The CanoScan LiDE120 Color Image Scanner is a compact scanner that offers advanced features and affordability. The "Send to Cloud" functionality, for example, lets you upload photos and documents to the Cloud with remarkable ease. The LiDE120 scanner provides a maximum optical resolution of 2400 x 4800 dpi for dazzling scans of both photos and documents. The Auto Document Fix feature automatically produces beautiful scans with advanced image analysis and area-by-area data correction, while Auto Scan Mode automatically evaluates the item being scanned and saves it with the appropriate settings. The LiDE120 scanner can help you work efficiently with four EZ buttons that enable you to scan, copy, Send to Cloud or create a PDF in a snap. Plus, it scans fast, creating a letter size color scan in approximately 16 seconds. What's more, the LiDE120 scanner uses one USB cable for both data and power, so plugging in is easy. The LiDE 120 includes My Image Garden, a convenient software package that makes organizing your photos fun and easy.
Excellent resolution
This product has 2400 x 4800 dpi maximum optical resolution, 48-bit color depth with over 281 trillion possible colors and 19,200 x 19,200 dpi (Interpolated) software enhanced scans. -
High speed scan
It delivers a letter size color scan in approx. 16 seconds. -
EZ buttons
There are four buttons that enable you to scan, copy, Send to Cloud or create PDFs faster. -
Auto document fix
It automatically employs area-by-area correction for beautiful, easy-to-view scans. -
Auto scan mode
It automatically recognizes the type of original, then scans and saves with suitable settings with one click of the Scan button. -
Advanced Z-Lid expansion top
It raises approximately one-inch to allow you to scan large items such as personal notebooks and other thick documents. -
Send to cloud
This product gives an easy way to send all your data or attachments to Dropbox or Evernote with a single button. -
Hi-speed USB
You can plug the cable into your PC for a super-fast connection for your data transfers.
- Canon CanoScan LiDE120 - flatbed scanner - desktop - USB 2.0
- Flatbed scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Light Source
- RGB LED array
- Max Supported Document Size
- 216 x 297 mm
- Input Type
- Grayscale / Color Depth
- 16-bit (64K grey levels) / 48-bit colour
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 48-bit colour
- Optical Resolution
- 2400 dpi x 4800 dpi
- Interpolated Resolution
- 19200 dpi
- Max Document Size
- 216 mm x 297 mm
- Supported Document Type
- Plain paper
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Apple MacOS X 10.6.8 or later, Windows 8, Windows 8.1
- Microsoft Certification
- Compatible with Windows 7
- 25 cm x 37 cm x 4 cm
- 1.6 kg
- Interface Type
- USB 2.0
- 216 x 297 mm
Scanner
- Input Type
- Grayscale Depth
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 48-bit colour
- 19200 dpi
- Bulb / Light Source Type
- RGB LED array
- Scanner Speed Details
- 16 sec/scan - colour - A4 - 300 dpi
- Scanner Features
- Powered by USB port, Auto Document Fix, Auto Photo Fix, 4 EZ Buttons, Instant document recognition
Media Handling
- Max Document Size
- 216 mm x 297 mm
- Plain paper
- Interfaces Details
- USB 2.0
- Power Consumption Operational (Standby)
- 2.5 Watt
- Power Consumption Stand by
- 1.5 Watt
- Software Included
- Drivers & Utilities, Canon Scanning Utility, My Image Garden
- OS Required
- 25 cm
- 37 cm
- 4 cm
- 1.6 kg
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
