Canon LV-WX300ST WXGA DLP 3000 Lumens Projector
Quicklinx: 9ZWFWS00 Mfr#: 9880B005
Canon LV-WX300ST
Compact, portable WXGA projector with a projection ratio of less than 0.5:1 - delivering bigger images from a shorter distance.
Project vivid widescreen images from a short distance with the Canon LV-WX300ST. This compact short throw projector offers native WXGA resolution, HDMI input and easy setup, making it a superbly flexible performer.
  • Deliver clear widescreen images with native WXGA resolution (1280 x 800 pixels)
  • Enjoy a vivid 3000 lumens brightness and 2300:1 contrast ratio
  • Display bigger images from a shorter throw distance with the 0.49:1 projection ratio
  • 1.0x fixed high-quality short throw projection lens
  • Compact and lightweight: just 2.8kg
  • -18° / +12° vertical keystone correction
  • 4000h lamp life (6000h in Eco Mode)
  • HDMI™ port and 2 x VGA ports
  • RJ-45 network port for remote control and monitoring
  • Built-in 10W speaker
Bright, sharp, faithful images
The LV-WX300ST is perfect for buyers who want a bright, high quality short throw projector at an affordable price. With its native wide-aspect WXGA resolution (1280 x 800 pixels), 3000 lumens brightness and 2300:1 contrast ratio, the projector's DLP technology delivers sharp, accurate images. A 0.49:1 projection ratio creates a host of new installation opportunities, by dramatically reducing the distance required between the projector and screen. Set-up becomes easier, the presenter isn't dazzled by the projector, and shadows on the image are easily avoided.
Convenient to transport
The LV-WX300ST is light enough to carry between locations at just 2.8kg. This makes it a great choice for business and educational establishments that may need to project in a number of locations across a campus or corporate office. The short throw capability is ideal in cramped or cluttered environments where positioning a traditional projector can present challenges.
Easy to set up
Ensure images retain perfect geometry even in tight spaces using the vertical (-18/+12 degrees) keystone correction. For extra help to achieve great results in environments with no screen, use the screen colour correction feature. This compensates for the image colouring that occurs when images are projected onto coloured walls - so audiences can enjoy clear projected images with natural colours, even when a screen is not available.
Reduce costs - not quality
Total cost of ownership is kept low by the LV-WX300ST's 4000-hour lamp life, which can be extended up to 6000 hours using the energy-saving Eco Mode. In addition, Eco Mode further reduces energy consumption to just 270W. The projector consumes less than 1W in Standby (with LAN off). Eco Mode also makes it possible to create a quiet, distraction-free environment by reducing fan noise to just 29 dBA. In addition, there are no air filters to clean or replace, keeping maintenance as simple as possible.
Versatile connection options
Project still and moving images from a wide range of sources using the LV-WX300ST's extensive choice of inputs. Use the HDMI™ port input to project bright and sharp images from today's digital sources, including Blu-ray disc players and notebook computers; or effortlessly connect to either of the two VGA ports. The LV-WX300ST can be monitored and controlled remotely via the RJ-45 port, and it supports the 'Crestron Connected™' standard. Add high-quality sound to presentations using the built-in 10W speaker.
  • Bright, sharp, faithful images
    The LV-WX300ST is perfect for buyers who want a bright, high quality short throw projector at an affordable price. With its native wide-aspect WXGA resolution (1280 x 800 pixels), 3000 lumens brightness and 2300:1 contrast ratio, the projector's DLP technology delivers sharp, accurate images. A 0.49:1 projection ratio creates a host of installation opportunities, by dramatically reducing the distance required between the projector and screen. Set-up becomes easier, the presenter isn't dazzled by the projector, and shadows on the image are easily avoided.
  • Convenient to transport
    The LV-WX300ST is light enough to carry between locations. This makes it a great choice for business and educational establishments that may need to project in a number of locations across a campus or corporate office. The short throw capability is ideal in cramped or cluttered environments where positioning a traditional projector can present challenges.
  • Easy to set up
    Ensure images retain perfect geometry even in tight spaces using the vertical (-18/+12 degrees) keystone correction. For extra help to achieve great results in environments with no screen, use the screen color correction feature. This compensates for the image coloring that occurs when images are projected onto colored walls - so audiences can enjoy clear projected images with natural colors, even when a screen is not available.
  • Versatile connection options
    Project still and moving images from a wide range of sources using the LV-WX300ST's extensive choice of inputs. Use the HDMI port input to project bright and sharp images from today's digital sources, including Blu-ray disc players and notebook computers; or effortlessly connect to either of the two VGA ports. The LV-WX300ST can be monitored and controlled remotely via the RJ-45 port, and it supports the 'Crestron Connected ' standard. Add high-quality sound to presentations using the built-in 10W speaker.
Canon LV-WX300ST - DLP projector - portable
DLP projector - 720p
Built-in Devices
Speaker
Brightness
3000 lumens
Contrast Ratio
2300:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
P-VIP 190 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
330 Watt
28.2 cm x 26.8 cm x 11.8 cm
2.8 kg
3-year warranty
Built-in Devices
Speaker
Ethernet
Projector
Brightness
3000 lumens
Brightness (Reduced)
2200 lumens
Contrast Ratio
2300:1
Image Size
178 cm - 305 cm
Projection Distance
0.74 m - 1.26 m
Throw Ratio
0.49:1
Uniformity
70 %
Digital Zoom Factor
2x
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Display Format
1,024,000 pixels
Bulb type
P-VIP 190 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
sRGB colour profile, PJlink, 16:10 aspect ratio support, Crestron Connected, Eco Mode
Lens
Focus Type
Manual
Lens Aperture
F/2.6
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-18 / +12
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
1 x HDMI - 19 pin HDMI Type A , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management) , 1 x USB - 4 pin USB Type B , 1 x S-video input - 4 pin mini-DIN
1 x VGA cable
330 Watt
Power Consumption Stand by
3 Watt
28.2 cm
26.8 cm
11.8 cm
2.8 kg
Limited warranty - 3 years
Sound Emission
36 dBA
29 dBA
