Canon Maxify GX5050 Refillable Ink Tank Printer
Quicklinx: GQPPWS00 Mfr#: 5550C008
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wireless, Wired
Technology: Ink-jet
Select:
12 In Stock
£333.33 ex VAT
£399.99 inc VAT
The Maxify GX5050 A4 inkjet colour printer is ideal for businesses which required a high volume printing. With functionality of Hi-Speed USB, Wi-Fi, Ethernet, Print and Cloud. This printer has refillable ink tanks (CYMK), up to 14,000 sheets printed in standard mode or up to 6,000 if printing in monochrome. For higher print yield switch to Economy mode for greater savings. Speeds of up to 24 ipm in black and 15.5 ipm in colour. With 2 paper cassettes providing up to 350 sheets (plain paper). Can print banners up to 1.2m length. Print resolution up to 600 x 1200 dpi. Controlled via an LCD 2-line screen.
  • Durable documents - on the double
    Print stand-out business documents with pin-sharp, durable detail at deadline-beating speeds of 24 ipm in black and 15.5 ipm in color. Pigment-based inks deliver stand-out business documents that are marker-, friction- and water-resistant.
  • Compact yet highly capable
    Make light work of busy schedules with this compact printer featuring a tiltable mono LCD screen, 250-sheet cassette and 100-sheet rear feed. Handle diverse media - even print banners up to 1.2m in length (plain paper only).
  • Maximize efficiency
    Be responsible with energy-efficient inkjet printing with high-yield ink bottles that help reduce waste. A user-replaceable maintenance cartridge keeps downtime to a minimum.
  • Get connected
    Print and connect to the cloud via the Canon PRINT app. Compatible with Apple AirPrint (iOS) and Mopria (Android) and harness Ethernet connectivity plus dual-band Wi-Fi support. Enhanced network security keeps documents and hardware safe and secure.
Canon MAXIFY GX5050 - printer - colour - ink-jet
Printer Type
Workgroup printer - ink-jet - colour
9 kg
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering)
Refillable Tank
Ink Refill System
Ink Tank System (ITS)
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A4/Legal
Max Media Size
216 x 1200 mm
Min Media Size (Custom)
89 mm x 127 mm
Max Media Size (Custom)
216 mm x 1200 mm
Print Speed
Up to 24 ipm - B/W , Up to 15.5 ipm - colour
Max Resolution (B&W)
600 x 1200 dpi
Max Resolution (Colour)
600 x 1200 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n)
Intelligent Assistant
Google Assistant, Alexa
AirPrint Enabled
Media Type
Envelopes, plain paper, iron-on transfers, photo paper, magnetic photo paper, glossy paper, matte paper, semi-gloss paper, restickable photo paper
Total Media Capacity
350 sheets
Media Handling
250-sheet paper cassette, 100-sheet input tray
Monthly Duty Cycle (max)
45000 pages
Print server
Printer Features
Wireless Direct Print
AC 100-240 V
Android, Microsoft Windows 7 SP1, Microsoft Windows Server 2008 R2 SP1, Google Chrome OS, Apple iOS, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple iPadOS, Microsoft Windows Server 2022, Windows 11, Apple macOS 11.x, Apple macOS 10.13.6 - 10.15, Apple macOS 12.x
39.9 cm x 41.6 cm x 23.8 cm
Printer Type
Printer
Inkjet Technology
Refillable Tank
Ink Refill System
Ink Cartridge Configuration
4 individual ink tanks
Print Speed
Built-in Devices
2 line monochrome LCD display
Wireless
AirPrint Enabled
600 x 1200 dpi
600 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
7 sec
First Print Out Time Colour
8 sec
Printer Features
Media Handling
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
216 x 1200 mm
89 mm x 127 mm
216 mm x 1200 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 101.6 x 152.4 mm, 89 x 127 mm, 216 x 1200 mm, 127 x 127 mm, 127 x 177.8 mm, 200 x 250 mm, 203.2 x 254 mm, 180 x 250 mm, 177.8 x 254 mm
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Media Weight
64 g/m² - 275 g/m²
350 sheets
Media Feeders
Input tray: 1 - 100 sheets - 216 x 1200 mm weight: 64 g/m² - 275 g/m² , Paper cassette: 1 - 250 sheets - 216 x 297 mm weight: 64 g/m² - 105 g/m²
Duty Cycle
45000 pages
Print server
Security Protocols & Features
WPA-PSK, TLS, 802.1x, WPA2-PSK, TKIP, AES, PEAP
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
PIXMA Cloud Link
Power supply
AC 100-240 V
Frequency Required
50/60 Hz
20 Watt
Power Consumption Stand by
1.4 Watt
Internet of Things (IoT)
Software Included
Drivers & Utilities, PosterArtist Lite, Canon Easy-PhotoPrint Editor, Canon IJ Printer Assistant Tool
5 °C
35 °C
10 - 90% (non-condensing)
Sound Emission (Operating)
49 dBA
39.9 cm
41.6 cm
23.8 cm
9 kg
Type: Printer
Output Type: Colour
Wireless Capability: Wired
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: 216 x 1200 mm
Brand: Canon
