A space saving, affordable mono laser printer for the small or home office, with Wi-Fi for easy wireless networking and printing from smart devices. Quiet, reliable and highly energy efficient it delivers fast, high quality prints.
Space saving, Wi-Fi mono laser printer
Designed to fit comfortably on the desk, and offering easy wireless and mobile printing, this fast, compact and affordable mono laser Wi-Fi printer is perfect for personal and small office use. Its sleek, space-saving design includes a retractable paper tray cover. -
Wi-Fi for network and mobile printing
Print wirelessly from PCs and smart phones and tablets using this Wi-Fi and mobile ready printer. Connecting it to your wireless network is effortless - just push the Wi-Fi key on the printer and you’re ready to go. -
Fast, productive performance
The i-SENSYS LBP 6030w springs into the action the moment you need it thanks to Canon’s Quick First-Print technologies, which ensure quick recovery from sleep mode. With a First Print Out Time (FPOT) of just 7.8 seconds and professional laser print speeds of 18ppm there’s no waiting around for your prints - so you can quickly get back to what’s important. -
Exceptional laser quality
Enjoy the sharpest, crispest text and most detailed graphics thanks to high print resolution with Automatic Image Refinement. The MS (Magnetic Spherical) Toner has been specifically developed to deliver optimum results print after print. -
Energy efficient
Thanks to Canon’s On Demand fixing technology this energy efficient printer uses only 1.6 watts in sleep mode and there’s virtually no warm up time. A convenient front power switch makes it easy to turn off, cutting energy costs and reducing its environmental impact even further. Plus there’s a customisable Auto Shut down mode that automatically turns the printer off for you after a pre-set time. -
Quiet operation
Thanks to Canon’s unique engine design, the i-SENSYS LBP6030w is silent in standby mode and exceptionally quiet during operation - so you can focus on your work without distraction. -
All-in-One cartridge
The recyclable All-in-One cartridge ensures maintenance-free operation and reliable high quality output. The Authentic Canon Laser Cartridge contains toner, drum and cleaning units and can be replaced in seconds without any fuss or mess.
- Canon i-SENSYS LBP6030w - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 188 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 18 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 2400 x 600 dpi
- Image Enhancement Technology
- Automatic Image Refinement
- Interface
- USB 2.0, Wi-Fi(n)
- RAM Installed (Max)
- 32 MB
- Language Simulation
- Canon Ultra Fast Rendering (UFRII LT)
- Media Type
- Envelopes, transparencies, labels, plain paper, heavy-weight paper
- Total Media Capacity
- 150 sheets
- Media Handling
- 150-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 5000 pages
- Networking
- Print server
- System Requirements
- Linux, Apple MacOS X 10.6, Android, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple iOS, Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition
- 36.4 cm x 24.9 cm x 19.9 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- USB 2.0, Wi-Fi(n)
- 2400 x 600 dpi
- First Print Out Time B/W
- 7.8 sec
- Media Handling
RAM
- 32 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 188 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 76.2 x 188 mm
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 150 sheets
- Media Feeders
- 1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 5000 pages
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages ISO/IEC 19752 - Canon 725 Starter
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 870 Watt
- Power Consumption Stand by
- 2.8 Watt
- Power Consumption Sleep
- 1.6 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
- Sound Emission (Operating)
- 49.2 dBA
- 36.4 cm
- 24.9 cm
- 19.9 cm
- 5 kg
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.17 |
