Canon Legria HF R606 - White
Quicklinx: BCJWWS00 Mfr#: 0280C018
HF R606 is perfect for capturing and sharing special family moments in stunning Full HD quality, the new camcorders make it easy for everyone to shoot creative movies to be enjoyed time and time again.
  • Capture moments you cherish
    Combining Canon's Full HD video system with a high-quality DIGIC DV4 processor, the new camcorders ensure you capture your favorite family moments - from holidays, to parties or school events - in outstanding detail. Featuring a 32x optical zoom lens with a 57x advanced zoom, the models provide the freedom to shoot a diverse range of scenes and subjects both near and far. You'll never lose track of your family when using the powerful zoom, thanks to Zoom Framing Assist. Simply hold the dedicated search button and the camcorder automatically pans out to help you relocate your subject, before zooming in again. You're guaranteed each shot will always be crystal clear, with Intelligent IS automatically reducing camera shake, giving you the confidence to zoom in on the action as it happens. To help you fit more into every shot - such as big groups at family gatherings, or sweeping vistas on holiday - the LEGRIA HF R68 includes a new Wide Attachment lens which can be quickly mounted on the camera to shorten the focal length to 26.9mm, widening the camcorder's overall view.
  • Fun for the whole family
    Adding a creative twist to movies is quick and simple thanks to a range of new and easy-to-use recording modes. With slow motion recording you can cut speeds by 1/2x - ideal for capturing and reliving every detail of a child's first goal - or speed up events by up to 1200x, great for a quick recap of holiday sunsets, or adventurous drives. To help you easily document precious family moments, videos shot in Baby Mode are automatically saved to a dedicated album, allowing seamless playback of your footage, ready to share with loved ones. To make sure your memories are safe against accidental deletion, the file lock function can disable the ability to delete or edit files, so your favorite moments can be viewed by children without risk.
  • Share the memories you've recorded
    Once you've captured all the day's events they can easily be shared to other devices via NFC compatibility¹, including smartphones, tablets and Canon's newly announced Connect Station CS100. It's also easy to upload content to social sites and cloud services, for instant sharing with people around the world. Additionally, the LEGRIA HF R606 is compatible with FlashAir SD cards - allowing you to share, store and play your footage on your smartphone or tablet, without a dedicated internet connection.
Canon LEGRIA HF R606 - camcorder - storage: flash card
Camcorder - 1080p
Media Type
Flash card
Memory Card Slot
SD card
Image Processor
DIGIC DV 4
Sensor Resolution
3.28 MP
Effective Sensor Resolution
Video: 2.07 MP - Photo: 2.07 MP
Lens System
Zoom lens - 32x zoom - 2.8 - 89.6 mm - f/1.8-4.5
Focus Adjustment
Automatic, manual
Min Focus Distance
1 cm
Digital Zoom
1140x
Image Stabiliser
Optical (Intelligent IS with Advanced Dynamic Mode)
Display
LCD display - 3"
Supported Battery
Canon BP-718 Li-ion rechargeable battery (included) , Canon BP-727 Li-ion rechargeable battery (optional)
Composite video/audio, HDMI, USB 2.0
White
5.3 cm x 11.6 cm x 5.8 cm
235 g
Camcorder - 1080p
Enclosure Colour
White
Camcorder Type
Consumer
Camcorder Sensor Resolution
3.28 MP
Sensor Qty
1 CMOS
Effective Video Resolution
2.07 MP
Effective Photo Resolution
2.07 MP
Widescreen Video Capture
Camcorder Media Type
Flash card
Optical Sensor Type
CMOS
Optical Sensor Size
1/4.85"
Optical Zoom
32x
Digital Zoom
1140x
Video Recording Modes
LP, MXP, LXP
Image Processor
DIGIC DV 4
Faders
Wipe fader, auto fade
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
Surround Sound
Dolby Digital AC-3 (2 channel) recording
Auto Focus
TTL contrast detection
AE/AF Control
Face-priority AF, Touch Area AF
Face Detection
Face-priority AF function
Digital Video Format
AVCHD, H.264
Image Recording Format
JPEG
Connectivity Features
Remote live view
Exposure & White Balance
Min Illumination
0.4 lux
Exposure Modes
Programme, automatic
Shooting Programs
Spotlight, portrait mode, night mode, fireworks, low light, sports mode, sunset, beach, snow, baby
White Balance
Custom, automatic, presets
White Balance Presets
Tungsten light, daylight
Max Shutter Speed
1/2000 sec
Min Shutter Speed
1/2 sec
Lens System
Focal Length Equivalent to 35mm Camera
38.5 - 1232mm
Focus Adjustment
Automatic, manual
Min Focus Distance
1 cm
Zoom Adjustment
Motorised drive
Built-in lens shield
Additional Features
Self-Timer Delay
10 sec
Low Lux / Night Mode
Additional Features
Backlight Compensation (BLC), takes photos while film recording, Pre-Rec function, Video Snapshot mode, face detection, Zoom Framing Assist, Touch Decoration, Smart AUTO, Bayer mosaic RGB filter, fast motion recording, Intelligent Image Stabilisation (IS), Audio Scene Select function, remote control via Android devices, FlashAir Card Ready, remote control via iPhone / iPad / iPod Touch, slow motion recording
Display
3" LCD display
Display Format
230,000 pixels
Display Form Factor
Rotating
Touch Screen
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Sensitivity control
Connector Type
Composite video/audio output (mini-phone stereo 3.5 mm) , HDMI output (19 pin mini HDMI Type C) , USB 2.0 (5 pin Mini-USB Type AB) , Headphones (mini-phone stereo 3.5 mm)
Software
Software
Drivers & Utilities
AC power adaptor, USB cable, HDMI cable
Battery Type
Canon BP-718 Lithium Ion
Details
Battery Life Details
Video recording - 2.17 hours
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Memory Card Included
No
Memory Card Max Supported Size
64 GB
Image Storage
JPEG 1920 x 1080
Video Capture
AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 - 50 fps - 24Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1440 x 1080 - 50 fps - 5Mbps , H.264 - 1920 x 1080 - 50 fps - 35Mbps , H.264 - 1920 x 1080 - 25 fps - 24Mbps , H.264 - 1920 x 1080 - 25 fps - 17Mbps , H.264 - 1280 x 720 - 25 fps - 4Mbps
5.3 cm
11.6 cm
5.8 cm
235 g
