Canon MAXIFY MB2350 Colour Inkjet Multifunction Printer
Quicklinx: 9TTMWS00 Mfr#: 9488B008AA
MAXIFY MB2350 is a high speed 4-in-1 for productive home office with Wi-Fi and cloud connectivity. This fast and productive All-in-One offering business quality color printing for home offices features Wi-Fi and Ethernet, touchscreen operation plus smartphone and cloud connectivity.
  • All-In-One for home offices
    Home office environments often demand productivity and versatility from a space saving design and this business inkjet All-in-one delivers. With wireless and Ethernet connectivity, professional print quality plus copy, scan and fax functions it has a recommended monthly print volume of between 200 and 1,000 pages.
  • High speed document printing
    Never wait around for your business documents again. Fast A4 document ISO print and color speeds are combined with a similarly rapid Quick First Print time of around 7 seconds.
  • Productivity you can depend on
    Make light work of every task including multi-page scanning and copying thanks to two 250-sheet paper cassettes, an integrated 50-sheet ADF and a large color touch screen. Effortless, double-sided printing is also available for added professionalism and lower paper consumption.
  • Connectivity
    With MAXIFY Cloud Link you can print from and scan to popular cloud services directly from the printer screen or from a smartphone using the MAXIFY Printing Solutions app.
Canon MAXIFY MB2350 - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
United Kingdom
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Monthly Duty Cycle (max)
15000 pages
Recommended Monthly Volume
200 - 1000 pages
Max Copying Speed
Up to 21 ppm (mono) / up to 10 ppm (colour)
Max Printing Speed
Up to 23 ipm (mono) / up to 15 ipm (colour)
Max Printing Resolution
Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
89 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper, glossy photo paper, matte photo paper
Standard Media Capacity
500 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
MAXIFY Cloud Link
AC 120/230 V (50/60Hz)
46.3 cm x 38.9 cm x 32 cm
12.2 kg
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
15000 pages
200 - 1000 pages
Display Features
Touch screen
AirPrint Enabled
MAXIFY Cloud Link
United Kingdom
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, 4 on 1, Frame Erase Copy, collation copy
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Ink Type
Dual Resistant High Density (DRHD)
Automatic Duplexing
First Print Out Time B/W
7 sec
First Print Out Time Colour
9 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 250 pages
Fax Machine Features
Speed Dialing
100 station(s)
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
89 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
275 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
500 sheets
2 x paper cassette - 250 sheets size: 89 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 275 g/m² , ADF - 50 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 23 ipm (A4) - B/W , Printing: up to 15 ipm (A4) - colour , Copying: up to 21 ipm - B/W , Copying: up to 10 ipm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows Server 2003, MS Windows 7, MS Windows Vista SP1, MS Windows XP SP3, MS Windows Server 2008, MS Windows Vista SP2, MS Windows Server 2008 R2, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 R2, MS Windows Server 2012, Windows 8, Windows RT, Android, iOS, Windows 8.1, MS Windows Server 2012 R2
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX
29 Watt
Power Consumption Standby
1 Watt
Consumables Included
1 x ink tank (pigmented black) , 1 x ink tank (pigmented cyan) , 1 x ink tank (pigmented magenta) , 1 x ink tank (pigmented yellow)
46.3 cm
38.9 cm
32 cm
12.2 kg
Sound Emission
54 dBA (operating)
15 °C
30 °C
10 - 80% (non-condensing)
