The PGI-29CO Chroma Optimizer for the PIXMA PRO-1 Professional Inkjet Printer is a critical element to attaining professional print quality with accurate color and reduced metamerism, on coated papers. The Chroma Optimizer reduces the difference in ink droplet height to form a flat and smooth ink layer. The result is evenly reflected light, deep blacks, and bright, saturated colors.
Efficient capacity
With a 36 ml volume, this ink tank ensures a steady supply for your printing needs, offering a duty cycle of up to 429 pages without the need for frequent replacements. -
High-quality printing
Designed specifically for ink-jet technology, this original Canon PGI ink tank delivers crisp, clear, and consistent printouts, ensuring every page looks professional. -
Broad compatibility
This ink tank is compatible with PC, making it a versatile choice for a wide range of Canon printers, ensuring easy integration into your existing setup.
- Canon PGI-29CO - chroma optimiser - original - ink tank
- Product Type
- Ink tank
- Printing Technology
- Ink-jet
- Printing Colour
- Chroma optimiser
- Capacity
- 36 ml
- Yield
- Up to 429 pages
- Compatible with
- PIXMA PRO-1
Consumable
- Consumable Type
- Ink tank
- Ink-jet
- Chroma optimiser
- Included Qty
- 1-pack
- Capacity
- 36 ml
- Yield
- Up to 429 pages
- Compatible with
- Canon PIXMA PRO-1
