Canon PGI72 Cyan Ink Cartridge
Quicklinx: 8TVCWS00 Mfr#: 6404B001
Type: Ink Cartridge
Technology: Ink-Jet
10 In Stock
£10.72 ex VAT
£12.86 inc VAT
Canon Full-photolithography Inkjet Nozzle Engineering (FINE) features a patented print head that enables printing with microscopic droplets and high resolution up to 4800 x 2400 dpi, this makes the PGI-72 Cyan Ink Cartridge produce superior quality photos and images.
After developing the basic mechanisms used in inkjet printers, Canon has continued to foster ideas and original technologies in the field. FINE is the key technology behind these innovations. FINE's ink ejection mechanism and print head manufacturing technology have enabled Canon to achieve dramatic improvements in image quality, gradation expression, and image stability. Microscopic ink droplets and precise ejection are essential to high image quality. With conventional ejection systems, the finer the ink droplets, the more vulnerable they are to airflow disturbances from print head movement and changes in ink viscosity due to temperature fluctuations, resulting in inconsistent ejection volumes and ink dot placement. Canon's FINE print head ensures that all the ink under the heater is pushed out in a single ejection to ensure efficient performance. Ink droplet speed has been increased to more than 1.5 times that of conventional systems, reducing their susceptibility to airflow disturbances to enable increased placement accuracy.
  • Efficient Capacity
    With a 14 ml volume, this Canon PGI 72C ink tank ensures a duty cycle of up to 525 pages, making it a suitable choice for regular printing needs without frequent replacements.
  • High-Quality Printing
    Equipped with Canon LUCIA pigmented ink, the Canon PGI 72C offers exceptional print quality with sharp, long-lasting colors that bring your documents and photos to life.
  • Compatibility and Convenience
    Designed specifically for ink-jet printing technology, this original Canon ink tank is compatible with a wide range of printers, ensuring seamless integration and reliable performance.
Canon PGI-72C - cyan - original - ink tank
Ink tank
Printing Technology
Ink-jet
Printing Colour
Cyan (pigmented)
14 ml
Cartridge Features
Canon LUCIA
Yield
Up to 525 pages ISO/IEC 24711/29102
Compatible with
PIXMA PRO-10, PRO-10S; PIXUS PRO-10
Consumable
Consumable Type
Ink tank
Printing Technology
Ink-jet
Cyan (pigmented)
Included Qty
1-pack
14 ml
Cartridge Features
Canon LUCIA
Yield
Compatible with
Canon PIXMA PRO-10, PRO-10S , Canon PIXUS PRO-10
Type: Ink Cartridge
Technology: Ink-Jet
Brand: Canon
