Canon's FINE cartridge system gives you maximum convenience. Inks and print head are combined in a single handy unit, which can be easily replaced in seconds. The FINE cartridge system also gives you fast printing speeds, for when every second counts!
Black XL FINE Cartridge
This high yield black ink provides up to 3.3x more prints than the standard equivalent. The pigment black ink is used for printing documents and ensures crisp, sharp text with great longevity. The 21ml black ink cartridge allows you to print up to 600 pages of A4 documents.
High-capacity printing
With a generous 21 ml capacity, the Canon PG 540XL ink cartridge ensures a longer period between replacements, offering both convenience and cost-effectiveness for frequent printing needs. -
Advanced technology
Incorporated with Canon's Full-Photolithography Inkjet Nozzle Engineering (FINE), this ink cartridge delivers exceptionally detailed and crisp printouts, making it ideal for both text and image-heavy documents. -
Reliable performance
Designed to achieve up to 600 pages per cartridge under ISO/IEC 24711/24734 standard duty cycle coverage, the Canon PG 540XL provides a reliable and consistent printing solution for all your documents.
- Canon PG-540XL - black - original - ink cartridge
- Product Type
- Ink cartridge
- Printing Technology
- Ink-jet
- Printing Colour
- Black
- Capacity
- 21 ml
- Cartridge Features
- Canon Full-Photolithography Inkjet Nozzle Engineering (FINE)
- Yield
- Up to 600 pages ISO/IEC 24711/24734
- Compatible with
- PIXMA MG2150, MG2250, MG3150, MG3150 MONSTRES ACADEMY, MG3250, MG3550, MG3550 MONSTRES ACADEMY, MG3650, MG3650S, MG4150, MG4250, MG4250 MONSTRES ACADEMY, MX375, MX395, MX435, MX455, MX475, MX515, MX525, MX535, TS5150, TS5151
Consumable
- Consumable Type
- Ink cartridge
- Ink-jet
- Black
- Included Qty
- 1-pack
- Capacity
- 21 ml
- Yield
- Compatible with
- Canon PIXMA MG2150, MG2250, MG3150, MG3150 MONSTRES ACADEMY, MG3250, MG3550, MG3550 MONSTRES ACADEMY, MG3650, MG3650S, MG4150, MG4250, MG4250 MONSTRES ACADEMY, MX375, MX395, MX435, MX455, MX475, MX515, MX525, MX535, TS5150, TS5151
