Canon Legria Mini X Camcorder Black
Quicklinx: C2R1WS00 Mfr#: 9114B011AA
The LEGRIA mini X with Wi-Fi offers pure CD quality audio and a wide dynamic range. The unique combination of ultra-wide angle lens, built-in stand and vari-angle LCD gives you the power to create movies that sound as good as they look.
Get a wider perspective and capture more of every scene using the ultra-wide angle lens with a 160° angle of view for Full-HD movies and 170° for stills. With its unique compact design, the LEGRIA mini X is extremely portable - so you can carry it everywhere you go.
Easily frame yourself and shoot from a wide variety of angles using the innovative 6.8 cm (2.7") vari-angle capacitive touch screen LCD - flip it out to the subject side and you can see a live view of what you are filming. Using the unique built-in stand you can tilt LEGRIA mini X up to a maximum of approximately 60°, giving you a range of perspectives for your movie and reducing the need for a tripod. Stow the stand away or pull it out as required.
  • Professional-sounding results
    Enjoy movies that sound as good as they look with advanced audio. A large built-in stereo microphone with a high signal to noise ratio and wider dynamic range significantly reduces hiss and static and clearly reproduces a wider range of low and high level sounds. Linear PCM recording ensures immersive uncompressed audio, capturing sound sources in pristine CD quality.
  • Don't miss a thing
  • Frame yourself from any angle
  • Connect with Wi-Fi
    Effortlessly showcase your creativity to social networking sites with Wi-Fi. Enjoy remote monitoring to see what's happening at home when you're away using your smartphone or tablet via a Wi-Fi connection and the free 'CameraAccess Plus' app. The LEGRIA mini X is also compatible with the optional Camera Pan Table CT-V1, which enables horizontal panning in a range of 200° and can be controlled from your device over the Internet.
  • Superb image quality
    Enjoy crystal clear Full HD movies and stills with Canon's HS System. A 12.8-magepixel CMOS sensor and powerful DIGIC DV4 processor ensure superb image quality in every situation. Support for AVCHD (50i) and MP4 (25p) means you can select the best format for your workflow.
  • Steady close-up shooting
    Use simple touch control to switch from ultra-wide to close-up mode to give your movies a more conventional look and feel, by reducing the field of view to 64°. The image stabilizer in close-up mode reduces camera shake, giving you stable handheld shots.
  • Flip it your way
    Shoot your movie straight on or upside down and detection orientation will automatically flip footage the right way up - giving you even more shooting flexibility. Review your performance technique with mirror image playback mode, which flips the footage horizontally.
  • Manual audio control
    Adjust the input level directly with the microphone level dial, and configure settings such as directionality and frequency response all within camera. An external microphone terminal allows further expansion and supports mixed recording with the built-in microphone.
  • Free your creativity
    Slow and fast motion recording allows you to slow the footage to a 1/4x or speed up to 4x. Interval recording allows you to create a time-lapse effect making your movies even more appealing.
Canon LEGRIA mini X - camcorder - storage: flash card
Camcorder - 1080p
Media Type
Flash card
Memory Card Slot
SD card
Image Processor
DIGIC DV 4
Wireless Interface
Wireless LAN
Sensor Resolution
12.8 MP
Effective Sensor Resolution
Video: 8.99 MP - Photo: 12.0 MP
Lens System
Wide-angle lens f/2.8
Focus Adjustment
Focus free
Min Focus Distance
40 cm
Image Stabiliser
Electronic
Display
LCD display - 2.7"
Supported Battery
Canon NB-12L Li-ion rechargeable battery (included)
HDMI, USB 2.0
8.2 cm x 10.9 cm x 3 cm
205 g
Camcorder - 1080p
Enclosure Colour
Camcorder Type
Pocket
Camcorder Sensor Resolution
12.8 MP
Sensor Qty
1 CMOS
Effective Video Resolution
8.99 MP
Effective Photo Resolution
12.0 MP
Widescreen Video Capture
Camcorder Media Type
Flash card
Optical Sensor Type
BSI-CMOS
Optical Sensor Size
1/2.3"
Image Processor
DIGIC DV 4
Image Stabiliser
Electronic
Face Detection
Digital Video Format
AVCHD, H.264
Image Recording Format
JPEG
Audio Signal Format
Dolby Digital AC-3 (2 channel), Linear PCM, AAC
HDMI, USB 2.0, Wireless LAN
Connectivity Features
Remote control via mobile devices, remote live view
Exposure & White Balance
Exposure Modes
Programme, automatic
White Balance
Automatic, presets
White Balance Presets
Tungsten light, daylight
Max Shutter Speed
1/2000 sec
Min Shutter Speed
1/25 sec
Exposure Compensation
±3 EV range
Lens System
Focal Length Equivalent to 35mm Camera
16.8mm
Focus Adjustment
Focus free
Min Focus Distance
40 cm
Max View Angle
160 degree(s)
Built-in lens shield
Additional Features
Self-Timer Delay
10 sec, 2sec
Additional Features
RGB primary colour filter, camera orientation detection, interval shooting mode, image mirror, Video Snapshot mode, face detection, DLNA support, HS System, Touch Decoration, high-speed recording, Smart AUTO, fast motion recording, Audio Scene Select function, selectable field of view, built-in stand
Display
2.7" LCD display
Display Format
230,000 pixels
Display Form Factor
Folding
Touch Screen
Display Features
Display brightness control, Touch AE
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Wind noise reduction, sensitivity control
Connector Type
USB 2.0 , HDMI output , DC power input , Headphones , Microphone
AC power adaptor, USB cable, wrist strap
Battery Type
Canon NB-12L Lithium Ion
Details
Battery Life Details
Video recording - 2.6 hours
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
JPEG 4000 x 3000 , JPEG 1920 x 1440 , JPEG 640 x 480
Video Capture
H.264 - 1920 x 1080 - 25 fps - 24Mbps , H.264 - 1920 x 1080 - 25 fps - 17Mbps , H.264 - 1280 x 720 - 25 fps - 4Mbps , AVCHD - 1920 x 1080 - 50 fps , AVCHD - 1920 x 1080 - 50 fps
8.2 cm
10.9 cm
3 cm
205 g
