Canon LC-E8E Battery Charger for EOS 550D 600D
Quicklinx: BG1LWS00 Mfr#: 4520B004AA
The LC-E8E charges the LP-E8 Lithium-ion battery pack that comes with your camera. This battery charger can be used as an additional or replacement charger for both studio use and travelling.
  • Efficient charging
    Designed specifically for the Canon EOS Rebel T2i camera, this battery charger ensures your device is always ready to capture those important moments. Its external form factor makes it easy to carry and use wherever you go.
  • Versatile connectivity
    Comes equipped with a power cable that supports a wide range of power outlets, making it ideal for photographers on the move. Its compatibility with specific Canon models ensures a reliable charging solution for your photography equipment.
Canon LC-E8 battery charger
Battery charger
Camera
Cables
Power cable
Canon LP-E8
Battery charger
Camera
Power cable
Canon LP-E8
