The Maxify GX5050 A4 inkjet colour printer is ideal for businesses which required a high volume printing. With functionality of Hi-Speed USB, Wi-Fi, Ethernet, Print and Cloud. This printer has refillable ink tanks (CYMK), up to 14,000 sheets printed in standard mode or up to 6,000 if printing in monochrome. For higher print yield switch to Economy mode for greater savings. Speeds of up to 24 ipm in black and 15.5 ipm in colour. With 2 paper cassettes providing up to 350 sheets (plain paper). Can print banners up to 1.2m length. Print resolution up to 600 x 1200 dpi. Controlled via an LCD 2-line screen.
                Durable documents - on the doublePrint stand-out business documents with pin-sharp, durable detail at deadline-beating speeds of 24 ipm in black and 15.5 ipm in color. Pigment-based inks deliver stand-out business documents that are marker-, friction- and water-resistant.
                Compact yet highly capableMake light work of busy schedules with this compact printer featuring a tiltable mono LCD screen, 250-sheet cassette and 100-sheet rear feed. Handle diverse media - even print banners up to 1.2m in length (plain paper only).
                Maximize efficiencyBe responsible with energy-efficient inkjet printing with high-yield ink bottles that help reduce waste. A user-replaceable maintenance cartridge keeps downtime to a minimum.
                Get connectedPrint and connect to the cloud via the Canon PRINT app. Compatible with Apple AirPrint (iOS) and Mopria (Android) and harness Ethernet connectivity plus dual-band Wi-Fi support. Enhanced network security keeps documents and hardware safe and secure.
- Canon MAXIFY GX5050 - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- 9 kg
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering)
- Refillable Tank
- Ink Refill System
- Ink Tank System (ITS)
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A4/Legal
- Max Media Size
- 216 x 1200 mm
- Min Media Size (Custom)
- 89 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 1200 mm
- Print Speed
- Up to 24 ipm - B/W , Up to 15.5 ipm - colour
- Max Resolution (B&W)
- 600 x 1200 dpi
- Max Resolution (Colour)
- 600 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- Intelligent Assistant
- Google Assistant, Alexa
- AirPrint Enabled
- Media Type
- Envelopes, plain paper, iron-on transfers, photo paper, magnetic photo paper, glossy paper, matte paper, semi-gloss paper, restickable photo paper
- Total Media Capacity
- 350 sheets
- Media Handling
- 250-sheet paper cassette, 100-sheet input tray
- Monthly Duty Cycle (max)
- 45000 pages
- Networking
- Print server
- Printer Features
- Wireless Direct Print
- Power
- AC 100-240 V
- System Requirements
- Android, Microsoft Windows 7 SP1, Microsoft Windows Server 2008 R2 SP1, Google Chrome OS, Apple iOS, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple iPadOS, Microsoft Windows Server 2022, Windows 11, Apple macOS 11.x, Apple macOS 10.13.6 - 10.15, Apple macOS 12.x
- 39.9 cm x 41.6 cm x 23.8 cm
- Printer Type
Printer
- Inkjet Technology
- Refillable Tank
- Ink Refill System
- Ink Cartridge Configuration
- 4 individual ink tanks
- Print Speed
- Built-in Devices
- 2 line monochrome LCD display
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 600 x 1200 dpi
- 600 x 1200 dpi
- First Print Out Time B/W
- 7 sec
- First Print Out Time Colour
- 8 sec
- Printer Features
- Media Handling
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 216 x 1200 mm
- 89 mm x 127 mm
- 216 mm x 1200 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 101.6 x 152.4 mm, 89 x 127 mm, 216 x 1200 mm, 127 x 127 mm, 127 x 177.8 mm, 200 x 250 mm, 203.2 x 254 mm, 180 x 250 mm, 177.8 x 254 mm
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- Media Weight
- 64 g/m² - 275 g/m²
- 350 sheets
- Media Feeders
- Input tray: 1 - 100 sheets - 216 x 1200 mm weight: 64 g/m² - 275 g/m² , Paper cassette: 1 - 250 sheets - 216 x 297 mm weight: 64 g/m² - 105 g/m²
Duty Cycle
- 45000 pages
- Networking
- Print server
- WPA-PSK, TLS, 802.1x, WPA2-PSK, TKIP, AES, PEAP
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- PIXMA Cloud Link
- Power Device
- Power supply
- Voltage Required
- AC 100-240 V
- Frequency Required
- 50/60 Hz
- 20 Watt
- Power Consumption Stand by
- 1.4 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Software Included
- Drivers & Utilities, PosterArtist Lite, Canon Easy-PhotoPrint Editor, Canon IJ Printer Assistant Tool
- OS Required
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
- Sound Emission (Operating)
- 49 dBA
- 39.9 cm
- 41.6 cm
- 23.8 cm
- 9 kg
