Canon MAXIFY MB2755 InkJet Multifunction Printer
Quicklinx: CFK8WS00 Mfr#: 0958C028
Functionality: Copier, Fax, Printer, Scanner
Wireless Capability: Wired
Technology: Ink-jet
Max Print Speed: 24ppm
£117.82 ex VAT
£141.38 inc VAT
All-In-One colour inkjet for home offices. The Canon MAXIFY MB2755 provides mobile printing and cloud integration, while its 500-sheet paper capacity and fast 24 images per minute (ipm) mono print speed maximise productivity.
For home offices that demand productivity:
A fully featured printer, scanner, copier and fax designed for home offices. With a large 500-sheet paper cassette and 50-sheet automatic document feeder, the Canon MAXIFY MB2755 produces outstanding prints with deep, dense blacks, vivid colours and crisp text using its marker- and friction-resistant DRHD inks. This quality doesn't come at the expense of speed: print A4 at an ultra-fast 24 ipm in mono and 15.5 ipm in colour, while first page out time (FPOT) is just 6 seconds.
Keep running costs to a minimum:
From low energy consumption of just 0.2 kWh (TEC) to the individually replaceable colour cartridges, economy is a priority. Black cartridges provide an ISO yield of 1,200 pages and colour cartridges 900 pages. The optional 4-colour multipack contains a full set of replacement inks for even better value.
Designed for productivity:
Double-sided printing and support for a variety of paper sizes and types, from A4 plain paper to labels, envelopes, photo paper and even two-sided ID card copying makes light work of common office print jobs. Printing, copying, scanning or faxing is just a few taps away, with a highly responsive 7.5 cm (3") TFT colour touchscreen and improved interface.
Mobile-ready, cloud-ready, work-ready:
Support for Google Cloud Print, Apple AirPrint (iOS), Mopria and the Canon PRINT app provide quick and simple printing and scanning from mobile devices. You can print from the cloud and scan and save documents to cloud services. Supported services include Google Drive, Dropbox, Evernote, OneNote, OneDrive and Concur. Built in Access Point mode means that smart device users can connect to the printer without a Wi-Fi network.
Comprehensive monitoring and maintenance capability:
IP address filtering enables restricted access options, giving permission to only a select number of users, while SMTP email support allows secure scan-to-email. A range of further options allow system administrators to quickly and easily configure the printer and restrict certain operations, such as scan-to-USB.
Network integration:
IT managers and system administrators will appreciate the Canon MAXIFY MB2755s' Simple Network Management Protocol (SNMP) compatibility, making device management and integration into existing office networks easy. SNMP enables a range of maintenance monitoring functions, including ink levels, error status, and page counts.
This model has replaced the MAXIFY MB2350
Canon MAXIFY MB2755 - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Monthly Duty Cycle (max)
15000 pages
Recommended Monthly Volume
200 - 1000 pages
Max Copying Speed
Up to 22 ppm (mono) / up to 11.5 ppm (colour)
Max Printing Speed
Up to 24 ipm (mono) / up to 15.5 ipm (colour)
Max Printing Resolution
Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
3"
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
89 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, photo paper, glossy paper, matte paper, high resolution paper, luster paper, semi-gloss paper
Standard Media Capacity
500 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to network, scan to Cloud, MAXIFY Cloud Link, Mobile Printing, access point mode
AC 120/230 V (50/60Hz)
46.3 cm x 38.9 cm x 32 cm
12.1 kg
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
15000 pages
200 - 1000 pages
Display Diagonal Size
3"
Display Features
Touch screen
AirPrint Enabled
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, 4 on 1, Frame Erase Copy, collation copy
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Ink Type
Dual Resistant High Density (DRHD)
Automatic Duplexing
First Print Out Time B/W
6 sec
First Print Out Time Colour
7 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 250 pages
Fax Machine Features
Speed Dialing
100 station(s)
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
89 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
275 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 89 x 127 mm, 200 x 250 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
500 sheets
2 x paper cassette - 250 sheets size: 89 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 275 g/m² , ADF - 50 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 24 ipm (A4) - B/W , Printing: up to 15.5 ipm (A4) - colour , Copying: up to 22 ipm - B/W , Copying: up to 11.5 ipm - colour , Scanning: up to 18.5 ipm - B/W , Scanning: up to 15.5 ipm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows 7, MS Windows Server 2008, MS Windows Vista SP2, MS Windows Server 2008 R2, MS Windows 7 SP1, MS Windows Server 2012, Windows 8, Windows RT, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Windows 10 Mobile, Apple Mac OS X 10.8.5 or later
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX
26 Watt
Power Consumption Standby
0.9 Watt
Phone cable
Consumables Included
1 x ink tank (pigmented black) , 1 x ink tank (pigmented cyan) , 1 x ink tank (pigmented magenta) , 1 x ink tank (pigmented yellow)
46.3 cm
38.9 cm
32 cm
12.1 kg
Sound Emission
56 dBA (operating)
15 °C
30 °C
10 - 80% (non-condensing)
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Technology: Ink-jet
Max Paper Size: A4 (210 x 297 mm)
Brand: Canon
Price Range Ex VAT: 100 - 150
