Canon MAXIFY MB2150 Colour Ink-jet Multifunction Printer
Quicklinx: FFHKWS00 Mfr#: 0959C008
Functionality: Printer, Scanner, Copier, Fax
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Ink-jet
Hurry, only 1 left in stock!
£106.46 ex VAT
£127.75 inc VAT
Outstanding multifunction color inkjet printer, scanner, copier and fax, with print and scan support for mobile devices and cloud services, 19 ipm mono print speed and a range of network features.
  • High capacity, high quality
    Versatile printer, scanner, copier and fax designed for home offices that need great mono and color print quality with a low cost per page. With a large feeder and automatic document feeder, the Canon MAXIFY MB2150 Series produces outstanding prints with vivid colors and crisp text using its marker- and friction-resistant DRHD inks. The Canon MAXIFY MB2150 Series prints A4 at a fast 19 ipm mono and 13 ipm color, while its first page out time (FPOT) is just 6 seconds.
  • Productive and easy to use
    Double-sided printing and support for a variety of paper sizes and types - from A4 plain paper to labels, envelopes, photo paper and even two-sided ID card copying - makes light work of common office print jobs. Built for productivity, the printer is quick and simple to use: whether printing, copying, scanning or faxing, they're all within easy each with the Canon MAXIFY MB2150 Series' TFT color screen.
  • Monitoring and maintenance capabilities
    IP address filtering provides access rights to only a select number of users, while SMTP support allows secure scan-to-email within an office network. System administrators can quickly and easily configure the printer and restrict certain operations, such as scan-to-USB.
  • Simple network integration
    System administrators will appreciate the Canon MAXIFY MB2150 Series' Simple Network Management Protocol (SNMP) compatibility, a device management standard that makes it easy to integrate the printer into existing office networks. SNMP enables a range of maintenance monitoring functions, including ink levels, error status, and page counts.
Canon MAXIFY MB2150 - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Monthly Duty Cycle (max)
15000 pages
Recommended Monthly Volume
200 - 1000 pages
Max Copying Speed
Up to 18 ppm (mono) / up to 10 ppm (colour)
Max Printing Speed
Up to 19 ipm (mono) / up to 13 ipm (colour)
Max Printing Resolution
Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
2.5"
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
89 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper, glossy paper, matte paper, high resolution paper, luster paper, semi-gloss paper
Standard Media Capacity
250 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
Wi-Fi(n), USB host, USB 2.0
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to network, scan to Cloud, MAXIFY Cloud Link, Mobile Printing, access point mode
AC 120/230 V (50/60Hz)
46.3 cm x 38.9 cm x 26 cm
10.6 kg
2-year warranty (France - 3 years with product registration)
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
15000 pages
200 - 1000 pages
Display Diagonal Size
2.5"
AirPrint Enabled
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, 4 on 1, Frame Erase Copy, collation copy
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Ink Type
Dual Resistant High Density (DRHD)
Automatic Duplexing
First Print Out Time B/W
6 sec
First Print Out Time Colour
7 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 250 pages
Fax Machine Features
Speed Dialing
100 station(s)
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
89 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
275 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 89 x 127 mm, 200 x 250 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
Paper cassette - 250 sheets size: 89 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 275 g/m² , ADF - 50 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 19 ipm (A4) - B/W , Printing: up to 13 ipm (A4) - colour , Copying: up to 18 ipm - B/W , Copying: up to 10 ipm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows 7, MS Windows Server 2008, MS Windows Vista SP2, MS Windows Server 2008 R2, MS Windows 7 SP1, MS Windows Server 2012, Windows 8, Windows RT, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Windows 10 Mobile, Apple Mac OS X 10.8.5 or later
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX
27 Watt
Power Consumption Standby
0.9 Watt
Phone cable
Consumables Included
1 x ink tank (pigmented black) , 1 x ink tank (pigmented cyan) , 1 x ink tank (pigmented magenta) , 1 x ink tank (pigmented yellow)
Regional Warranty Exceptions
46.3 cm
38.9 cm
26 cm
10.6 kg
Sound Emission
56 dBA (operating)
15 °C
30 °C
10 - 80% (non-condensing)
FFHK Canon MB2050/MB2350 Black Ink In Stock £18.62
FFHK Canon MB2050/MB2350 Cyan Ink In Stock £12.54
FFHK Canon MB2050/MB2350 Magenta Ink In Stock £12.10
FFHK Canon MB2050/MB2350 Yellow Ink In Stock £12.56
Functionality: Scanner
Functionality: Copier
Functionality: Fax
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: Canon
