Get into HD moviemaking with the LEGRIA HF R16. Lightweight, stylish and undeniably chic, it offers a huge capacity of internal memory and memory card recording - all you need to make your own Full HD masterpiece.
With a huge capacity of dual flash memory, the LEGRIA HF R16 offers both internal capacity and memory card shooting. Store over 3 hours of movies to built-in memory - or record to SD and SDHC cards, which are great for sharing.
For effortless point-and-shoot operation, the camcorder selects the most appropriate scene mode - from a choice of 31 - to automatically obtain perfect settings. Smart Auto mode uses intelligent Scene Detection technology to select a scene mode based on brightness, contrast, distance and overall hue.
The LEGRIA HF R16 is perfect for capturing those special moments. Instant AF achieves pin-sharp focus quickly and Face Detection technology optimizes shooting settings for perfect people shots - tracking up to 35 faces in a frame.
Dual flash memory
With a huge capacity of dual flash memory, the LEGRIA HF R16 offers both internal capacity and memory card shooting. Store over 3 hours of movies to built-in memory - or record to SD and SDHC cards, which are great for sharing. -
Smart Auto with Scene Detection technology
For effortless point-and-shoot operation, the camcorder selects the most appropriate scene mode - from a choice of 31 - to automatically obtain perfect settings. Smart Auto mode uses intelligent Scene Detection technology to select a scene mode based on brightness, contrast, distance and overall hue. -
Video snapshot
Video snapshot mode makes it easy to create your own short movies. Every time the record button is pressed a short movie clip is captured - choose from two, four or eight seconds' length. To make a movie, simply arrange your clips in a play list on the memory card, select a soundtrack, and you're instantly ready to play your movie on a TV - no need for editing on a PC. -
HD to SD conversion
In-camera HD to SD conversion makes sharing movies easier. By reducing the size of your movies to web-friendly standard definition you can upload your movies faster. -
Pre REC
In Pre REC mode, the camcorder starts recording three seconds before the record button is pressed. These three seconds are automatically added to the beginning of each clip, so you can still capture the crucial moment even if you pressed the record button too late. -
Family friendly shooting
The LEGRIA HF R16 is perfect for capturing those special moments. Instant AF achieves pin-sharp focus quickly and Face Detection technology optimizes shooting settings for perfect people shots - tracking up to 35 faces in a frame. -
Continuous shooting with relay recording
If the built-in memory becomes full during shooting, relay recording automatically switches to continue recording on an SDHC card - so you won't miss a thing.
- Canon LEGRIA HF R16 - camcorder - storage: flash card
- Product Type
- Camcorder - 1080p - widescreen
- Media Type
- Flash card
- Memory Card Slot
- SD card
- Image Processor
- DIGIC DV III
- Internal Storage
- 8 GB flash
- Sensor Resolution
- 2.39 MP
- Effective Sensor Resolution
- Video: 1.56 MP - Photo: 1.73 MP
- Lens System
- Zoom lens - 20x zoom - 3 - 60 mm - f/1.8-3.6
- Focus Adjustment
- Automatic, manual
- Min Focus Distance
- 1 cm
- Digital Zoom
- 400x
- Image Stabiliser
- Electronic
- Display
- LCD display - 2.7"
- Supported Battery
- 1 x Li-ion rechargeable battery (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Red
- 6 cm x 12.4 cm x 6.4 cm
- 270 g
- Product Type
- Camcorder - 1080p
- Enclosure Colour
- Red
- Camcorder Type
- Consumer
- Camcorder Sensor Resolution
- 2.39 MP
- Sensor Qty
- 1 CMOS
- Effective Video Resolution
- 1.56 MP
- Effective Photo Resolution
- 1.73 MP
- Widescreen Video Capture
- Camcorder Media Type
- Flash card
- Optical Sensor Type
- CMOS
- Optical Sensor Size
- 1/5.5"
- Optical Zoom
- 20x
- Digital Zoom
- 400x
- Video Recording Modes
- SP, LP, FXP, XP+
- Image Processor
- DIGIC DV III
- Faders
- Wipe fader, black & white fader, sepia fader
- Image Stabiliser
- Electronic
- Face Detection
- Surround Sound
- Dolby Digital AC-3 (2 channel) recording
- Services and Applications
- YouTube capture mode
- Print Standard
- Direct print, Exif Print support
- Auto Focus
- TTL contrast detection
- Image Recording Format
- JPEG
- Interface
Exposure & White Balance
- Min Illumination
- 0.4 lux
- Exposure Modes
- Programme, automatic
- Shooting Programs
- Spotlight, portrait mode, night mode, fireworks, low light, sports mode, sunset, beach, snow
- Special Effects
- Soft, Neutral, Low Sharpening, Vivid, Skin Detail
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Tungsten light, daylight
- Max Shutter Speed
- 1/2000 sec
- Min Shutter Speed
- 1/2 sec
Lens System
- Focus Adjustment
- Automatic, manual
- 1 cm
- Zoom Adjustment
- Motorised drive
- Built-in lens shield
Additional Features
- Self-Timer Delay
- 10 sec
- Low Lux / Night Mode
- Additional Features
- Built-in speaker, backlight compensation, RGB primary colour filter, histogram display, Scene Detection Technology, face-priority AF function, Pre-Rec function, relay recording, Video Snapshot mode, face detection, 25p Cinema Mode
Display
- 2.7" LCD display
- Display Format
- 112,000 pixels
- Display Form Factor
- Rotating
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Stereo
- Connector Type
- Component video output , Composite video/audio output , HDMI , USB
Software
- Software
- Drivers & Utilities, Pixela ImageMixer 3SE
- Included Accessories
- Power adapter, USB cable
- Battery Type
- Canon BP-2L5 Lithium Ion - manufacturer-specific
- Details
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDHC Memory Card
- Internal Storage
- 8 GB flash
- Included Memory Card
- 8 GB
- Image Storage
- JPEG 1920 x 1080 , JPEG 1600 x 1200 , JPEG 640 x 480
- 6 cm
- 12.4 cm
- 6.4 cm
- 270 g
