Compatible with
- PIXMA PRO-10, PRO-10S; PIXUS PRO-10
Consumable
- Consumable Type
- Ink tank
- Ink-jet
- Included Qty
- 1-pack
- Capacity
- 14 ml
- Canon LUCIA
- Yield
- Compatible with
- Canon PIXMA PRO-10, PRO-10S , Canon PIXUS PRO-10
