Canon LEGRIA HF R406
Quicklinx: 8GVVWS00 Mfr#: 8155B007AA
  • SDHC Memory Card
Get closer to the action with Full HD movies that sound as good as they look. Capture Full HD movies without ever worrying about camera shake with the LEGRIA HF R406. Get closer with 53x advanced zoom and create movies that sound as good as they look with audio scene select.
  • Optical Intelligent IS
    Intelligent IS is the perfect solution to combat camera shake by detecting the scene and automatically selecting from four stabilization modes to counteract movement and prevent blur. The advanced dynamic mode corrects roll and tilt movements that can occur when walking, ensuring sharp steady videos in every situation.
  • 53x advanced zoom; Full HD CMOS
    A genuine Canon HD video lens with 53x advanced zoom lets you capture all the detail in even far away subjects. The Full HD CMOS sensor gives true HD quality and excellent color reproduction even in low light, so your movies will look great on your HDTV.
  • Baby mode
    Capture your child's first steps, first words, or many other firsts with baby mode. Register your child's date of birth in-camera, and add colorful stamps for height and weight. All footage will automatically be sorted to the baby album.
  • Advanced image processing
    The powerful DIGIC DV4 imaging processor ensures higher image quality in low light and a substantial reduction in image distortion as it works together with the optical image stabilizer.
  • Superb quality recording
    Bring out the best of Full HD with progressive recording at the highest rates for AVCHD(28 Mbps) and MP4 (35 Mbps). Whether you're showcasing or sharing, simply select the ideal format and choose from a range of recording rates.
  • Audio scene select
    It's simple to make your movies sound as good as they look with audio scene select. Just select from 5 scene modes and audio settings are optimized automatically to match the scene you're shooting. So whether you're filming speech at a wedding or music at a concert, you can enjoy immersive, realistic audio.
  • Fingertip control
    Smooth operation is easy with a high-resolution 7.5cm capacitive touch screen LCD, which gives you intuitive control of settings and simplifies playback. Opening the LCD panel quick starts the camcorder, so you'll never miss a moment.
  • Cinema-Look filters; touch decoration
    Inspire your creativity with Cinema-Look Filters. Select from 7 adjustable color-grading filters to capture the perfect movie scene. Adding fun effects to your movies without a PC is easy using touch decoration.
  • SDXC card slot
    The LEGRIA HF R406 records Full HD movies direct to an SDXC memory card which are available in a wide range of sizes allowing you to capture hours of footage.
Canon LEGRIA HF R406 - camcorder - storage: flash card
Camcorder - 1080p
Media Type
Flash card
Memory Card Slot
SD card
Image Processor
DIGIC DV 4
Sensor Resolution
3.28 MP
Effective Sensor Resolution
Video: 2.07 MP - Photo: 2.07 MP
Lens System
Zoom lens - 32x zoom - 2.8 - 89.6 mm - f/1.8-4.5
Focus Adjustment
Automatic, manual
Min Focus Distance
1 cm
Digital Zoom
1060x
Image Stabiliser
Optical
Display
LCD display - 3"
Supported Battery
Canon BP-718 Li-ion rechargeable battery (included) , Canon BP-727 Li-ion rechargeable battery (optional)
Composite video/audio, HDMI, USB 2.0
5.6 cm x 11.6 cm x 5.7 cm
235 g
Camcorder - 1080p
Enclosure Colour
Camcorder Type
Consumer
Camcorder Sensor Resolution
3.28 MP
Sensor Qty
1 CMOS
Effective Video Resolution
2.07 MP
Effective Photo Resolution
2.07 MP
Widescreen Video Capture
Camcorder Media Type
Flash card
Optical Sensor Type
CMOS
Optical Sensor Size
1/4.85"
Optical Zoom
32x
Digital Zoom
1060x
Image Processor
DIGIC DV 4
Faders
Wipe fader, auto fade
Image Stabiliser
Optical
Built-in Optical Image Stabiliser
Face Detection
Surround Sound
Dolby Digital AC-3 (2 channel) recording
Auto Focus
TTL contrast detection
AE/AF Control
Face-priority AF, Touch Area AF
Face Detection
Face-priority AF function
Digital Video Format
AVCHD, H.264
Image Recording Format
JPEG
Exposure & White Balance
Min Illumination
0.4 lux
Exposure Modes
Programme, automatic
Shooting Programs
Spotlight, portrait mode, night mode, fireworks, low light, sports mode, sunset, beach, snow, baby
White Balance
Custom, automatic, presets
White Balance Presets
Tungsten light, daylight
Max Shutter Speed
1/2000 sec
Min Shutter Speed
1/2 sec
Lens System
Focal Length Equivalent to 35mm Camera
38.5 - 1232mm
Focus Adjustment
Automatic, manual
Min Focus Distance
1 cm
Zoom Adjustment
Motorised drive
Built-in lens shield
Additional Features
Self-Timer Delay
10 sec
Low Lux / Night Mode
Additional Features
Backlight Compensation (BLC), Pre-Rec function, Video Snapshot mode, Touch Decoration, Smart AUTO, Bayer mosaic RGB filter, Intelligent Image Stabilisation (IS), Audio Scene Select function
Display
3" LCD display
Display Format
230,000 pixels
Display Form Factor
Rotating
Touch Screen
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Sensitivity control
Connector Type
Composite video/audio output , HDMI output , USB 2.0 , Headphones
Software
Software
Drivers & Utilities
AC power adaptor, USB cable, HDMI cable
Battery Type
Canon BP-718 Lithium Ion
Details
Battery Life Details
Video recording - 1.75 hours
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Memory Card Max Supported Size
64 GB
Video Capture
AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 - 50 fps - 24Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1440 x 1080 - 50 fps - 5Mbps , H.264 - 1920 x 1080 - 50 fps - 35Mbps , H.264 - 1920 x 1080 - 25 fps - 24Mbps , H.264 - 1920 x 1080 - 25 fps - 17Mbps , H.264 - 1280 x 720 - 25 fps - 4Mbps
5.6 cm
11.6 cm
5.7 cm
235 g
